11Likes
5th March 2012, 18:08
#1
08 M5
E60 M5 Master DIY Thread
Please let me know if you find a better DIY for any of the below, either here or on an external site. Also, some of the DIY links are old (ie, external picture links broken), such as the main oil change one, so new DIYs are always welcome.
***ROUTINE/SCHEDULED MAINTENANCE:
Summary of Mike Miller’s Old School Maintenance Schedule (not specific to E60 M5)
(Email Mike Miller for the full writeup: techtalk [at] roundel.org) :
- Brake fluid: Every 1-2 years
- Engine coolant: Every 2 years (50/50 mix of BMW anti-freeze + distilled water)
- Engine oil/filter: Every 7,500 miles (Castrol TWS Motorsport 10W-60)
- Engine air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Cabin air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Power steering fluid: every 30,000 miles (Pentosin CHF 11.S)
- Transmission oil (SMG & 6MT): every 30,000 miles (MTF-LT-2 or Red Line MTL)
- Differential oil: every 30,000 miles (Castrol SAF-XJ or Red Line 75W-140)
- Valve adjustment: every 30,000-60,000 miles
- Spark plugs: every 30,000-60,000 miles (stick with OEM but
Amazon has them cheap)
- Fuel filter: every 60,000 miles
- Engine drive belts: every 60,000 miles
- O2 sensors: 150k miles (or just wait for it to trip a CEL)
- Water/fuel hoses: 150k miles
Oil change [pics dead] :
E60 M5 - DIY Oil Change - Step-by-Step w/Pictures [pic links dead]
- thanks jfenley
Oil change tip for 08+ cars :
DIY oil change update - 2nd drain plug
- thanks ssigarto
Brake fluid flush :
BMW Brake Fluid Change: Bimmerzone.com
- thanks Killer-Bimmer (PDF saved here if external link breaks: http://www.m5board.com/vbulletin/att...uid-change.pdf )
Transmission fluid flush :
DIY: Transmission fluid flush
- thanks Clyde and WallyM5 (original reference thread: Oil/fluid leakage from gearbox! )
Differential fluid flush :
Rear Differential Fluid Change
- thanks SoCaLE39
Spark plug replacement :
BMW E60 M5 DIY: Spark Plug Replacement
- thanks mdyaman (reference thread: e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) )
Spark plug/coil replacement :
OKD Okada/Plasma Direct coil on our E60 M5
- thanks STM5
Air filter replacement :
BMW E60 M5 DIY: Air Filter Replacement
- Dinan air filter replacement: DINAN Air Intake Filter Removal
Fuel filter/sending unit replacement :
Fuel Filter step by step DIY
- thanks mdyaman
Brake rotor/pad/sensor change :
DIY: Front Brake Rotor, Pad, and Sensor Replacement
- thanks f1lmmaker
- also see this video for an E63:
http://www.youtube.com/watch?v=Xzr2PRCqYm8 )
- also see this writeup for an E63:
http://www.bimmerfest.com/forums/sho...d.php?t=523439
Brake pad change :
DIY for Brake Pad Change?
- thanks Clyde
Cabin air filter replacement :
http://www.youtube.com/watch?v=oX0jq...ature=youtu.be
- also:
Fixing Stuff: Replacing BMW E60 Microfilter (cabin air filter)
- thanks sigsegv (reference thread: Replacing Micro Filter )
Service interval reset via OBC :
Reset Oil/Microfilters/Service/etc with Pictures!
- thanks celicatoe46m3
***OTHER MECHANICAL REPAIRS:
Throttle body cleaning :
DIY - Throttle Body Removal and Cleaning - With Images
- thanks duhmingus
Throttle actuator motor replacement :
Replacing throttle actuator motor with pics
- thanks vataam5
Replace VANOS solenoids :
DIY - Changing the S85 VANOS solenoids
- thanks anzafin
(see here for additional VANOS info:
S85 Vanos Adjustment Unit Replacement DIY Question )
Alternator removal/replacement :
E60 M5 Alternator Removal Instructions DIY
- thanks Euroskeptik
Rear window cover/seal :
E60 BMW M5 Rear Window Cover Replacement DIY - YouTube
- thanks mcw331 (reference thread: DIY: Replacing Rear Window Cover )
Windshield trim replacement (E63) :
- thanks Clyde
Voltage regulator :
FYI: E60 M5 S85 Valeo Voltage Regulator for Alternator
- thanks latinskllz
Radiator/Cooling system :
- thanks Euroskeptic
SMG service workflow and troubleshooting diagrams :
http://forums.5series.net/uploads/11...213_519805.pdf
- thanks phorte
SMG pump relay replacement :
SMG Pump Relay replacement Do it Yourself!
