41 - 55 of 55 Posts
Yeah that's the proper termination for the K-can. Take a look at the arduino sketch here.
https://github.com/pavelmalik/BMWCanBridge
Let me guess, you wanna tie exhaust cut outs into the m-mode? :)
Thanks for the very quick reply!
Yup... you're spot on - I want to do as rt7085 did and have an M-mode and RPM dependent exhaust valve operation. My current setup is conveniently operated from my Homelink buttons on my rear view mirror, however I want some more smarts around the switching (mostly just for the fun of tinkering, to be honest).
Thanks for the link to your code! It looks like you are using the Due, which I believe has can bus built in? I will be using a Nano + MC2515 module, but I think I shall be able to use some elements of your code.
This is my first foray into Arduino, so perhaps I am trying to run before I can walk.
Hi all,
Basically, I want my exhaust to operate as follows:
When M-mode is off, exhaust will remain closed (quiet), but open (loud) when RPM>4000 & throttle>50%
When M-mode is on, exhaust will remain open (loud) under all conditions
I have been able to sniff the K-Can using the Arduino Nano + MCP2515 combination without too much trouble. I am able to determine RPM from the ArbID 0xAA and M-Mode from 0x399 as suggested, however I would also like to determine throttle (pedal) position.
I am determining statuses as follows:
M-Mode by testing for the value of byte 1 (byte[1] = 81 then M-drive is off, if byte[1] = 82 then M-drive is on) on ArbID 0x399
RPM by calculating (byte[5]*256+byte(4))/4 of ArbID 0xAA
According to the amazing work on this site CAN BUS Codes, I should be able to calculate the throttle position from bytes 2 and 3 of ArbID 0xAA, however I am not able to determine the correct transfer function.
Does anyone have any hints as to how to determine throttle position?
I shall post up by Arduino sketch here once I have it all completed for others to use.
Discussion starter · #43 ·
Hi all,
I have been able to sniff the K-Can using the Arduino Nano + MCP2515 combination without too much trouble. I am able to determine RPM from the ArbID 0xAA and M-Mode from 0x299 as suggested, however I would also like to determine throttle (pedal) position.
throttle pedal for other modules is:
ArbID 0xAA
byte 3
bit 0-3
Pedal % = hex * 0.39063
ArbID 0xAA
byte 3
bit 0-3
Thank you very much Jim.
I was calculating it using Pedal % = (byte[3]*256+byte[2])/(256^2), as according to the loopybunny site the throttle was spread across a highbyte/lowbyte.
I shall try your method instead, which is mathematically equivalent to the above formula when ignoring byte 2.
Hello all,
I have finished compiling some code to sniff the K-CAN and switch the exhaust under the conditions described.
I used the MCP2515 can bus module library and example code from this source: https://github.com/autowp/arduino-mcp2515#library-installation
as it is a bit more flexible than the SparkFun sketch; the MCP2515 module I have has a 8MHz oscillator, unlike the SparkFun shield, which uses a 16 MHz oscillator.
Please note, my code should be considered beta, as I am yet to road test it. I have only confirmed its operation using a CAN emulator.
<spi.h><mcp2515.h><canmsg.can_dlc; i++)="" {="" print="" the="" data
</canmsg.can_dlc;></mcp2515.h></spi.h></canmsg.can_dlc;></mcp2515.h></spi.h>
Update: I have road tested my configuration and code and it works exactly as intended. I am very happy with the outcome!
For those who are interested in adding a third mode (perhaps switching more aggressively i.e. at a lower RPM and throttle threshold), the ArbID for the P400/500 mode is 0x315 . Surprisingly the status is not broadcast by the DME, but rather the center console module (SZM).
The status is available on byte[2], which is F1 in hex (241 in dec) when in P400 and FA in hex (250 in dec) when in P500.
Edit: I tried triggering off 0x315 on my car without success. With M-Mode off, it would broadcasting of byte[2] as F2 regardless of the status of the Power button, and would shift to FA when in M-Mode (I assume this means P500s).
This is really strange, as I am expecting to see a third status when in P400 mode.
Any idea?
Does anyone know if it is possible to read the Power (P400/500) mode on the K-Can, or is this information only communicated on the PT-Can?
As per my previous post, I am not able to read this state from the 0x315 ArbID on the K-Can.
I posted this on bimmerforums, but you guys will probably find it helpful too. Found it while digging through tool32
Code:
CAN_ID_HEX    CAN_ID_NAME    CAN_ID_NAME (Translated)    DIAG_ID_HEX    SG_NAME
0x00    unbekannt    unknown    0x00    Sender unbekannt
0xA8    Drehmoment 1 K-CAN [10]    Torque 1 K-CAN [10]    0x12    DME1/DDE1
0xA9    Drehmoment 2 (10)    Torque 2 (10)    0x12    DME1/DDE1
0xAA    Drehmoment 3 K-CAN [10]    Torque 3 K-CAN [10]    0x12    DME1/DDE1
0xAC    Radmoment Antriebsstrang 2 [5]    Wheel torque Drive train 2 [5]    0x12    DME1/DDE1
0xAD    Verzögerungsanforderung ACC [9]    Delay request ACC [9]    0x1C    LDM
