:greenflag:
<FONT size=3><SPAN style="FONT-FAMILY: 'Calibri','sans-serif'; COLOR: black">BOM:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
1. 1 – BMW BM53 New Generation Radio P/N: 65126988275<o></o>
2. 1 – BMW ANT ADAPTER P/N: 61126913955<o></o>
3. 1 – BMW RADIO HARNESS P/N: 61126913957<o></o>
4. 1 – BMW CDC ADAPTER P/N: 61126924785<o></o>
5. 1 – BMW CONNECTION CABLE CD-CHANGER (550mm) P/N: 65128364756<o></o>
6. 1 – BMW Sirius Installation Kit P/N: 84110141975<o></o>
7. 1 – BMW Sirius Receiver (tuner) P/N: 65120439437
8. 1 – BMW CDC Slave Cable P/N: 84110150526
9. 1 – Sirius / XM Antenna (with FAKRA SMB connection)
<o></o>
Tools:
8mm short 1/4 drive socket<o></o>
1/4 drive extentions<o></o>
1/4 drivers (rachet and nut driver handle)<o></o>
Trim removal tool<o></o>
#2 phillips screw driver<o></o>
<o></o>
<o></o>
Removal:
1.Remove the left rear trunk trim.<o></o>
2.Loosen the two screws on the side of the CD auto-changer (side facing front if vehicle).<o></o>
a.Remove and disconnect the CDC.
<o> </o>
3.Loosen the (3) bolts between the bottom of the CDC rear (vehicle) bracket and remove (1) bolt at the top of the C43 radio.<o></o>
a.Remove the bracket.<o></o>
4.Loosen the (3) bolts between the front CDC bracket.<o></o>
a.Remove the (1) bolt between the front CDC bracket and the floor.<o></o>
5.Disconnect the Antenna and coaxial cables from the C43.<o></o>
6.Disconnect the electrical connector from the C43 radio<o></o>
7.Remove the radio.
<o></o>
Installation:<o></o>
1.Install the CDC audio cable to the vehicle harness (BMW CONNECTION CABLE CD-CHANGER (550mm) P/N: 65128364756).<o></o>
a.To facilitate this you will need to remove the blue CPA (Connector Position Assurance)<o></o>
b.Insert the CDC cable in the blank cavity across from the Nav./tape audio input<o></o>
c.Replace the blue CPA<o></o>
2.Connect the Old to New Radio adapter (BMW RADIO HARNESS P/N: 61126913957) to the vehicle harness.<o></o>
3.Install the CDC Adapter Cable (BMW CDC ADAPTER P/N: 61126924785)<o></o>
a.Insert the black and white connectors from the CDC Adapter into the cavities of the New Generation Radio side of the Radio Adapter.<o></o>
4.Install the BM53 radio<o></o>
5.Connect the harness to the BM53 radio.<o></o>
6.Attach the antenna adapter to the vehicle antenna cable (BMW ANT ADAPTER P/N: 61126913955).<o></o>
a.Attach the Antenna to the BM53.<o></o>
7.Mount the Sirius tuner to the bracket (84110141975)<o></o>
8.Install the Sirius Tuner<o></o>
9.Replace the CDC rear bracket<o></o>
10.Route the CDC Cable (P/N: 65128364756) to the mating connector on the Sirius tuner.<o></o>
11.Route the I-bus (3-pin) connector from the CDC to the mating connector on the Sirius tuner.<o></o>
a. Left to right (Sirius antenna, Slave Cable, CDC Cable, I-bus (blank - had not been connected when Pic' was taken)<o></o>
12.Replace and snug (lose enough to allow small movement) all bracket fasteners.<o></o>
13.Check the fitment of all components for binding and misalignment including the CDC.<o></o>
a.When final fitment is correct, remove the CDC and tighten the bracket fasteners.<o></o>
14.Remove the slave cable connector cover from the Sirius tuner.<o></o>
a.Attach the CDC slave cable (P/N: 84110150526) to the Sirius tuner.
<o> </o>
b.Attach the CDC slave cable to the CDC.<o></o>
15.Replace the CDC<o></o>
16.Mount the Satellite antenna (your preference).
<o> </o>
a.Mine is on the parcel shelf on top of the cover for the center LATCH (child seat anchor).<o></o>
b.Route the antenna cable to the Sirius tuner or splitter (as required).<o></o>
c.Attach the antenna (splitter as applicable) to the Sirius tuner.<o></o>
17.Replace the left rear trunk trim.<o></o>
18.Turn the radio “on”.<o></o>
19.Press the “mode” button until Sirius is displayed Nav. Display (Mk-IV).<o></o>
a.“No Tape” (2<SUP>nd</SUP> time) Nav. Display (Mk-III) and Sirius channel on OBC.<o></o>
(Yes, the pixels have since been repaired.)
b.If you have Mk-III write down the ESN on the Sirius tuner’s label.<o></o>
c.Make sure that the Sirius preview channel is playing on the radio.<o></o>
i.If not relocate the antenna or vehicle such that the audio is being received.<o></o>
20.Call Sirius to activate the tuner. (1-866-635-2349).<o></o>
21.Rock out with your bad self.
:checkeredflag::applause::woowoo:
<o></o>
Tools:
<o></o>
<o></o>
Removal:
<o> </o>
7.Remove the radio.
<o></o>
<o> </o>
<o> </o>