- thanks cobratom (also see here from B767capt:
Anyone have the part number on the smg hydraulic pump relay? )
SMG repair/replacement pictorial :
Trans. fault! Drive moderately + pics
- thanks ///power
New battery registration :
Battery Registration
- thanks dave t (E63 forum)
Steering angle sensor (SZL) cleaning :
Steering angle sensor DIY fix - it worked
- thanks shuriki and g_force_alt (reference thread: Steering angle sensor DIY fix - it worked )
MAF sensor removal/cleaning :
MAF Sensor Removal & Cleaning
- thanks mdyaman
Access/repair windshield wiper fluid reservoir :
Leaking Windshield washer reservoir - Bimmerfest - BMW Forums
- thanks mdyaman (reference thread: How to access windshield washing reservoir )
Pre-Cat O2 sensor replacement :
Pre-Cat O2 Sensors Replacement
- thanks douglas_ngo
Themostat replacement :
Anyone have a DIY for Thermostat Change?
- thanks vantaam5 and PRM5
Remove transmission (from ISTA) :
DIY: Remove & Install Transmission
- thanks WallyM5
***PERFORMANCE:
Charcoal filter removal :
Charcoal Filter Removal - Step-by-Step (w/Pictures)
- thanks Jfenley
Scoops (RPI) :
Race Precision Forums • View topic - RPi e60 M5/530/545 Ram Air Intake Installation Instructions
- thanks RPI
Block off plates :
Race Precision Forums • View topic - E60/E63 Ram Air Box - Block Off Plate/Plug Installation
- thanks RPI
Scoops/filters (aFe) :
DIY - Scoops, Drop-in filters & Intake Tube Couplers
- thanks Bryan@JleviSW
Oil cooler :
Race Precision Forums • View topic - RPi M5 Oil Cooler Install Instructions
- thanks RPI
DME/ECU removal :
Race Precision Forums • View topic - E60 M5 DME/ECU Removal Instructions
- thanks RPI
Sprint booster install :
BMW Sprint Booster Installation - Bavarian Autosport - YouTube
- thanks Fumanstu (reference thread: Sprint Booster Diy ? )
Pulley install :
Race Precision Forums • View topic - RPi Pulley Kit Installation - M5/M6
- thanks RPIpower (reference thread: Pulley install, DIY? )
Spring install 1 (front/rear for E63) :
DIY lowering spring installation
- thanks survyor2 (E63 forum)
Spring install 2 :
Advice on installing aftermarket springs?
- thanks ktan
Spring install 3 :
Eibach springs & spacers pictorial, including install
- thanks stunt
Spring install 4 :
Thoughts post Eibach Spring install
- thanks supark
Bolt replacement after spring install :
WARNING! All owners with lowering springs or modified suspension. ACTION REQUIRED if incorrectly installed!
- thanks V10PWR
SMG Euro software reprogram :
Reprogram Euro SMG software to US cars! (Faster shifts + 4k Launch Control) for free!
- thanks Vodyk for expertise and BB8888 for DIY summary (reference thread: Reprogram Euro SMG software to US cars! (Faster shifts + 4k Launch Control) for free! )
Nitrous Oxide (NOS) controller wiring :
HOW TO: Nitrous Oxide Controller Wiring for 2006-2010 BMW M6
- thanks rocket5979
Short-throw shifter install :
Short Shifter DIY.
- thanks Infamous Q
***EXTERIOR COSMETIC:
Headlight height adjustment [pics dead] :
2006 M5 - Vertical Headlight Aiming
- thanks Kegger and jseter
Headlight removal/replacement :
BMW E60 angel eyes replacement installation right side - YouTube
- thanks m5Dreamin (reference thread: detailed guide to change the m5 angel eye bulb? )
Taillight removal/replacement :
DIY LCI taillight retrofit - 5 Series Forums
- thanks mdyaman (reference thread: brake lights )
Kidney grill removal :
How to remove and install new kidney and side grills?
- thanks avlynch
Side grill removal :
How to remove e60 M5 side vent - YouTube
- thanks wstxoutlaw (reference thread: side grill removal : searched )
Roundel replacement :
Product Installation Tutorial: BMW Roundel Upgrades - YouTube
- thanks Jlevi_SW (reference thread: DIY Install Video : LED Sidemarker Lenses )
Painting brake calipers :
Painted My Calipers...
- thanks zerocks1 (E63 forum)
Replace lower side mirror cover :
How To: CF lower mirror cover install
- thanks ///Pete
LED side turn signal :
DIY LED Side Signal BMW M5 E60 Do It Yourself
- thanks V10PWR
LED side turn signal_2 :
- thanks Bryan@Jlevi_SW
All red tail lights :
DIY: All Red Taillights
- thanks MTV10
LED license plate lights :
LED XENON License Plate Light Installation Instructions for E60 M5
- thanks V10PWR
Door pathway/puddle light upgrade :
Logo Puddle/Welcome Lights
- thanks Tottifan
***INTERIOR COSMETIC/REPAIRS:
Remove airbag warnings from visor [no pics] :
Destickered M5 - removing airbag warning stickers
- thanks Wolverine
Interior trim carbon fiber wrap (pre LCI) :
Jlevi SW | Dinoc Carbon Fiber Wrap DIY Guide For E60
- thanks Jlevi SW
Aluminum pedals :
DIY: Aluminum Racing Pedals
- thanks ttribe
Shift knob replacement (6MT) :
DIY - Installation of a ZHP Shift Knob
- thanks OldM6guy (E63 forum)
E-brake handle replacement :
DIY Carbon Fiber E-Brake Handle Replacement
Steering wheel trim replacement :
DIY: Install Carbon Fiber Steering Wheel Trim
- thanks Clyde (E63 forum)
Steering wheel trim replacement 2 :
Removal & fitting of E60 lower trim cover - MY MOTIV BMW
- thanks rittiman (reference thread: Anyone replace SMG paddle ? )
SMG shift paddle replacement :
Shift Paddle Replacement
SMG plate removal/replacement :
SMG plate removal and repaint [pics]
- thanks petesamprs
Squeaky side bolster repair :
Squeaky Active Seating Bolster
- thanks CBarton and OzMosis
Heads-Up Display height adjustment :
BMW E60 Heads Up Display Adjustment
- thanks Turner Motorsports
Cupholder removal/replacement :
http://www.youtube.com/watch?v=9tWfK...ature=youtu.be
- thanks mdyaman
***ELECTRICAL/SOFTWARE/AUDIO:
V1 hardwire (tap passenger footwell cigarette lighter) + Concealed display :
Valentine V1 Install w Remote Audio Adapter and Concealed Display - With Pic's!
- thanks rlpM5
V1 hardwire (tap sunroof wiring) :
radardet - 5 Series Forums
Coding/software tweaks [E60 forum] :
Coding your M5
- thanks bowtie17
Coding/software tweaks 2 [E63 forum] :
DYI _Coding the E63-E64 *Updated 02-21-2011
- thanks zerocks1
Laser jammer install :
DIY Lidatek installation on a M5 E60 (PDF and pics)
- thanks Gustav
iPod MOST adapter :
DIY IPod MOST Adapter Install in 2006 M5
- thanks mcw331
Auxiliary input install (for early model E60s) :
DIY: auxiliary input E60
- thanks bimma328
Center channel speaker replacement (E63) :
M6 Center Channel Speaker Replace DIY
- thanks whatheheck and KILLZBUGZ (reference thread: M5 Center Speaker Upgrade (DIY Link) HQ )
Diversity antenna amplifier replacement :
Diversity Amplifier Replacement - 5Series.net - Forums
- thanks mdyaman
2010 CIC install (updated NAV) :
2010 CIC install in 2006 M5 Pictorial
- thanks stunt
***OTHER RESOURCES:
E60 M5 aftersales manual :
http://www.midia.nl/diversen/bmw/E60...te_Vehicle.pdf
Alignment specs :
Alignment Specs and Shock Specs for E60 M5, many of us wanted this!