0xAD    Verzögerungsanforderung ACC [9]    Delay request ACC [9]    0x21    ACC_Modul/ACC+NAVI
0xB3    Steuerung LenkunterstĂĽtzung [2]    Steering assistance steering [2]    0x16    AFS
0xB4    Radmoment Antriebsstrang 1 [4]    Wheel torque Drive train 1 [4]    0x12    DME1/DDE1
0xB5    Drehmomentanforderung EGS [9]    Torque demand EGS [9]    0x18    EGS_MECH+NAVI/EGS_MECH
0xB6    Drehmomentanforderung DSC [7]    Torque demand DSC [7]    0x29    DXC_RB/DSC_RB/DSC_CT
0xB7    Drehmomentanforderung ACC [10]    Torque demand ACC [10]    0x1C    LDM
0xB7    Drehmomentanforderung ACC [10]    Torque demand ACC [10]    0x21    ACC_Modul/ACC+NAVI
0xB8    Drehmomentanforderung DKG [2]    Torque requirement DKG [2]    0x18    DKG
0xB9    Drehmomentanforderung AFS [3]    Torque demand AFS [3]    0x16    AFS
0xBA    Getriebedaten [20]    Transmission data [20]    0x18    SMG_M/SMG/EGS_MECH+NAVI/EGS_MECH/DKG
0xBB    Sollmomentanforderung [7]    Required torque request [7]    0x29    DXC_RB
0xBC    Status Sollmomentumsetzung [7]    Status setpoint torque conversion [7]    0x19    VGSG
0xBD    Drehmomentanforderung SSG [6]    Torque demand SSG [6]    0x18    SMG_M/SMG
0xBE    Alive Zähler [12]    Alive counters [12]    0x23    ARS_Modul
0xBF    Anforderung Radmoment Antriebsstrang [6]    Requirement wheel torque Drive train [6]    0x1C    LDM
0xC0    Alive Zentrales Gateway [1]    Alive Central Gateway [1]    0x0    KGM
0xC1    Alive Zähler Telefon [3]    Alive counter phone [3]    0x36    TEL_JAP/TEL_BPI
0xC4    Lenkradwinkel K-CAN [13]    Steering wheel angle K-CAN [13]    0x29    DXC_RB/DSC_RB/DSC_CT
0xC8    Lenkradwinkel Oben K-CAN [6]    Steering wheel angle Top K-CAN [6]    0x2    SZL_LWS
0xCE    Radgeschwindigkeit K-CAN [4]    Wheel speed K-CAN [4]    0x29    DXC_RB/DSC_RB/DSC_CT
0xD2    Bedienung Sitzverstellung BF [6]    Operation Seat adjustment BF [6]    0x65    SZM_MIT_KBUS/SZM
0xD5    Anforderung Radmoment Bremse [6]    Wheel torque brake requirement [6]    0x1C    LDM
0xD7    Alive Zähler Sicherheit [2]    Alive counter security [2]    0x1    ACSM
0xDA    Bedienung Sitzverstellung FA [6]    Operation Seat adjustment FA [6]    0x65    SZM_MIT_KBUS/SZM
0xE1    Radmoment Bremse [3]    Wheel torque brake [3]    0x29    DXC_RB/DSC_RB
0xE2    Status Zentralverriegelung BFT [11]    Status Central locking system BFT [11]    0x0    KGM
0xE6    Status Zentralverriegelung BFTH [11]    Status Central locking BFTH [11]    0x72    KBM
0xEA    Status Zentralverriegelung FAT [11]    Status Central locking FAT [11]    0x0    KGM
0xEE    Status Zentralverriegelung FATH [11]    Status Central locking FATH [11]    0x72    KBM
0xF2    Status Zentralverriegelung HK [13]    Status Central locking HK [13]    0x72    KBM
0xF6    Steuerung AuĂźenspiegel [9]    Steering wheel mirrors [9]    0x0    KGM
0xFA    Steuerung Fensterheber FAT [10]    Control window lifters FAT [10]    0x0    KGM
0xFB    Steuerung Fensterheber BFT [5]    Control window lifters BFT [5]    0x0    KGM
0xFC    Steuerung Fensterheber FATH [5]    FATH Control Window Regulators [5]    0x72    KBM
0xFD    Steuerung Fensterheber BFTH [5]    Control window lifters BFTH [5]    0x72    KBM
0x130    Klemmenstatus [19]    Terminal status [19]    0x40    CAS
0x135    Steuerung Crashabschaltung EKP [1]    Control Crash Disconnection EKP [1]    0x1    ACSM
0x15F    Anforderung Winkel FFP [6]    Request angle FFP [6]    0x1C    LDM
0x172    Quittierung Anforderung Kombi [1]    Acknowledgment request Combi [1]    0x62    M_ASK/CCC_GW
0x190    Anzeige ACC [13]    Display ACC [13]    0x1C    LDM
0x190    Anzeige ACC [13]    Display ACC [13]    0x21    ACC_Modul/ACC+NAVI
0x192    Bedienung Getriebewahlschalter [16]    Operation Gear selector switch [16]    0x2    SZL_LWS
0x193    Anzeige ACC DCC [4]    Display ACC DCC [4]    0x1C    LDM
0x194    Bedienung Tempomat/ACC [13]    Operation Tempomat / ACC [13]    0x2    SZL_LWS
0x198    Bedienung Getriebewahlschalter 2 [2]    Operation Gear selector switch 2 [2]    0x5E    GWS
0x19E    Status DSC K-CAN [19]    Status DSC K-CAN [19]    0x29    DXC_RB/DSC_RB/DSC_CT
0x1A0    Geschwindigkeit K-CAN [14]    Speed K-CAN [14]    0x29    DXC_RB/DSC_RB/DSC_CT
0x1A2    Getriebedaten 2 [6]    Transmission data 2 [6]    0x18    EGS_MECH+NAVI/EGS_MECH/DKG
0x1A3    Rohdaten Längsbeschleunigung [3]    Raw data longitudinal acceleration [3]    0x18    SMG_M
0x1A6    Wegstrecke [6]    Distance [6]    0x29    DXC_RB/DSC_RB/DSC_CT
0x1AA    Effekt ErgoCommander [10]    Effect ErgoCommander [10]    0x62    M_ASK/CCC_GW
0x1AC    Status ARS-Modul [13]    Status ARS module [13]    0x23    ARS_Modul
0x1B4    Status Kombi [14]    Status Combine [14]    0x60    Kombi
0x1B5    Wärmestrom/Lastmoment Klima [14]    Heat flow / load moment Climate [14]    0x78    IHKA
0x1B6    Wärmestrom Motor [11]    Heat flow motor [11]    0x12    DME1/DDE1
0x1B8    Bedienung ErgoCommander [6]    Operation ErgoCommander [6]    0x67    ZBE_LO/ZBE
