26th April 2010, 05:51
#1
2001 M5 Jet Black
DIY Accelerator Pedal Removal
In the process of installing my new aluminum ///M pedals, I needed to remove my gas pedal. Of the two or three threads and DIY that I found on the subject after lots of searching, they were ALL WRONG  . I absolutely ruined my pedal because of what they said to do  . After much frustration I ordered a new pedal for around $20 and decided I would do everyone a favor and show how this darn pedal connects to the car.
Overall it is a simple procedure: Pop latch behind pedal down, use a flat-head screwdriver to push from BEHIND on the two plastic catches while pulling up on the pedal. Then twist the pedal back on the upper hinge to remove. Voila!
Now to show with pictures..
1) Pull the clip from behind down, it might take a bit of effort, and you have to really push it into the carpet for the clamp to clear enough to remove the pedal.
2) Push from behind with the object of your choosing. If you have enough extra limbs to do both at the same time then great. Otherwise you'll have to go one at a time.
3) Twist the pedal back to slide off the hinge
Hope this saves you the hassle I went through..
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler, Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
The Following 9 Users Say Thank You to russap5 For This Useful Post:
26th April 2010, 23:43
#2
2001 M5 Jet Black
lol just 1 thanks!? psh you guys will thank me later..
thanks chowdah!
27th April 2010, 01:27
#3
I could have used this diy a few months ago. My pedal came apart at the bottom hinge, and I destroyed the old one getting it out. Major pain in the ***. This will save someone a headache down the road for sure!
12th Gen Bluetooth * Intravee II, Alpine KCA-420i, Alpine TUA-T550 HD Radio * Alpine SPX-17 REF 6.5" F & SPS-500 5.25" R Speakers * OEM Sirius * JL Audio XD600/6 6 Channel Amp(DSP Removed) * Audio Control DQXS * Custom ED Sub Box with 2 x SQ10's * Infinity 611a Sub Amp * Dinan Exhaust * Powerchip MAF-less tune * E60 SSK * ZHP Illuminated Shift Knob * Jet Black Rear Valance * Headlight Armor light smoke tinted tails * 18x10 SSR GT3 wheels F&R * Euro Hella Headlights * Predator Ice AE's with 5W Luxeon K2 Star and 1000 mA PowerPuck Driver * Seasonal OEM Heated Steering Wheel Retrofit * F & R Illuminated Door Sills * Ultimate Pedals * Full Interior LED's * 6000K HID Fogs * MKIV Nav * Passport 9500ci * Griots Italian Air Horn * Slimm's leather tilting armrest * Dinan Stage 1 Suspension *...
27th April 2010, 01:34
#4
2003 ///M5
Ok ok sank you sank you, pedal master!
27th April 2010, 01:39
#5
2001 M5 Jet Black
hahaha and the thanks pour in
you guys are the best
16th May 2010, 02:41
#6
Thanks Drew, I was in the process of replacing my old aluminum padals that had warn down over the years and remembered the trouble I had installing of the accelerator. The first time I did not remove it because I could not figure it out, so I did a search on the board this time and found this posting you did. Thanks, saved me a lot of time.
Evolve Alpha-N Stage 3 Tune, Evolve Medusa Headers & 200 Cell Cats, Bilstein PSS9 Coilover Suspension, StopTech Brake Upgrade, E60 SSk w/ZHP Knob, Slimmbones Open Lower Grill with Open Brake Ducts, Umnitza Projector 30 with Predator Orion V2 LED Angel Eyes, Eihach Front and Rear Anti Sway Bars, SuperSprint Exhaust, X-Pipe, 19" BBS LM's, CAI, ACS Splitters, Icelink iPod, Valentine V1 Hardwired, Ultimate Pedals.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