- thanks bmw1986
Torque tightening specs (NOTE: this is for older BMWs; may not apply for E60/S85 engine in all cases ) :
http://www.bmw-m.net/TechData/torq/bmw_torq.pdf
- thanks mdyaman
Fuse Diagram (E63) :
M6 Fuse Lay Out
- thanks Clyde and whatheheck (E63 forum)
Check control messages (E92) :
Check Control Guide
- thanks mdyaman
Access hidden NAV menu :
Screenshots of the hidden/secret menu [access to GPS speed too]
- thanks scoopz
Wiring diagram (general E60) :
WDS BMW Wiring Diagram System - 5 E60 E61
Find a local indy :
BMW Repair Shops- Find a BMW Mechanic | BimmerShops.com
Owner’s manual :
Owner's Manual - BMW North America
Find part numbers :
RealOEM or
Penske Parts
DISCLAIMER: In most cases these DIYs are not written by professionals. Undertake these projects at your own risk.
Recently sold:
2008 / / / M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
The Following 18 Users Say Thank You to petesamprs For This Useful Post:
chowdah (6th March 2012),
E39 GaGaN (9th April 2012),
elmar (19th April 2012),
FCS5 (6th March 2012),
JayDubb (23rd May 2012),
Kegger (6th March 2012),
khyber (6th March 2012),
Killer-Bimmer (7th March 2012),
MarlonF1 (6th March 2012),
mdyaman (5th March 2012),
messex (5th March 2012),
Miguex (6th March 2012),
OzMosis (6th March 2012),
S2000 (15th May 2012),
ttribe (29th May 2012),
TwinTurboZ (8th March 2012),
V10PWR (17th April 2012),
VOVE (9th July 2012)
5th March 2012, 18:09
#2
Drives a ///M
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current : 2008 e60 DINAN ///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops.
5th March 2012, 18:23
#3
2008 M5 SMG
Just what we need here. I did the Laser Jammer last week. Waiting for a SMG clutch replacement. I see there is one on here done overseas. If I do the SMG, I'll post with pictures.
5th March 2012, 18:42
#4
08 M5
Originally Posted by
B767capt
Yes, the SMG replacement on here I believe was done by a guy in Saudi Arabia. It wasn't really a full DIY - more just pictures of progress. If you do end up doing the SMG, and full DIY w/ pics and tools required would be immensely valuable.
thanks.
5th March 2012, 18:52
#5
Wow - this is great - I fully agree - this needs to be a sticky. If I put any DIY together in the near future, I'll be sure to do a write up, and include in this thread, if desired.
Performance Mods
Eurocharged ECU Tune, Charcoal Filter Delete, RPI Ram Air Kit/Block Off Plates, RPI Oil Cooler, M Sprint Booster V2
Cosmetic Mods
H&R Lowering Springs, 20" ConceptOne Wheels, Blacked out Kidneys/Side Vents, 6W Angel Eyes
6th March 2012, 03:43
#6
E60 M5
This is great! Thank you!
6th March 2012, 06:25
#7
Thanks, we really need this!
Sticky please!
"It's like the F10 is the 911 Turbo to the E60's GT3."
6th March 2012, 14:59
#8
08 M5
Added a bunch more to the list yesterday and this morning. There are still some major holes.
The E39 one is a good inspiration:
Do It Yourself (DIY) Guidepost
I like the idea of putting the summary of the Old school maintenance schedule at the top of the main thread. Will do that as well.
6th March 2012, 15:27
#9
Drives a ///M
petesamprs
hey pete, have you contacted (PM'd) a board admin to make this post a sticky?
6th March 2012, 16:24
#10
E46 E39 E60
Thanks for sharing. Definitely sticky this thread. I just added this to my favorite link.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Rate This Thread
Linear Mode