0x1C2    Abstandsmeldung PDC [5]    Distance indication PDC [5]    0x64    PDC
0x1C3    Abstandsmeldung 2 PDC [3]    Distance indication 2 PDC [3]    0x64    PDC
0x1C6    Akustikmeldung PDC [5]    Acoustic message PDC [5]    0x64    PDC
0x1D0    Motordaten [13]    Motor data [13]    0x12    DME1/DDE1
0x1D2    Anzeige Getriebedaten [22]    Transmission data display [22]    0x18    SMG_M/SMG/EGS_MECH+NAVI/EGS_MECH/DKG
0x1D6    Bedienung Taster Audio/Telefon [12]    Audio / phone control buttons [12]    0x2    SZL_LWS
0x1D8    Bedienung Klima Luftverteilung FA [13]    Operation Climate air distribution FA [13]    0x62    M_ASK/CCC_GW
0x1D9    Bedienung Taster M-Drive [2]    Operating buttons M-Drive [2]    0x2    SZL_LWS
0x1DA    Bedienung Klima Fernwirken [5]    Operation Climate Telecontrol [5]    0x40    CAS
0x1DC    Bedienung Schichtung Sitzheizung [1]    Operation layering Seat heating [1]    0x62    M_ASK/CCC_GW
0x1E0    Bedienung Klima Luftverteilung BF [7]    Operation Climate air distribution BF [7]    0x62    M_ASK/CCC_GW
0x1E2    Bedienung Klima Front [11]    Operation Climate Front [11]    0x62    M_ASK/CCC_GW
0x1E7    Bedienung Sitzheizung/Sitzklima FA [7]    Operation seat heating / seat climate FA [7]    0x65    SZM_MIT_KBUS/SZM
0x1E8    Bedienung Sitzheizung/Sitzklima BF [7]    Operation seat heating / seating climate BF [7]    0x65    SZM_MIT_KBUS/SZM
0x1EA    Bedienung Lenksäulenverstellung [5]    Operation Steering column adjustment [5]    0x2    SZL_LWS
0x1EB    Bedienung Aktivsitz FA [3]    Operation Active seat FA [3]    0x65    SZM_MIT_KBUS/SZM
0x1EC    Bedienung Aktivsitz BF [3]    Operation Active seat BF [3]    0x65    SZM_MIT_KBUS/SZM
0x1ED    Bedienung Lehnenbreitenverstellung Aktiv FA [2]    Operation of the backrest width adjustment active FA [2]    0x65    SZM_MIT_KBUS/SZM
0x1EE    Bedienung Lenkstockstaster [6]    Steering wheel control [6]    0x2    SZL_LWS
0x1EF    Bedienung Lehnenbreitenverstellung Aktiv BF [2]    Operation Backrest width adjustment Active BF [2]    0x65    SZM_MIT_KBUS/SZM
0x1F2    Bedienung Sitzmemory BF [3]    Operation Seat memory BF [3]    0x65    SZM_MIT_KBUS/SZM
0x1F3    Bedienung Sitzmemory FA [4]    Operation Seatmemory FA [4]    0x65    SZM_MIT_KBUS/SZM
0x1F4    Fernbedienung Sitzmemory BF [2]    Remote Control Seat Memory BF [2]    0xFF    unbekannt
0x1F6    Blinken [6]    Flashing [6]    0x70    LM
0x1FC    Status AFS [4]    Status AFS [4]    0x16    AFS
0x1FE    Crash [12]    Crash [12]    0x1    ACSM
0x200    Regelgeschwindigkeit Stufentempomat [7]    Speed regulation [7]    0x12    DME1/DDE1
0x202    Dimmung [10]    Dimming [10]    0x70    LM
0x205    Akustikanforderung Kombi [3]    Acoustic demand combination [3]    0x60    Kombi
0x206    Steuerung Anzeige Shiftlights [1]    Control Display Shiftlights [1]    0x12    DME1
0x20B    Memoryverstellung [6]    Memory adjustment [6]    0x65    SZM_MIT_KBUS
0x20B    Memoryverstellung [6]    Memory adjustment [6]    0x6D    SM_FA
0x20C    Steuerung Lenksäule (4)    Steering Column Control (4)    0x6D    SM_FA
0x20D    Position Lenksäule (5)    Position steering column (5)    0x65    SZM_MIT_KBUS/SZM
0x210    Bedienung HUD [7]    Operation HUD [7]    0x62    M_ASK/CCC_GW
0x211    Status HUD [7]    Status HUD [7]    0x3D    HUD
0x212    Höhenstände Luftfeder [8]    Height air spring [8]    0x38    EHC
0x21A    Lampenzustand [13]    Lamp condition [13]    0x70    LM
0x21C    Bedienung Night-Vision [2]    Operation Night-Vision [2]    0x62    CCC_GW
0x21E    Status Night-Vision [2]    Status Night-Vision [2]    0x57    NVC
0x226    Regensensor-Wischergeschwindigkeit [8]    Rain sensor wiper speed [8]    0x45    RLS
0x226    Regensensor-Wischergeschwindigkeit [8]    Rain sensor wiper speed [8]    0x70    LM
0x228    Bedienung Sonderfunktion [8]    Operation special function [8]    0x62    M_ASK/CCC_GW
0x228    Bedienung Sonderfunktion [8]    Operation special function [8]    0x63    CCC_MM
0x22A    Status BFS [10]    Status FSO [10]    0x6E    SM_BF
0x22E    Status BFSH [7]    Status BFSH [7]    0xFF    unbekannt
0x232    Status FAS [10]    Status FAS [10]    0x6D    SM_FA
0x236    Status FASH [7]    Status FASH [7]    0xFF    unbekannt
0x237    Status Lehnenbreitenverstellung Aktiv BF [3]    Status Backrest width adjustment Active BF [3]    0x5A    aLBV_BF
0x239    Status Lehnenbreitenverstellung Aktiv FA [3]    Status Backrest width adjustment Active FA [3]    0x59    aLBV_FA
0x23A    Status FunkschlĂĽssel [13]    Status radio key [13]    0x40    CAS
0x23B    Status Klima Front Erweitert [1]    Status Climate Front Advanced [1]    0x78    IHKA
0x23C    Status Bedienung Sitzkomfort FA [1]    Status Operation Seating comfort FA [1]    0x6D    SM_FA
0x23F    Status Bedienung Sitzkomfort BF [1]    Status Operating Seating Comfort BF [1]    0x6E    SM_BF
0x242    Status Klima Front [11]    Status Climate Front [11]    0x78    IHKA
0x24A    Status PDC [6]    Status PDC [6]    0x64    PDC
0x252    Wischerstatus [8]    Wiper status [8]    0x72    KBM
