For the past week my car has been showing some strange behavior... The outside temperature gauge starts off normal, but then after I'm driving for about 20 minutes, it starts climbing rapidly (about 1 degree per minute) My commute from work to home isnt very long so the highest I've seen it go is 103 F, when the actual outside temp is around 70 F. The coolant temp (the gauge on the far right) always stays in the middle and that hasn't moved so I don't think the car is over heating...do you think this is a faulty sensor or something worse I should check out?
