DIY: SMG Pump Relay replacement Do it Yourself! - BMW M5 Forum and M6 Forums
Like Tree8Likes
Old 23rd December 2012, 22:23   #1
cobratom
Garage: 2006 BMW M5 Gray
Post SMG Pump Relay replacement Do it Yourself!
Ok, so I decided to do a quick DIY to replace the SMG Relays. There are two of them. One of them Salmon colored, the other black.
Here are the Part numbers for both relays:
SMG Pump relay: 61366901469 ($10.94)
Transmission Oil Pump Relay: 12631742690 ($6.94)
You can get them from GetBMWParts.com (best prices online) and most dealers stock them.
You will need:
#5 Allen Wrench or Driver
Torx 20 Screwdriver
13MM Driver or Socket/Ratchet (a 13mm wrench will not work, its too tight around the plastic nuts)
1. Open Your hood and locate the passenger side cabin air filter
2. Undo the Plastic 13mm nut by turning it 90 degrees and pull the cabin air filter up and out of the way
3. Remove the drip/water tray to the left near the fender
4. Undo the Torx bolt right below where the cabin filter is:
5. Turn the 3 13mm nuts in the passenger tray 90 degrees clockwise
6. Remove the rubber moulding and set it out of the way, The tray is made out of two pieces, unlock the two pieces by sliding the piece in the center of the tray to the right, and undo the 13mm plastic nut underneath 90 degrees clockwise
7. Remove the tray and place it out of the way, on the left side you will have a Electronics cover. Remove the 5 #5 Allen head screws, and turn the locking tab in the back of the cover and slide it to the left to unlock. Pull up and expose!
8. Locate relays in the back of the ECU compartment. There is only one black one, and one salmon one. Use Pliers to pull up on the top, paying attention to the position of the relay and replace with the new relays.
Follow instructions backwards to put everything back in place and then you no longer have to worry about a relay leaving you stranded!
cobratom is offline   Reply With Quote
The Following 5 Users Say Thank You to cobratom For This Useful Post:
CSBM5 (26th December 2012), Hasan Shaikh (24th December 2012), lumi (23rd December 2012), MKSixer (25th December 2012), potassium (24th December 2012)
Old 24th December 2012, 08:24   #2
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
Were you having SMG issues, or was this preventative maintenance?
Clyde is online now   Reply With Quote
Old 24th December 2012, 15:33   #3
petesamprs
petesamprs's Avatar
Garage: 08 M5
thanks for writeup. Added to DIY master.
Any chance you can upload the pics directly to this site (rather than linking from postimage), so they are not lost if that site goes down.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is online now   Reply With Quote
Old 24th December 2012, 15:39   #4
cobratom
Preventative maintenance. I did have the red cog randomly flash a couple of times but from pulling codes its because os 5101 "SMG too sensitive" according to a bulletin.
Yes, I can post them on this server, but how do you want that done? Just upload via attachments? or do you guys have a uploader specific to this?
The Following User Says Thank You to cobratom For This Useful Post:
Old 24th December 2012, 16:31   #5
mdyaman
mdyaman's Avatar
Garage: Drives a ///M
Upload via attachments.
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops.
mdyaman is online now   Reply With Quote
Old 24th December 2012, 20:50   #6
Clyde
Clyde's Avatar
I always upload directly to the site using attachments. The order of pictures sometimes get shuffled, which can make DIY threads a little confusing -- so split the DIY into several posts with only a few attachments each.
For DIY threads I generally scale to down to 600 or 1000 pixels wide and reduce quality.
For threads where quality is important, upload full resolution (the site will display large thumbnails).
Old 23rd January 2013, 12:33   #7
Bronzegod
Bronzegod's Avatar
Garage: BMW M6 black
When should one replace these? My '07 has about 38k mi. on it.
Bronzegod is offline   Reply With Quote
Old 23rd January 2013, 13:05   #8
B767capt
B767capt's Avatar
Garage: 2008 M5 SMG
I would do it now. They're cheap and get a lot of hard use. Every 20-30K maybe. Buy 2 and have a spare.
B767capt is offline   Reply With Quote
Old 23rd January 2013, 14:02   #9
bimma328
bimma328's Avatar
Garage: m5 white
i dont see why changing relays would fix the issue you mentioned, relays either work or don't work, when they are dead they either wont "click" to close or "stick" in the closed position, whats your train of thought on this issue?
from what i read on the other forums all you need is an smg program update and re-adaptation and you're done
E60 ///M5 White on Black oem 166's
Quote Taken from member QuickSilv3r : Stupid to buy an ///M and not drive it, it's like paying a hooker for a hug
bimma328 is online now   Reply With Quote
Old 23rd January 2013, 14:05   #10
bimma328
bimma328's Avatar
Garage: m5 white
my car has almost 80k and 2 of my friends have over 120k, never replaced these, i don't see why you should
Anyone have the part number on the smg hydraulic pump relay? deebom3 E60 M5 and E61 M5 Touring Discussion 19 30th March 2013 22:23
Transmission Warning -> SMG Pump Replacement Impulse E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 48 27th February 2013 04:24
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 68 5th September 2012 02:25
SMG Pump Replacement CabCreekM5 E60 M5 and E61 M5 Touring Discussion 4 9th May 2011 00:10
urgent help needed! fuel pump relay or pump itself?? jonnycowboy E39 M5 and E52 Z8 Discussion 14 1st October 2009 15:58