0x256    Challenge Passive Access [10]    Challenge Passive Access [10]    0x40    CAS
0x258    Status Transmission Passive Access [4]    Status Transmission Passive Access [4]    0x27    PGS
0x25C    Bedienung Klima Zusatzprogramme [2]    Operating climate Additional programs [2]    0x62    M_ASK/CCC_GW
0x26B    Bedienung Rollos BF [2]    Operation Roller blinds BF [2]    0xFF    unbekannt
0x26C    Bedienung Rollos FA [2]    Operation Roller blinds FA [2]    0x0    KGM
0x26D    Bedienung Rollos MK [1]    Operation Roller blinds MK [1]    0xFF    unbekannt
0x26E    Steuerung FH/SHD Zentrale (Komfort) [10]    Control FH / SHD Central (Comfort) [10]    0x40    CAS
0x26F    Bedienung Rollos BFH [2]    Operation Roller blinds BFH [2]    0xFF    unbekannt
0x270    Bedienung Rollos FAH [2]    Operation Roller blinds FAH [2]    0xFF    unbekannt
0x278    Navigationsgraph [3]    Navigation chart [3]    0x62    CCC_GW
0x27A    Synchronisation Navigationsgraph [4]    Synchronization navigation graph [4]    0x62    CCC_GW
0x27E    Status Verdeck Cabrio [7]    Convertible top convertible top [7]    0x24    CVM_V
0x284    Steuerung Fernstart Sicherheitsfahrzeug [8]    Remote control starter safety [8]    0x40    CAS
0x285    Steuerung Rollos [3]    Control roller blinds [3]    0x65    SZM_MIT_KBUS/SZM
0x28C    Bedienung Taster Vertikaldynamik [2]    Control buttons Vertical Dynamics [2]    0x5E    GWS
0x290    Steuerung Reaktion Wasserstoff-Fahrzeug [1]    Control reaction Hydrogen vehicle [1]    0xFF    unbekannt
0x292    Steuerung Fernlicht-Assistent [2]    Steering Wheel Assistant [2]    0x5F    FLA
0x29F    Fernbedienung FondCommander [5]    Remote Control FondCommander [5]    0x40    CAS
0x2A0    Steuerung Zentralverriegelung [10]    Central locking control [10]    0x40    CAS
0x2A2    Bedienung Klima Standfunktionen [5]    Operation Air conditioner [5]    0x62    M_ASK/CCC_GW
0x2A4    Bedienung Personalisierung [8]    Operation Personalization [8]    0x62    M_ASK/CCC_GW
0x2A6    Bedienung Wischertaster [12]    Operation Wiper switch [12]    0x2    SZL_LWS
0x2B2    RaddrĂĽcke K-CAN [1]    Wheel pressure K-CAN [1]    0x29    DXC_RB/DSC_RB/DSC_CT
0x2B3    Beschleunigungsdaten [2]    Acceleration data [2]    0x29    DXC_RB/DSC_RB/DSC_CT
0x2B4    DWA-Alarm [4]    DWA alarm [4]    0x41    DWA
0x2B6    Steuerung Hupe DWA [3]    Control horn DWA [3]    0x41    DWA
0x2B8    Bedienung Bordcomputer [3]    Operation board computer [3]    0x62    M_ASK/CCC_GW
0x2BA    Stoppuhr (3)    Stopwatch (3)    0x60    Kombi
0x2C0    LCD-Leuchtdichte [7]    LCD lighting [7]    0x60    Kombi
0x2CA    AuĂźentemperatur [9]    Outdoor temperature [9]    0x60    Kombi
0x2CE    Steuerung Monitor [4]    Control monitor [4]    0x62    M_ASK/CCC_GW
0x2D5    Status Heizung Heckscheibe [1]    Status Heating rear window [1]    0x78    IHKA
0x2DA    Status Heckklappenlift [2]    Status of tailgate lift [2]    0x6B    HKL
0x2E2    Status Einstellung Video Night-Vision [1]    Status Setting Video Night-Vision [1]    0x57    NVC
0x2E4    Status Anhänger (8)    Status Trailers (8)    0x71    AHM
0x2E6    Status Klima Luftverteilung FA [13]    Status Climate air distribution FA [13]    0x78    IHKA
0x2EA    Status Klima Luftverteilung BF [9]    Status Climate air distribution BF [9]    0x78    IHKA
0x2EC    Status Klima SH/ZH Zusatzwasserpumpe [14]    Status Climate SH / ZH Additional water pump [14]    0x7A    SH_ZH
0x2EE    Status Klima Zusatzprogramme [2]    Status of climate supplementary programs [2]    0x78    IHKA
0x2F0    Status Klima Standfunktionen [12]    Status of climate status [12]    0x78    IHKA
0x2F4    Steuerung Klima SH/ZH Zusatzwasserpumpe [13]    Control climate SH / ZH auxiliary water pump [13]    0x78    IHKA
0x2F6    Steuerung Licht [7]    Control light [7]    0x72    KBM
0x2F7    Einheiten [10]    Units [10]    0x62    M_ASK/CCC_GW
0x2F7    Einheiten [10]    Units [10]    0x63    CCC_MM
0x2F8    Uhrzeit/Datum [12]    Time / Date [12]    0x60    Kombi
0x2FA    Sitzbelegung Gurtkontakte (14)    Seat belt contact (14)    0x1    ACSM
0x2FC    ZV und Klappenzustand [11]    ZV and folding condition [11]    0x40    CAS
0x304    Status Gang [13]    Status Status [13]    0x18    SMG_M/SMG/EGS_MECH+NAVI/EGS_MECH/DKG
0x306    Fahrzeugneigung [2]    Towing    0x70    LM
0x308    Status MSA [2]    Status MSA [2]    0x12    DME1/DDE1
0x310    AuĂźentemperatur/Relativzeit [10]    External temperature / relative time [10]    0x60    Kombi
0x311    Nachtankmenge [3]    Nightfall [3]    0x60    Kombi
0x312    Service Call Teleservice [2]    Service Call Teleservice [2]    0x60    Kombi
0x313    Status Service Call Teleservice [3]    Status Service Call Teleservice [3]    0x36    TEL_BPI
0x313    Status Service Call Teleservice [3]    Status Service Call Teleservice [3]    0x62    M_ASK/CCC_GW
0x314    Status Fahrlicht [9]    Status of driving light [9]    0x45    RLS
0x314    Status Fahrlicht [9]    Status of driving light [9]    0x70    LM
0x315    Fahrzeugmodus [7]    Vehicle mode [7]    0x65    SZM_MIT_KBUS/SZM
