BOM:
·<FONT size=3> 1 – 51.71.2.694.217 Left (bank2) Firewall Cover<B><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
http://www.ecstuning.com/BMW-E39-M5s62_5.0L/Search/SiteSearch/51712694217/ES128289/<o
></o
· 1 - 51.71.2.694.218 Right (bank1) Firewall Cover<o
></o
o 03 CENTRE ENGINE COMPARTMENT CLOSING PANEL RECHTS 1 51712694218 $37.17<o
></o
o http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/Search/SiteSearch/51712694218/ES128290/<o
></o
· 5 – 51.71.8.204.904 Lock<o
></o
o 02 Lock 4 51718204904 $0.65 (There are 5 not 4. Three for the left cover and two for the right).<o
></o
o http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/Search/SiteSearch/51718204904/ES129774/<o
></o
· 3 – 61.13.1.925.120 Clamp<o
></o
o 11 Clamp 3 61131925120 $0.32<o
></o
o http://www.ecstuning.com/Search/SiteSearch/61131925120/ES264768/
<o
></o
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2292&hg=51&fg=80&hl=11
<o
></o
· Total Parts Cost - $78.55 List (realOEM.com 11/30/2013)<o
></o
· Total Time <1hr.
<o
></o
Removal:<o
></o
1. Remove the right side (bank1) and left side (bank2) Cabin Filter covers<o
></o
a. RIGHT MICROFILTER SERVICE COVER 1 04/1998 64318379626 $27.50<o
></o
b. LEFT MICROFILTER SERVICE COVER 1 04/1998 64318379627 $27.50
<o
</o
2. Remove the right, left side and center cabin filter and windshield weather seals<o
></o
a. 28 Sealing windshield panel 1 03/1998 51718238595 $10.84<o
></o
b. 29 seal, microfine filter housing left 1 03/1998 51718238599 $21.68<o
></o
c. 30 seal, microfine filter housing right 1 03/1998 51718238600 $21.68<o
></o
3. Remove the right and left cabin filter boxes (left side remember to disconnect the Hood Switch).<o
></o
a. 03 HOUSING LOWER PART MICROFILTER RIGHT 1 04/1998 64318379624 $83.68 <o
></o
b. 03 HOUSING LOWER PART LEFT MICROFILTER 1 04/1998 64318379625 $83.68
4. Remove the right and left Air Channels<o
></o
a. 07 RIGHT MICROFILTER AIR CHANNEL 1 04/1998 64318379620 $66.08<o
></o
b. 07 LEFT MICROFILTER AIR CHANNEL 1 04/1998 64318379621 $66.08
<o
</o
<o
</o
5. Right side cover must be removed first, turn both of the locks ½ turn (either direction) so that the lock’s tab is parallel to the ground (horizontal). This will release the lock.<o
></o
a. Remove the locks by bulling straight forward (towards front of vehicle).<o
></o
b. Using a small flat screwdriver remove the clamp between the windshield cowl and the right side firewall cover<o
></o
c. Remove the right side cover
<o
</o
<o
</o
6. Left side cover turn the three locks ½ turn (either direction) so that the lock’s tab is parallel to the ground (horizontal). This will release the lock. 1 lock is directly behind the engine harness. You will need to remove the harness from the cover and push it out of the way to gain access to the third lock<o
></o
></o
b. Using a small flat screwdriver remove the two clamps between the windshield cowl and the left side firewall cover<o
></o
c. Remove the left side cover
<o
</o
<o
</o
Installation:<o
></o
1. Install the Left cover<o
></o
a. Insert the lock in the three holes and fasten by turning the locks ½ turn so that the tabs are perpendicular (vertical) to the ground.<o
></o
b. With the cover and the three locks in place re-install the two clamps between the left cover and the windshield cowl.
c. Replace the Engine Harness into the cavity in the Left side Firewall Cover.
<o
</o
<o
</o
<o
</o
2. Install the Right cover<o
></o
a. Insert the lock in the two holes and fasten by turning the locks ½ turn so that the tabs are perpendicular (vertical) to the ground.<o
></o
b. With the cover and the two locks in place re-install the clamp between the right cover and the windshield cowl.
<o
</o
<o
</o
<o
</o
3. Check that the harness is properly positioned and that all 5 locks are secure.<o
></o
4. Install the right and left Air Channels.<o
></o
5. Install the right and left Cabin Filter boxes.<o
></o
a. Reconnect the Hood Switch.<o
></o
6. Install the Windshield weather seal.
7. Install the right and left Cabin Filer weather seals.<o
></o
8. Install the left and right Cabin Filter Covers. <o
></o
9. Remove shop light and any tools.
<o
</o
10. Close the Hood.<o
></o
11. Find a Beer. :beerglass:<o
></o
· Links<o
></o
Cabin Filter<o
></o
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=64_0673&hg=64&fg=10<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379626/ES179026/<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379627/ES179027/<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379624/ES179024/<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379625/ES179025/<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379620/ES179022/<o
></o
http://www.ecstuning.com/Search/SiteSearch/64318379621/ES179023/<o
></o
<o
></o
Seals<o
></o
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=41_0057&hg=41&fg=35<o
></o
http://www.ecstuning.com/Search/SiteSearch/51718238595/ES129986/<o
></o
http://www.ecstuning.com/Search/SiteSearch/51718238599/ES129987/<o
></o
http://www.ecstuning.com/Search/SiteSearch/51718238600/ES129988/<o
></o
<o
></o
Firewall Covers <o
></o
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2292&hg=51&fg=80&hl=11<o
></o
></o
></o
></o
http://realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2258&hg=51&fg=20<o
></o
http://www.ecstuning.com/Search/SiteSearch/61131925120/ES264768/<o
></o
<o
<o
· Total Time <1hr.
<o
Removal:<o
<o
<o
<o
<o
<o
<o
<o
Installation:<o
<o
<o
<o
<o
<o
<o
<o
· Links<o
Cabin Filter<o
<o
Seals<o
<o
Firewall Covers <o
