• Latest threads
    • Custom feed
      • Updates
        Old 21st February 2008, 10:07   #1 (permalink)
        M55555
        M55555's Avatar
        E60 545i Short Shifter Install + Review
        Thanks to xr4tic for his inspiration here
        Crown Auto delivered on my expectations: delivery in less than 5 days and products in stock. Also received great customer service from JD who sent a follow up email to keep me in the loop. One item was missing from the package (1 circlip), wasn't a big deal as it costs $0.61. Plus, JD mailed me it so no big deal.
        Parts/Tools Needed:
        1 x 25117546373 Shift Lever
        1 x 25111220600 Shift Bearing
        4 x 25111220439 Yellow Washers
        2 x 25111220379 Circlip
        Needle Nose Pliers
        Long Flathead Screwdriver
        Lithium Grease
        Jack Stands + Jack
        Soapy Water
        Installation: I followed this link
        Job Duration: 2 hours
        It was my first time doing this, and had a difficult time removing the circlip from the OE shifter. The space is very tight, and I could only raise the car so high with my jack. If I were to this again, it would easily take 30 minutes max.
        Some things to note in this install:
        1. The rubber boot that covers the shifter and the opening needs to be dipped on some soapy water. It makes it a lot easier to slide this sucker over the shifter and pushed into the opening.
        2. The yellow washers are optional since the E60 lever has bushings that protrude to compensate for the washers on the E39 lever. I got 4 just in case, since they pennies each. Even with 1 yellow washer, I could not fit the circlip on.
        3. I would buy at least 2+ circlips, as the 1 that I had did fall into the heat shield. Luckily, I could reach my hand in far enough to retrieve it.
        4. Jack the car as high as you can do so safely. The space is definitely tight.
        5. The shift bearing can be easily removed by simply taking a needle nose plier, rotating the bearing about 1/4 counterclockwise, inserting a flathead screwdriver into the slot on the clip, and pulling gently. I tried to pry that sucker out before I learned I could simply rotate it out of the locking position.
        6. When reinstalling the bearing, make sure the "flaps" are pointed out towards the doors. This way, you can simply push it back in.
        7. Otherwise, VERY EASY DIY.
        Impressions:
        I originally purchased the Z3M shifter last year, but sold due to concerns of notchiness and shifting effort. In reading reviews about the E60 shifter as an unbranded Dinan shifter, I was skeptical at how much improvement I would actually notice. After the install you can immediately feel the difference in the throws. The shifts are 100% more crisps (click click click between gears) and the knob sits about 1/2 inch below the OE lever. For the ~$70 I paid for this mod, I was more than pleasantly surprised. The "side to side" slop is eliminated, and the shifts are like butter. The "rubber" feel of the OE lever has been eliminated completely. I was ultimately looking for the shortest throw and shortest knob height, but what this E60 lever delivers is PERFECT. I would have been unhappy with the Z3M. You can't beat this mod for the price. For those who feel that the Dinan counterpart is on the expensive side, I urge you to give this one a try. And when I say the throws are reduced, I'm talking dramatic enough to know you have an SSK while maintaining the OE appeal.
        BTW: I have 4 yellow washers and 1 circlip that I did not use. If anyone needs 1+, let me know and I can snailmail it over to you.
        e60-545i-short-shifter-install-review-ssk.jpg   e60-545i-short-shifter-install-review-ssk-2.jpg   e60-545i-short-shifter-install-review-ssk-3.jpg   e60-545i-short-shifter-install-review-ssk-parts-1.jpg   e60-545i-short-shifter-install-review-ssk-parts-2.jpg   e60-545i-short-shifter-install-review-ssk-parts-3.jpg
        2001 Carbon Black ///M5
        BBS RC 18x8.5F/18x10R | Bilstein PSS9 Coilovers | ESS Software | Magnaflow 14816 | E60 545i SSK | 3000K HID Fogs
        M55555 is offline
        The Following 8 Users Say Thank You to M55555 For This Useful Post:
        Beasty5 (21st February 2008), E Alexander (2nd August 2008), Fiori (19th May 2008), iconoclast (13th April 2008), jsnm (22nd May 2008), Mike S. (22nd February 2008), rassi (21st February 2008), s4kebomb (21st February 2008)
        Old 21st February 2008, 13:41   #2 (permalink)
        azaytsev
        azaytsev's Avatar
        add the ZHP weighted shifter and you are gonna be even more happier
        azaytsev is offline
        Old 21st February 2008, 15:30   #3 (permalink)
        julesandtrish
        julesandtrish's Avatar
        I also installed this a few days ago myself and M55555, you are right. It's PERFECT. The only PITA about the whole thing was trying to put the "C" clip back on. I got so fustrated (after 3 hrs.) that I took it to the dealer and they put the clip on for free!
        -Julian
        julesandtrish is offline
        Old 21st February 2008, 16:32   #4 (permalink)
        Kelster
        Kelster's Avatar
        It's a great mod at a rock bottom price. Thanks to Thrilos5 for originally recommending it to me.
        2003 Jet Black ///M5 Dinan S3
        621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2 SQ Intercooled Supercharger
        , S3 Oil Cooler, S3 Engine Management Software, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Free Flow Exhaust, BMW 545 Short Shift Kit, Stage 3 Dinan/JRZ Suspension, Dinan/Brembo Brakes, Dinan Pedal Pad Set, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Subframe Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, 4 Toyo Proxes RA1 275/35R18 /Drags: Nitto NT-555R Drag Radials 285/35R18, Blinder-M45-X-treme, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v29 Perspective & Navtech 2007.2 DVD Map, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder
        1/4 mile: 11.795 @122.20 mph, 60' - 1.819
        Kelster is offline
        Old 21st February 2008, 17:14   #5 (permalink)
        kiddhan625
        kiddhan625's Avatar
        I had the Dinan short shifter installed this past Fall. Definitely worth the upgrade. I would never go back to stock!
        kiddhan625 is offline
        Old 21st February 2008, 20:04   #6 (permalink)
        M55555
        M55555's Avatar
        The ZHP won't match with my wood-grain trim
        The circlip was definitely a pain. I was able to reach 2 hands in that small area to remove it, causing it to fall into the heatshield.
        M55555 is offline
        Old 21st February 2008, 22:33   #7 (permalink)
        rhouse181
        rhouse181's Avatar
        I also did the e60 shifter and new bushings, and the results were just as spectacular. The car should have come stock like that!
        Big difference, but some of the side to side slop comes back after 500 miles or so...
        - Randall
        rhouse181 is offline
        The Following User Says Thank You to rhouse181 For This Useful Post:
        Wi_KeD_M5 (22nd March 2008)
        Old 21st February 2008, 23:29   #8 (permalink)
        Stika
        Stika's Avatar
        BIG +1 on that!
        ...i wanna go fast...
        Stika is offline
        Old 22nd February 2008, 00:04   #9 (permalink)
        M55555
        M55555's Avatar
        The ZHP weighted knob requires a new boot also, correct?
        M55555 is offline
        Old 22nd February 2008, 00:20   #10 (permalink)
        azaytsev
        azaytsev's Avatar
        Yes. Since the oem shifter knob is attached to the leather boot you need to buy a separate e39 boot
        azaytsev is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!Google Bookmark this Post!