0x317    Bedienung Taster PDC [1]    Operation button PDC [1]    0x65    SZM_MIT_KBUS/SZM
0x318    Status Antennen Passive Access [7]    Status Antennas Passive Access [7]    0x27    PGS
0x319    Bedienung Taster RDC [4]    Operation button RDC [4]    0x65    SZM
0x31C    Status Reifendruck [6]    Status of tire pressure [6]    0x20    RDC
0x31D    Status Reifenpannenanzeige [6]    Status of tire tension indicator [6]    0x29    DXC_RB/DSC_RB/DSC_CT
0x322    Dämpferstrom [2]    Damp current [2]    0x39    EDCK_Modul
0x326    Status Dämpferprogramm [9]    Status damper program [9]    0x39    EDCK_Modul
0x328    Relativzeit [9]    Relative time [9]    0x60    Kombi
0x32A    Steuerung ALC [2]    Control system ALC [2]    0x70    LM
0x32D    Anzeige HDC [3]    Display HDC [3]    0x29    DXC_RB
0x32E    Status Klima Interne Regelinfo [6]    Status Climate Internal Ruleinfo [6]    0x78    IHKA
0x330    Kilometerstand/Reichweite [5]    Mileage / range [5]    0x60    Kombi
0x331    Programmierung Stufentempomat [2]    Programming step stepping [2]    0x62    M_ASK/CCC_GW
0x332    Fahreranzeige Drehzahlbereich [4]    Driver display Speed range [4]    0x12    DME1/DDE1
0x335    Status Elektrische Kraftstoffpumpe [3]    Status Electric Fuel Pump [3]    0x17    EKP
0x336    Anzeige Checkcontrol-Meldung (Rolle) [3]    Display of checkcontrol message (role) [3]    0x60    Kombi
0x337    Status Kraftstoffregelung DME [1]    Status Fuel Control DME [1]    0x12    DME1
0x338    Steuerung Anzeige Checkcontrol-Meldung [7]    Control display Checkcontrol message [7]    0x60    Kombi
0x339    Status Anzeige Funktionen Extern [1]    Status Display Functions External [1]    0x62    M_ASK/CCC_GW
0x33A    Status Monitor Front [3]    Status Monitor Front [3]    0x73    CID_C_H/CID_C
0x348    Ăśbereinstimmung Navigationsgraph [4]    Conformity navigation graph [4]    0x62    CCC_GW
0x34A    Navigation GPS 1 [5]    Navigation GPS 1 [5]    0x62    CCC_GW
0x34B    Status Sitzlehnenverriegelung FA (3)    Status Seat back rest FA (3)    0x65    SZM_MIT_KBUS
0x34B    Status Sitzlehnenverriegelung FA (3)    Status Seat back rest FA (3)    0x6D    SM_FA
0x34C    Navigation GPS 2 [5]    Navigation GPS 2 [5]    0x62    CCC_GW
0x34D    Status Sitzlehnenverriegelung BF [2]    Status Seat backrest BF [2]    0x65    SZM_MIT_KBUS
0x34D    Status Sitzlehnenverriegelung BF [2]    Status Seat backrest BF [2]    0x6E    SM_BF
0x34E    Navigation System Information [6]    Navigation system information [6]    0x62    CCC_GW
0x35A    Termin Condition Based Service [2]    Appointment Condition Based Service [2]    0x62    M_ASK/CCC_GW
0x35C    Status Bordcomputer [5]    Status of board computer [5]    0x60    Kombi
0x35E    Daten Bordcomputer (Reisedaten) [5]    Data on board computer (rice data) [5]    0x60    Kombi
0x360    Daten Bordcomputer (Fahrtbeginn) [2]    Data board computer (start of journey) [2]    0x60    Kombi
0x362    Daten Bordcomputer (Durchschnittswerte) [4]    Data on board computer (average values) [4]    0x60    Kombi
0x364    Daten Bordcomputer (Ankunft) [2]    Data board computer (arrival) [2]    0x60    Kombi
0x366    Anzeige Kombi/Externe Anzeige [3]    Display Combi / External Display [3]    0x60    Kombi
0x367    Steuerung Anzeige Bedarfsorientierter Service [6]    Control Display Demand-oriented Service [6]    0x60    Kombi
0x374    Radtoleranzabgleich [7]    Wheel tolerance adjustment [7]    0x29    DXC_RB/DSC_RB/DSC_CT
0x376    Status VerschleiĂź Lamelle [3]    Status wear lamella [3]    0x19    VGSG
0x380    Fahrgestellnummer [5]    Chassis number [5]    0x40    CAS
0x381    Elektronischer Motorölmessstab [10]    Electronic engine oil dipstick [10]    0x12    DME1/DDE1
0x382    Elektronischer Motorölmessstab M [1]    Electronic engine oil dipstick M [1]    0x12    DME1/DDE1
0x388    Fahrzeugtyp [13]    Vehicle type [13]    0x40    CAS
0x38E    Startdrehzahl [1]    Starting speed [1]    0x12    DME1/DDE1
0x394    RDA Anfrage/Datenablage [5]    RDA Request / Data Storage [5]    0x60    Kombi
0x395    Codierung Powermanagement [2]    Coding Powermanagement [2]    0x40    CAS
0x398    Bedienung Fahrwerk [14]    Operation Chassis [14]    0x62    M_ASK/CCC_GW
0x399    Status M-Drive [2]    Status M-Drive [2]    0x12    DME1
0x39C    EBA Datenanforderung [5]    EBA data request [5]    0xFF    unbekannt
0x39E    Bedienung Uhrzeit/Datum [1]    Operation Time / Date [1]    0x62    M_ASK/CCC_GW
0x3A0    Fahrzeugzustand [4]    Vehicle condition [4]    0x0    KGM
0x3A3    Anforderung Remote Services [2]    Request Remote Services [2]    0x62    M_ASK/CCC_GW
0x3AC    Nachlaufzeit Klemme 30 fehlergesteuert [2]    Follow-up time Terminal 30 error-controlled [2]    0x0    KGM
0x3B0    Status Gang Rückwärts [2]    Status Reverse [2]    0x70    LM
0x3B1    Getriebedaten 3 [2]    Transmission data 3 [2]    0x18    EGS_MECH/DKG
0x3B3    Powermanagement Verbrauchersteuerung [8]    Powermanagement Consumer Control [8]    0x12    DME1/DDE1
0x3B4    Powermanagement Batteriespannung [11]    Powermanagement Battery voltage [11]    0x12    DME1/DDE1
0x3B5    Status Wasserventil [6]    Status Water valve [6]    0x78    IHKA
0x3B6    Position Fensterheber FAT [6]    Position window lifter FAT [6]    0x0    KGM
0x3B7    Position Fensterheber FATH [5]    Position window lifters FATH [5]    0x72    KBM
0x3B8    Position Fensterheber BFT [6]    Position window lifter BFT [6]    0x0    KGM
0x3B9    Position Fensterheber BFTH [5]    Position Window lifters BFTH [5]    0x72    KBM
0x3BA    Position SHD [10]    Position SHD [10]    0x44    SHD/MDS
0x3BD    Status Verbraucherabschaltung [2]    Status of consumer disconnection [2]    0x72    KBM
0x3BE    Nachlaufzeit Stromversorgung [5]    Run-on time Power supply [5]    0x40    CAS
0x3BF    Position Fensterheber Heckscheibe [1]    Position Window Regulator Rear Window [1]    0x24    CVM_V
0x3C0    Konfiguration FAS [3]    Configuration FAS [3]    0x6D    SM_FA
0x3C1    Konfiguration BFS [3]    Configuration FSO [3]    0x6E    SM_BF
0x3CA    Konfiguration M-Drive [2]    Configuration M-Drive [2]    0x62    M_ASK/CCC_GW
0x3D3    Status Solarsensor [1]    Status Solar sensor [1]    0x70    LM
0x3D4    Konfiguration Zentralverriegelung CKM [3]    Configuration Central locking CKM [3]    0x62    M_ASK/CCC_GW
0x3D5    Status Zentralverriegelung CKM [4]    Status Central locking CKM [4]    0x40    CAS
0x3D6    Konfiguration DWA CKM [1]    Configuration DWA CKM [1]    0x62    M_ASK/CCC_GW
0x3D7    Status DWA CKM [2]    Status DWA CKM [2]    0x41    DWA
0x3D8    Konfiguration RLS CKM [3]    Configuration RLS CKM [3]    0x62    M_ASK/CCC_GW
0x3D9    Status RLS CKM [4]    Status RLS CKM [4]    0x45    RLS
0x3D9    Status RLS CKM [4]    Status RLS CKM [4]    0x70    LM
0x3DA    Konfiguration Memorypositionen CKM [1]    Configuration Memory positions CKM [1]    0x62    M_ASK/CCC_GW
0x3DB    Status Memorypositionen CKM [3]    Status Memory positions CKM [3]    0x65    SZM_MIT_KBUS
0x3DB    Status Memorypositionen CKM [3]    Status Memory positions CKM [3]    0x6D    SM_FA
0x3DC    Konfiguration Licht CKM [3]    Configuration light CKM [3]    0x62    M_ASK/CCC_GW
0x3DD    Status Licht CKM [4]    Status light CKM [4]    0x70    LM
0x3DE    Konfiguration Klima CKM [5]    Configuration Climate CKM [5]    0x62    M_ASK/CCC_GW
0x3DF    Status Klima CKM [6]    Status Climate CKM [6]    0x78    IHKA
0x3E0    Konfiguration ALC CKM [1]    Configuration ALC CKM [1]    0x62    M_ASK/CCC_GW
0x3E1    Status ALC CKM [1]    Status ALC CKM [1]    0x70    LM
0x3E2    Konfiguration Heckklappe CKM [1]    Configuration tailgate CKM [1]    0x62    M_ASK/CCC_GW
0x3E3    Status Heckklappe CKM [1]    Status tailgate CKM [1]    0x6B    HKL
0x3E9    Marker 1 [1]    Marker 1 [1]    0xFF    unbekannt
0x3EA    Marker 2 [3]    Marker 2 [3]    0x7E    Diagnosetool_K_CAN_System
0x3EB    Marker 3 [1]    Marker 3 [1]    0x7D    Diagnosetool_PT_CAN
0x3EE    Anforderung Fehlermeldung [1]    Request error message [1]    0xFF    unbekannt
0x3EF    OBD Daten Motor (3)    OBD data engine (3)    0x12    DME1/DDE1
0x3F0    Konfiguration Licht Erweitert CKM [1]    Configuration Light Advanced CKM [1]    0x62    M_ASK/CCC_GW
0x3F1    Status Licht Erweitert CKM [1]    Status Light Advanced CKM [1]    0x70    LM
0x3F4    Konfiguration Laderaumabdeckung CKM [1]    Configuration of charger cover CKM [1]    0x62    M_ASK/CCC_GW
0x3F5    Status Laderaumabdeckung CKM [1]    Status Charging compartment cover CKM [1]    0x72    KBM
0x3FE    Anforderung CAN_Testtool SI-Bus [5]    Requirement CAN_Testtool SI-Bus [5]    0x7E    Diagnosetool_K_CAN_System
0x480    Netzwerkmanagement    Network management    0x0    KGM
0x481    Netzwerkmanagement    Network management    0x1    ACSM
0x482    Netzwerkmanagement    Network management    0x2    SZL_LWS
0x492    Netzwerkmanagement    Network management    0x12    DDE1/DME1
0x496    Netzwerkmanagement    Network management    0x16    AFS
0x497    Netzwerkmanagement    Network management    0x17    EKP
0x498    Netzwerkmanagement    Network management    0x18    DKG/EGS_MECH/EGS_MECH+NAVI/SMG/SMG_M
0x499    Netzwerkmanagement    Network management    0x19    VGSG
0x49B    Netzwerkmanagement    Network management    0x1B    VVT1
0x49C    Netzwerkmanagement    Network management    0x1C    LDM
0x49E    Netzwerkmanagement    Network management    0x1E    VVT2
0x4A0    Netzwerkmanagement    Network management    0x20    RDC
0x4A1    Netzwerkmanagement    Network management    0x21    ACC+NAVI/ACC_Modul
0x4A3    Netzwerkmanagement    Network management    0x23    ARS_Modul
0x4A4    Netzwerkmanagement    Network management    0x24    CVM_V
0x4A5    Netzwerkmanagement    Network management    0x25    RSC_VDA/SC_CT/SC_VDA
0x4A7    Netzwerkmanagement    Network management    0x27    PGS
0x4A9    Netzwerkmanagement    Network management    0x29    DSC_CT/DSC_RB/DXC_RB
0x4B6    Netzwerkmanagement    Network management    0x36    TEL_BPI/TEL_JAP/TEL_MULF
0x4B7    Netzwerkmanagement    Network management    0x37    AMP_TOP
0x4B8    Netzwerkmanagement    Network management    0x38    EHC
0x4B9    Netzwerkmanagement    Network management    0x39    EDCK_Modul
0x4BA    Netzwerkmanagement    Network management    0x3A    KHM
0x4BB    Netzwerkmanagement    Network management    0x3B    JNAV
0x4BC    Netzwerkmanagement    Network management    0x3C    CDC
0x4BD    Netzwerkmanagement    Network management    0x3D    HUD
0x4C0    Netzwerkmanagement    Network management    0x40    CAS
0x4C1    Netzwerkmanagement    Network management    0x41    DWA
0x4C4    Netzwerkmanagement    Network management    0x44    MDS/SHD
0x4C5    Netzwerkmanagement    Network management    0x45    RLS/RLS
0x4CB    Netzwerkmanagement    Network management    0x4B    VM
0x4D0    Netzwerkmanagement    Network management    0x50    Notstrom-Sirene
0x4D3    Netzwerkmanagement    Network management    0x53    IBOC
0x4D4    Netzwerkmanagement    Network management    0x54    SDARS
0x4D5    Netzwerkmanagement    Network management    0x55    ISpeechBox
0x4D7    Netzwerkmanagement    Network management    0x57    NVC
0x4D9    Netzwerkmanagement    Network management    0x59    aLBV_FA
0x4DA    Netzwerkmanagement    Network management    0x5A    aLBV_BF
0x4DB    Netzwerkmanagement    Network management    0x5B    DAB
0x4DC    Netzwerkmanagement    Network management    0x5C    Behoerde
0x4DD    Netzwerkmanagement    Network management    0x5D    TLC
0x4DE    Netzwerkmanagement    Network management    0x5E    GWS
0x4DF    Netzwerkmanagement    Network management    0x5F    FLA
0x4E0    Netzwerkmanagement    Network management    0x60    Kombi
0x4E2    Netzwerkmanagement    Network management    0x62    CCC_GW/M_ASK
0x4E3    Netzwerkmanagement    Network management    0x63    CCC_MM
0x4E4    Netzwerkmanagement    Network management    0x64    PDC
0x4E5    Netzwerkmanagement    Network management    0x65    SZM/SZM_MIT_KBUS
0x4E7    Netzwerkmanagement    Network management    0x67    ZBE/ZBE_LO
0x4EB    Netzwerkmanagement    Network management    0x6B    HKL
0x4ED    Netzwerkmanagement    Network management    0x6D    SM_FA/SM_FA_KBUS
0x4EE    Netzwerkmanagement    Network management    0x6E    SM_BF/SM_BF_KBUS
0x4F0    Netzwerkmanagement    Network management    0x70    LM/LM_ALC
0x4F1    Netzwerkmanagement    Network management    0x71    AHM
0x4F2    Netzwerkmanagement    Network management    0x72    KBM
0x4F3    Netzwerkmanagement    Network management    0x73    CID_C/CID_C_H
0x4F8    Netzwerkmanagement    Network management    0x78    IHKA
0x4FA    Netzwerkmanagement    Network management    0x7A    SH_ZH
0x4FD    Netzwerkmanagement    Network management    0x7D    Diagnosetool_PT_CAN
0x4FE    Netzwerkmanagement    Network management    0x7E    Diagnosetool_K_CAN_System
0x500    Datentransfer [1]    Data transfer [1]    0x70    LM
0x500    Datentransfer [1]    Data transfer [1]    0x78    IHKA
0x509    Netzwerkmanagement    Network management    0x89    Xenon_Scheinwerfer_Links_ALC
0x50A    Netzwerkmanagement    Network management    0x8A    Xenon_Scheinwerfer_Rechts_ALC
0x50B    Netzwerkmanagement    Network management    0x8B    CNV
0x571    Netzwerkmanagement    Network management    0xF1    Diagnosedose
0x580    Dienste    services    0x0    KGM
0x581    Dienste    services    0x1    ACSM
0x582    Dienste    services    0x2    SZL_LWS
0x592    Dienste    services    0x12    DDE1/DME1
0x596    Dienste    services    0x16    AFS
0x597    Dienste    services    0x17    EKP
0x598    Dienste    services    0x18    DKG/EGS_MECH/EGS_MECH+NAVI/SMG/SMG_M
0x599    Dienste    services    0x19    VGSG
0x59B    Dienste    services    0x1B    VVT1
0x59C    Dienste    services    0x1C    LDM
0x59E    Dienste    services    0x1E    VVT2
0x5A0    Dienste    services    0x20    RDC
0x5A1    Dienste    services    0x21    ACC+NAVI/ACC_Modul
0x5A3    Dienste    services    0x23    ARS_Modul
0x5A4    Dienste    services    0x24    CVM_V
0x5A5    Dienste    services    0x25    RSC_VDA/SC_CT/SC_VDA
0x5A7    Dienste    services    0x27    PGS
0x5A9    Dienste    services    0x29    DSC_CT/DSC_RB/DXC_RB
0x5B6    Dienste    services    0x36    TEL_BPI/TEL_JAP/TEL_MULF
0x5B7    Dienste    services    0x37    AMP_TOP
0x5B8    Dienste    services    0x38    EHC
0x5B9    Dienste    services    0x39    EDCK_Modul
0x5BA    Dienste    services    0x3A    KHM
0x5BB    Dienste    services    0x3B    JNAV
0x5BC    Dienste    services    0x3C    CDC
0x5BD    Dienste    services    0x3D    HUD
0x5C0    Dienste    services    0x40    CAS
0x5C1    Dienste    services    0x41    DWA
0x5C4    Dienste    services    0x44    MDS/SHD
0x5C5    Dienste    services    0x45    RLS/RLS
0x5CB    Dienste    services    0x4B    VM
0x5D0    Dienste    services    0x50    Notstrom-Sirene
0x5D3    Dienste    services    0x53    IBOC
0x5D4    Dienste    services    0x54    SDARS
0x5D5    Dienste    services    0x55    ISpeechBox
0x5D7    Dienste    services    0x57    NVC
0x5D9    Dienste    services    0x59    aLBV_FA
0x5DA    Dienste    services    0x5A    aLBV_BF
0x5DB    Dienste    services    0x5B    DAB
0x5DC    Dienste    services    0x5C    Behoerde
0x5DD    Dienste    services    0x5D    TLC
0x5DE    Dienste    services    0x5E    GWS
0x5DF    Dienste    services    0x5F    FLA
0x5E0    Dienste    services    0x60    Kombi
0x5E2    Dienste    services    0x62    CCC_GW/M_ASK
0x5E3    Dienste    services    0x63    CCC_MM
0x5E4    Dienste    services    0x64    PDC
0x5E5    Dienste    services    0x65    SZM/SZM_MIT_KBUS
0x5E7    Dienste    services    0x67    ZBE/ZBE_LO
0x5EB    Dienste    services    0x6B    HKL
0x5ED    Dienste    services    0x6D    SM_FA/SM_FA_KBUS
0x5EE    Dienste    services    0x6E    SM_BF/SM_BF_KBUS
0x5F0    Dienste    services    0x70    LM/LM_ALC
0x5F1    Dienste    services    0x71    AHM
0x5F2    Dienste    services    0x72    KBM
0x5F3    Dienste    services    0x73    CID_C/CID_C_H
0x5F8    Dienste    services    0x78    IHKA
0x5FA    Dienste    services    0x7A    SH_ZH
0x5FD    Dienste    services    0x7D    Diagnosetool_PT_CAN
0x5FE    Dienste    services    0x7E    Diagnosetool_K_CAN_System
0x609    Dienste    services    0x89    Xenon_Scheinwerfer_Links_ALC
0x60A    Dienste    services    0x8A    Xenon_Scheinwerfer_Rechts_ALC
0x60B    Dienste    services    0x8B    CNV
0x671    Dienste    services    0xF1    Diagnosedose
0x7C0    CAS Programmierung Bandende 1 (3)    CAS Programming Bandende 1 (3)    0x40    CAS
0x7C1    CAS Programmierung Bandende 2 (3)    CAS Programming Bandende 2 (3)    0xFF    TOOL_BANDENDE_CAS
0x7C2    CAS Applikationsnachricht 1 (3)    CAS Application Message 1 (3)    0x40    CAS
0x7C3    CAS Applikationsnachricht 2 (3)    CAS application message 2 (3)    0xFF    TOOL_BANDENDE_CAS
0xFFF    unbekannt    unknown    0xFF    Sender unbekannt
Listing of what a bunch of message IDs are for and which modules they originate from. There are some IDs missing when I check against my 535xi, so the list is incomplete, but it's still much better than flying completely blind.
Can you recall where you found it?
So, it took a while, but I finally got around to soldering the header pins on my Sparkfun CAN Shield.
CAN-BUS Shield - DEV-13262 - SparkFun Electronics
This board is a "shield" (expansion board) for an Arduino (open source microcontroller) and allows you to connect an Arduino to a CAN bus. Depending on the program written for the Arduino, it can log the CAN packets (signals) across the car's bus. Once a large amount of data is obtained, it takes some work to go through and interpret what the signals are, who (which module) they are meant for, and what they contain. Most people would be amazed at the amount of data flying around in their car if they're not familiar with this.
My goal is to figure out what signals are generated in the car when certain buttons are pressed. Who knows, maybe we can do something cool with that!
Also, once I'm familiar with the signals and interpreting them, I would like to build a bench tester for the throttle actuators and idle actuators.
Try instead an ESP32 with dual core cpu, integrated Wifi/Bluetooth and OLED screen. Heltec brand is cheap and OK since it comes with oled but Lolin D32 is a more of a Quality, slightly more powerful and capable chipset with flash memory option.
thank me later. It runs on the arduino platform/IDE as well but wrapped around the Espressif OS system. Its awesome because it just as easy to use and packs tons of power for its size. Especially considering the footprint (size) of the esp32 compared to Arduino Uno/Mega, etc.
Ever since moving to Puerto rico about 2 months ago... i too have been thinking about what can be done With an arduino + bmw but more along the lines of an anti-theft Car tracking device that uses a mobile carrier connection and a small backup battery if car 12v battery is disconnected. Car jackings and thefts are pretty rampant here which is why i start thinking of a potential cheap anti-theft car tracker product
I already built a working unit, which connects to the K-CAN bus, with switching available for M-Mode status, RPM, and throttle. In fact, I have a spare unit for sale - but no one seems interested (not sure why; it's by far one of the best mods I have done on my car).
Does anyone have any PT-CAN bus logs in Steptronic manual selection mode?
My idea is to inject manual selection packets into my E66 assuming MS is part of 0x192 packet. On the E66 it's definitely the 0x192 which controls R/N/D electronically.
Hello guys im building a remote start system from scratch and i have a question
if the key is in the slot but not pressed is it possible to send a command via the obd with tool 32,inpa,or insta to trigger the kl15?( ignition on )? i want to capture this signal on the k-can
on ista i have seen this multiple times doing it by itself ( same for ista p )
maybe someone knows and it would really help out
Kind regards
here is the project in works (
41 - 55 of 55 Posts
