E39 M5 - DIY for Dummies - BMW M5 Forum and M6 Forums
Like Tree13Likes
Old 3rd January 2010, 23:34   #1
russap5
russap5's Avatar
Garage: 2001 M5 Jet Black
After getting frustrated with my front cup holder and ripping it out in multiple pieces I feel creative.
E39 M5 - DIY for Dummies:
1) Always work in low light environments
2) When working on electrical components, never disconnect the battery or you will lose your date and time information
3) If the part doesn't want to come out, just pull harder
3b) BMW parts are always strong, especially the plastic, so don't worry about breaking them
4) Simple leaks can be easily fixed with the application of Duct Tape
4b) Recommend electrical tape for VANOS leaks
5) Never use the fluids recommended by the dealer, they just want to overcharge you
6) Torque figures for bolts are just suggestions
7) MAFs never need replacing
8) Try using flat-head screwdrivers on philips head screws, vice versa
9) No need to put the parking brake on when jacking up your car, friction will hold it in place
10) Any mods will void your warranty
Feel free to add!
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan
CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan
Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler,
Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
russap5 is offline   Reply With Quote
Old 3rd January 2010, 23:43   #2
Essixtytwo
Essixtytwo's Avatar
Garage: 1998 E39 M5 Carbonblack
11. Electronics work on smoke. If it comes out, it doesn't work anymore.
Le Garage:
1998 E39 M5 (yes, that's right, going EXTREMELY strong and ZERO oil/rattle issues), Carbon Black/Caramel Full/Alcantara.
1985 E28 525i, Alpine White/Pacific, 12 yrs of ownership, DD during winter, most reliable car ever.
Essixtytwo is offline   Reply With Quote
The Following User Says Thank You to Essixtytwo For This Useful Post:
Diny (3rd January 2010)
Old 3rd January 2010, 23:44   #3
Neil.D
Neil.D's Avatar
Garage: E39 M5 - Titanium Silver
12) Always work with hot engine fluids - they will come out easier
2000 M5 Titanium silver
Neil.D is offline   Reply With Quote
Old 4th January 2010, 00:00   #4
CarbonCopy
CarbonCopy's Avatar
Garage: 2001 M5 Carbonblack/caramel
13) Feel free to balance any loose screws or bolts on any available sort-of-horizontal surface. If you loose one the other 7 will most likely hold the item in place.
CarbonCopy is offline   Reply With Quote
The Following User Says Thank You to CarbonCopy For This Useful Post:
ganesht (4th January 2010)
Old 4th January 2010, 00:01   #5
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
14. Don't consult the TIS before trying to remove an integral part of your engine. The TIS is for nerds.
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Old 4th January 2010, 00:02   #6
Mfreakin5
Mfreakin5's Avatar
15. Always wear flip-flops when swapping an engine in your home, dimly lit garage. (Raza )
Old 4th January 2010, 00:05   #7
Clemster
Garage: 2010 E90 M3 Alpine White/Fox Red
Sales Feedback: (26)
16. Feel free to dump the clutch at will, especially with a newly installed supercharger. It's bulletproof!
Clemster is offline   Reply With Quote
Old 4th January 2010, 00:18   #8
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
17) Don't use a torque wrench on your oil pan drain bolt. It can't be stripped no matter how hard you crank it down!
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
Old 4th January 2010, 01:24   #9
5PEEDY
5PEEDY's Avatar
18) If you cannot use a hammer you have an electrical problem.
5PEEDY is offline   Reply With Quote
The Following 4 Users Say Thank You to 5PEEDY For This Useful Post:
ganesht (4th January 2010), Mfreakin5 (4th January 2010), russap5 (4th January 2010), TMcNasty (4th January 2010)
Old 4th January 2010, 01:46   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
19. No need to ever add or change oil, it is a lifetime fluid!
DIY - Is replacing a rear seat belt recepticle DIY? M5VRICK E39 M5 and E52 Z8 Discussion 4 4th August 2009 17:55
NavTweak for dummies? ECB E39 M5 and E52 Z8 Discussion 30 10th August 2008 01:14
DIY E39 M5 headers GT2 Evo E39 M5 and E52 Z8 Discussion 39 1st June 2006 17:10
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 00:46
Coilovers for dummies: 2003 M5!!! E39 M5 and E52 Z8 Discussion 22 23rd March 2005 13:06
