After rebuilding my friend's 1999 S62 following the not uncommon problem of a bearing and big end conrod failure we are not able to diagnose an engine vibration which kicks in at 1200rpm. The following are our best guesses in order of our opinion of most likely cause:
1. Unbalanced flywheel/new pressure plate (just removed and balanced and replaced with no effect on vibration)
2. Engine mount problem (checked and not apparently the cause of vibration)
3. Throttle body balance (not yet performed due to unavailability of balancing tool - not even the dealer has one)
4. Con rod imbalance (not likely as new con rod was matched for weight with other 7)
5. Running out of ideas - anyone have any suggestions?
Note that the rebuild was done professionally and engine runs very smoothly at idle and otherwise EXCEPT for the 1200 - 1500 rpm vibration which tend to carry over into throttle over-run suggeting possibility that it is NOT a throttle body balance issue.
Also engine has more power and runs better than before the rebuild.
Look forward to the board's vast experience to solve this one.
Whammy:1zhelp:
Whammy:1zhelp:
