I was sick and tired of the slop and long throws of the factory shifter, so following the info found in this thread: http://www.m5board.com/vbulletin/showthread.php?t=103511
I ordered the E60 545i "short" shifter - Item #6 p/n 25117546373
http://www.realoem.com/bmw/showparts.do?model=NB33&mospid=47759&btnr=25_0407&hg=25&fg=05
props to Azaytsev for pointing it out.
I also ordered a new bushing - Item #3.
http://www.realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=25_0009&hg=25&fg=05
If you're not installing a DSSR at the same time, I would recommend getting an extra couple washers (Item 5) and clip (Item 6) I actually lost a clip in the heatshield, and lost a washer that I swear vanished into thin air.
They're cheap and better to have them and not need them, than to not have them and need them. The DSSR comes with new clips/washers, so I had to reuse the old to replace the lost parts,
I ordered the parts from
https://secure.webmakerx.net/Default-2.aspx?hostname=parts.crownauto.com
They had the best price, and had no problems getting the shifter - they had to order the shifter from Germany, so it took over a week to get, but it was worth the wait.
I also ordered a UUC DSSR, the ZHP knob, and Redline Goods shift and e-brake boot.
During the install, I found that most of the slop was just in the worn out shifter bushing, I'm sure the DSSR helps, but I bet 90% of the slop I had was from the bushing, and the car only has 50K miles on it.
The E60 shifter needs to have the bushing trimmed at the bottom, my guess is that it was made this way to eliminate the need for the plastic washers, however, it will not fit in the DSSR this way, nor will the shifter fit through the shifter bushing.
The E60 shifter is about 3/4" lower in height, and the ZHP knob is another 1/2" lower
Here is the factory shift lever and ZHP knob with Redline boot:
Here's the after:
Throws are MUCH shorter, ~30% shorter than factory by my calcs (knob + shifter vs. factory knob and shifter)
I've only had time to drive around the block, but I love it so far - the weighted knob and heavier DSSR linkage are very nice as well.
JD Ross from Crown Auto BMW sent me this pics of the E60 normal shifter vs. the short shifter, it's taller, and slightly shorter on the bottom, so it will have longer throws, would be good if you think 30% is too much.
*Disclaimer* I have no association with Crown BMW, just a happy customer
Here's the after:
