As my “Beast” came with the C43 radio it did not have the vehicle harness for the Aux Input which is supported by the BM53 radio. As the next tribute to be paid to the Beast is the BM53 radio, I took the opportunity to build and fit a harness to the vehicle to support the Aux Input facility after the new radio is fitted.
Material:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
18-20’ - Mil-W-16878 STJ Type E 20AWG (0.5mm<SUP>2</SUP>) 4 conductor 19/32 strand silver plated copper, PTFE insulated, Silver-copper braided shield, PTFE tape jacket.<o></o>
6 – Tyco Connectivity Terminals – P/N: 962885-5<o></o>
1 - Male three pole connector – P/N: 61138377072<o></o>
10 – Black nylon wire ties<o></o>
2 – 2” (50.0mm) adhesive lined shrink tube<o></o>
1 – BMW Aux Input cable P/N: 65120153503 for S609A<o></o>
1 – BMW BM53 New Generation Radio P/N: 65126988275<o></o>
1 – BMW ANT ADAPTER P/N: 61126913955<o></o>
1 – BMW RADIO HARNESS P/N: 61126913957<o></o>
1 – BMW CDC ADAPTER P/N: 61126924785<o></o>
1 – BMW CONNECTION CABLE CD-CHANGER (550mm) P/N: 65128364756<o></o>
2 – Gallons of sweat<o></o>
1 – Giant PITA<o></o>
Tools:<o></o>
X-Acto Knife<o></o>
Ultra-fine wire cutters<o></o>
Heat gun<o></o>
Hot tweezers<o></o>
Crimp tool (GT-150 die for un-insulated terminals)<o></o>
Phillips head #2 screw driver – Stubby, and standard<o></o>
10mm short ¼ square drive socket<o></o>
8mm short ¼ square drive socket<o></o>
7mm short ¼ square drive socket<o></o>
4” ¼ drive extension<o></o>
¼ Ratchet<o></o>
¼ Nut driver handle<o></o>
Curved Kelly Clamp<o></o>
45° long forceps<o></o>
DIY<o></o>
Harness:<o></o>
1- Using the X-Acto knife remove the jacket and a ultra-fine pair of wire cutters trim the shield and the remnants of the jacket from each end of the Mil-W16878 cable, approximately 3” (75.0mm) at one end (head unit) and 6” (150.0mm) at the other end (radio).<o></o>
<o></o>
<o></o>
2- Place one piece of the shrink tube on each end of the cable such that the termination of the jacket and shield is covered and approximately ½” (13.0mm) of the exposed conductors. Using the heat gun heat the shrink tube until the adhesive flows.
3- Using the hot tweezers remove 1/8 (3.5mm) of the insulation from each of the conductors
4- Crimp the Tyco terminals to the conductors
5- Install the male connector to the head unit end of the harness
Harness Retro-fit:
<o></o>
Remove:<o></o>
1- Set driver’s preferred memory settings<o></o>
a. Record Radio preset stations and DSP settings (if equipped)<o></o>
b. Open door windows<o></o>
2- Disconnect Battery Ground Cable<o></o>
3- Left side boot trim<o></o>
4- CD Changer (if equipped) (2 screws)<o></o>
5- Radio Module (4 screws)<o></o>
6- Rear seat bench<o></o>
7- Rear center headrest (lift straight up)<o></o>
8- Raise outboard rear headrests to upper most position<o></o>
9- Rear seat back lower fasteners (2 screws)<o></o>
10- Rear Seat back (lift up)<o></o>
11- Tray and rear HVAC vent<o></o>
12- Center console arm rest (2 screws)<o></o>
13- Park Brake boot<o></o>
14- Shifter bezel<o></o>
15- Hazard switch (push up from underneath; accessed from under shifter boot)<o></o>
16- Center console insert (5 screws)<o></o>
17- Navigation head unit (4 screws)<o></o>
18- Automatic Air Conditioning Control unit<o></o>
19- Seat heater control unit<o></o>
20- Cup holder (2 screws)<o></o>
21- Cigarette lighter and tray assembly (2 screws)<o></o>
22- Center stack control module frame (4 screws)<o></o>
23- Left and right center console trim panels (1 screw each side)<o></o>
24- Center console (12 screws)
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o>Fitment:</o>
<o></o>
<o><o></o>
1- Lift the rear carpet to allow the radio end of the harness to be fed under the carpet towards the left rear seat from the left side of the airbag module.
2- Pull the harness through to the rear; leaving approximately 4’ (1.3m) to be routed through to center stack behind the Navigation Head Unit .
3- Route the head unit end of the harness forward around the parking brake and up the left side of the center stack.
a. Secure the harness along the route with wire ties.
4- Route the radio end of the harness along the existing harnesses and through the lower left side grommet into the boot.
5- Continue routing the aux input harness in the boot along the existing harness to the radio/electronics bay
a. Secure the harness with wire ties as required (typically where the harness changes direction)
6- Connect the Left audio input terminal to socket 3 of the X13649 connector (black connector of BMW CDC ADAPTER P/N: 61126924785)
7- Connect the Right audio input terminal to socket 4 of the X13649 connector (black connector of BMW CDC ADAPTER P/N: 61126924785)
8- Connect the audio input ground terminal to socket 10 of the X13649 connector(black connector of BMW CDC ADAPTER P/N: 61126924785)
a. Thanks… B Jack at the M5 Board http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/191687-car-stereo-experts-please-help.html
9- Install the BMW Aux Input facility per direction (01290153504) or at a location of your preference.
<o> </o>
<o></o>
<o> </o>
<o></o>
<o><o>10- Reinstall all components removed during the removal portion of this DIY in reverse order.<o></o>
</o>
</o><o>11- Reconnect Battery Ground Cable</o>
<o>a. Set Driver’s Memory</o>
<o>12- Verify proper function.</o>
<o></o>
<o></o>
<o></o>
<o></o></o>
</SPAN>
Tools:<o></o>
X-Acto Knife<o></o>
Heat gun<o></o>
Hot tweezers<o></o>
¼ Ratchet<o></o>
DIY<o></o>
Harness:<o></o>
<o></o>
<o></o>
Harness Retro-fit:
<o></o>
Remove:<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o>Fitment:</o>
<o></o>
<o><o></o>
<o> </o>
<o></o>
<o> </o>
<o></o>
</o>
<o></o>
<o></o>
<o></o>
<o></o></o>
</SPAN>
