E60 M5 - DIY Oil Change - Step-by-Step w/Pictures [pic links dead] - BMW M5 Forum and M6 Forums
Like Tree3Likes
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 22nd August 2006, 21:43   #1
jfenley
jfenley's Avatar
Garage: E60 M5 Silverstone/Full Silverstone Perf/Aluminum
Some have posted oil change info in the past, but it I think most could use more detail in how to get it done. I decided to do an interim oil change last night at 9,000 miles. I think it was a good thing - the oil looked pretty dirty. Here is my take on getting it done.
Equipment you will need:
Jack - preferably a floor jack
Jack Stands
Torque Wrench - or socket wrench
6mm Allen Head Socket
24mm Socket
3" Socket Extension
Filter Kit - available from dealer for about $12.00
9 Litres of Castrol 10-60
Large Piece of Cardboard, or a Tarp
Oil Drain Pan (with capacity to hold 15 qts.)
STEP 1: Get the car jacked up. (if you have access to a lift, GREAT!! - your job will be a lot easier) For the rest of us, I'll leave it to you to figure out how to do this, but here is a little info on how I did it. There are 5 jack points that I know of. The first four are the corner points under the side skirts, just on the inside of each wheel. The points are very easy to find - they are marked by small arrows on the side skirts, or if you look under the car, you will see plastic rectangle pieces. The 5th point is under the front center of the car - a couple feet in from the front, in the center, there is a plastic block that is about 1.5" x 4". My problem with this point was that my floor jack wouldn't fit far enough under the car (due to H&R springs). If your car is not lowered, or if you have a lower-profile floor jack, I think this is the best point to use. I lifted the car, and put jack stands on the two front/side jack points. Make sure to put wheel stops behind the rear wheels. To get the front two jack stands in place, I first jacked the rear passenger side and put the first stand in place on the front passenger side. Then I jacked just in front of the jack point on the front driver's side and put the second stand in place at the front driver's side jack point. Jacking in front of the jack point didn't do any damage to the car.
Keep in mind I did this at night, so the pictures are not so great.
For reference, here is the front center jack point:
STEP 2: Place a tarp or some cardboard under the car where you will be working so you protect your driveway from oil spills.
STEP 3: Locate the oil drain plug. It is in the center of the car and there is a circular cutout in the undercarriage to access it - see picture below - there are some reference points so you can't miss it.
STEP 4: Using your socket wrench, attach a 6mm allen head socket and insert into drain plug. It takes some torque to losen, so the longer your wrench, the better. Turn it just enough to losen it and then put your drain pan in place. Remove the wrench from the socket and use your fingers to turn the socket to slowly remove the plug. Be careful towards the end, as the oil is about to come rushing out. Let the oil drain completely. Once the oil has drained, I lowered the car back to a level position and about another 1/2 litre came out. I would recommend doing this.
STEP 5: The drain plug has a small copper washer. Remove the old washer and replace it with the new one that came with the filter kit. Reinstall the drain plug and torque reasonably tight. I failed to get the torque figure from the dealer, but I'm sure one of you can come up with it - please post.
STEP 6: Remove the access panel under the front passenger side of the car. This is a small panel at the very front corner. There are four screws to remove (sorry, I'm not sure what size wrench - maybe 6 or 7mm). Remove the screws and remove the panel.
With this cover removed, it will reveal the oil filter housing:
STEP 7: Loosen the silver drain plug in the center of the filter cover with your 6mm allen socket. You will probably need an extension for this. Reposition your drain pan and carefully remove the plug and let the oil drain out.
STEP 8: Remove the gasket from the plug and replace with the new gasket included in the filter kit. Reinstall the plug.
STEP 9: Loosen the filter cover with a 24mm socket and remove the cover, slowly by hand. Be careful as there will still be a little oil in the cover. Remove the filter element by pulling gently.
STEP 10: Wipe the inside of the housing with a clean towel and install the new filter element by firmly pressing it into the housing - you will feel it click in.
STEP 11: Replace the gasket on the filter housing cover and reinstall the cover, then reinstall the access panel.
STEP 12: Remove oil pan and all tools from under the car. Leave the ground cover in place. Lower the car and fill with 9 litres of oil. Inspect under the car to make sure nothing is leaking. Take a drive and let the engine warm up to temperature and then take a quick reading of the oil level. If you drained all of the oil properly, you should come out with a new reading of 1.0L. (Mine was actually 1.1L).
jfenley is offline   Reply With Quote
The Following 18 Users Say Thank You to jfenley For This Useful Post:
BMWNTHZST (7th October 2009), BMWPower06 (17th September 2009), carlsturm (14th March 2009), Daywlkr29 (7th July 2011), Dbld (1st April 2010), dvdoughboy (14th March 2009), EM_5 (1st March 2010), F1_SMG (16th June 2010), hbpetrides (29th March 2010), JAY55 (20th July 2010), M5Express (10th May 2010), mackyfr (5th September 2009), Minimization (17th May 2010), Munir (26th May 2009), nanoera (11th May 2010), redm3sedan (7th February 2012), TwinTurboZ (10th January 2012), YellowCog (14th September 2009)
Old 22nd August 2006, 21:55   #2
kees
Administrator
Garage: magic moderator wand
Excellent post yet again!
Couple of pointers:
1) if you have difficulty with a jacking point (like you did here with the central jacking point) - a common trick with lowered cars is to tuck a brick or small block of wood under each of the front tires and drive the car onto them. Often that will be enough to access the jacking point.
2) somehow disable the car from being started without oil being filled in the engine or it could be a very expensive repair. One step could be to take the keys out of the ignition and toss them in between the cans with new engine oil.
3) Another step is to check under the car for a massive oil puddle after filling up the oil and starting the car - e.g. to catch situations where the drain plug or filter isn't properly seated.
kees is offline   Reply With Quote
The Following User Says Thank You to kees For This Useful Post:
jchris (20th July 2010)
Old 22nd August 2006, 22:29   #3
LI-M5
LI-M5's Avatar
Garage: M5 E 60 interlagos blue/black/alum
jfenley your the man with the diy guides, you should have a show on tv called diy for the e60.kinda like tim allen in tool time..
2013 F10 M5
Apline White/Black/Black
LI-M5 is offline   Reply With Quote
Old 22nd August 2006, 22:36   #4
ALTANertive
ALTANertive's Avatar
Garage: E60 M5 Silver Gray/Indianapolis Red/Aluminum
What direction is the oil filter opening facing?
2006 BMW E60 M5 SG/IR/Al
ALTANertive is offline   Reply With Quote
Old 22nd August 2006, 22:39   #5
jfenley
jfenley's Avatar
It's in the front of the front passenger wheel at the very front corner of the car
Old 22nd August 2006, 22:58   #6
ALTANertive
I'll try to re-word my quetion so it's a little clearer. For the E46 M3, the opening for the oil filter is facing upwards so that when you install the filter, it is possible to add a quart or so of oil to reduce oil choke on the first startup. Is this possible for the M5 or is the opening sideways/upside-down so that it isn't possible?
Old 22nd August 2006, 23:54   #7
canysmc
canysmc's Avatar
Garage: 06 Indy Red M5
Sales Feedback: (3)
Gotta love these DIY writeups.
20XX M5 Its Got To Be Red
2008 328i Vert Crimson Red/Brown
1996 Porsche 993TT Iris Blue/Grey
2007 Ducati Monster S4RS Testastretta
2005 Ducati S2R
2007 Aprilia Sportcity 250ie
2009 Aprilia Sportcity One 125
2007 Mini Cooper S Vert Sidewalk Package Sparkling Silver/Malt Brown
2006 750Li White/Brown
2006 M5 Indianapolis Red/Indianapolis Red
2001 M5 Imola Red/Black/Imola Red
The Mercedes Benz/Range Rover Years
1992 Miata Red/Black
1987 535is Blue/Beige
1987 930 Black/Black
1985 535i White/Black
1985 911 Black/Black
1972 911 Blue/Black
canysmc is offline   Reply With Quote
Old 23rd August 2006, 00:08   #8
jfenley
jfenley's Avatar
Sorry - now I see what you are asking. It is facing up - you could add oil - that is a good idea. I didn't do it, though.
Old 23rd August 2006, 03:07   #9
M CRISIS
M CRISIS's Avatar
Garage: 2006 M5 SILVER GRAY
I wonder how much a 10min Oil quick change place would charge if I supplied the filter kit and the oil? Haven't changed my own oil in 15 years!
"...it (SMG) makes everybody look like Michael Schumacher" - Bill Auberlen (excerpt from Road & Track's feature video - 2009 Cadillac CTS-V vs. 2008 BMW M5 SMG)
M CRISIS is offline   Reply With Quote
Old 23rd August 2006, 03:17   #10
jfenley
jfenley's Avatar
I haven't changed my own oil in over 15 years either. This wasn't so much a "do it to save money" project - it was more a "do it to figure out how to do it" project. I figure an oil change at the dealer would be around $200-$250. I spent about $600!!! ($325 for floor jack, jack stands, wheels stops - $125 for oil and filter - $125 for torque wrench and allen sockets - $25 for funnel and catch pan). Granted, my next oil change will cost oil and filter only because I now have the proper tools.
I wouldn't trust it to Jiffy Lube - even if you bring your own filter and oil. Best bet is the dealer - but I would definitely do it at intervals between the scheduled service - the oil was really dirty and my driving is moderate.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Braheem24
Wow! Just had a blast driving a E60 M5 and E55 AMG! ATLANTA M5 E60 M5 and E61 M5 Touring Discussion 36 4th May 2006 06:15
E60 M5 - Charcoal Filter Removal - Step-by-Step (w/Pictures) jfenley M5 E39 and E60 tips & tricks 0 2nd February 2006 06:05
A Race, A Cool Guy, and a Test of the E60 M5 Wrightsville Beast E39 M5 and E52 Z8 Discussion 11 1st January 2006 18:08
Customer Advisory letter from BMWNA regarding Vanos oil line Lohe E60 M5 and E61 M5 Touring Discussion 52 12th December 2005 19:01
14 September press release in English, 0-100 4,7s SuperBMW E60 M5 and E61 M5 Touring Discussion 0 14th September 2004 11:23
