Just did the update last night. Its an easy procedure, but after reading all I could on the topic it was very confusing because of all the multiple systems that were talked about.
This is specifically for a MK IV system and might take an hour from the time you read this and download to the time the install is done.
Background: I have a 2000 M5, upgraded the nav unit from MK II to Mk IV, and installed a widescreen 16:9 unit.
- First download the V31 updated software (save to desktop)- RapidShare: Easy Filehosting This is a Zip file.
- Download and install ImgBurn software. Its shareware and can be used for free. Do a Google search and download from the original site.
- Unzip the V31 file. In win systems, double click and extract to the desktop (or where ever you want). It should extract a .BIN, .TOC, and .CUE file. These are compressed files that ImgBurn will write to a CD.
- Open up ImgBurn and put a blank CD (yes, your Mk IV reads CDs) in your drive. I used a Sony data disk and it worked the first time.
- You want to "Write an Image file to Disk"
- Set the write speed to 1x
- and be sure to check "Verify". These are all important steps!
- Select the .CUE file and then burn the CD. It will extract a long list of files
and I think 13 folders, so you will know if youve done it right up to this
point. Make sure to "Verify" the CD to make sure there are no errors.
This is from a service bulletin.
- Go out to your car.
- Ignition to "1"
- Select "GPS Nav"
- Remove Map DVD in trunk
- Insert V31 software CD
- After a delay (a min?) you should get a screen saying something like
"updating software" and a progress bar.
- When its done it will put a new screen up "Software successfully loaded"
- Remove CD
- Confirm update by pushing "OK" with the right button.
- Reinsert your map DVD
- Done. Enjoy.
Useful Links:
- Version info from the X5 guys: BMW Navigation System FAQ - X5world
- Service Information Bulletin:X5world - View Single Post - Navigation V31 SIB
- Somewhat useful discussion on the update. Not the same V31 link. Mine is a .ZIP file. I dont know where I found it, but I like ZIP files better than .NRG or what ever: V31 has been released and is now available - X5world
- This is also a good thread on the update and how to load a custom splash screen: http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/118126-v31-custom-nav-files.html
Some Notes on Nav System/Widescreen Upgrade:
- Although the M5 and X5 widescreen, nav unit, and trim ring all look the same there are subtle differences. (Ask how I know).
- If you buy a used MK IV there is at least one difference between a M5 and X5 unit. You can tell if its a X5 because you wont have an "Arrival Time". Also, getting into the hidden menu items, one of the settings, Telematics, will show X5. Check this by going to "settings" then hold the menu button down for 20-30 sec. Its in there somewhere. Someone posted a fix, but not easy. Requires dealer, or a software and hardware hack. Do a search for "No arrival Time" on this board (or the X5 Board. Sorry I cant remember. Ive done a lot of homework).
- The 16:9 screen comes in a M5 and X5 (maybe others) flavors, even though both fit and will work. Try to get one for your type of car. Some differences in the "tilt" of the screen. If you get the wrong one, it still works and can be tweeked for your car.
Check out this thread: http://www.m5board.com/vbulletin/e3.../vbulletin/e39-m5-e52-z8-discussion/69094-16-9-widescreen-not-same-x5s-m5s.html
- Definitely a difference in the M5 and X5 trim ring bezel for the wide screen. The X5 screen trim ring is about 4mm taller that the M5 trim. Wont work. $120 at dealer, $40 on ebay.
Overall, a very cool and relatively easy upgrade.
Good luck
Sam
:cheers:
- Ignition to "1"
- Select "GPS Nav"
- Remove CD
- Done. Enjoy.
Useful Links:
Good luck
Sam
:cheers:
