I've done a fair amount of searching and I can't seem to find an issue like mine that's already been tackled. I'm looking for advice on the best way to proceed with this. I have a 2003 with 71K miles.
A couple of months ago I started noticing a vibration coming up through the shifter at around 2000-3000 RPMs. Since then I've replaced the tires (needed to go anyway) and the vibration is still there. The problem presents itself when the car is up to temperature and is under load. If the car is dead cold I get nothing. It's most predominant in 6th gear right at 2000 RPMs but is there in 3rd-5th as well. It's probably there in 1st and 2nd as well but it's harder to pinpoint. The tempo of the vibration appears constant no matter what gear I'm in.
I can best describe the vibration as if something was spinning and hitting on something during the rotation. Almost like if you spun a big wheel and every time it passed a point in the circle you'd feel the wheel hit something. At higher RPMs, the vibration goes faster until around 3500 when it's hard to pinpoint amongst everything else. If you take your foot off the gas at 2K RPMs, the problem goes away. If you push the clutch in, the problem goes away. If you're driving downhill, the problem is less prevalent than on flat or going uphill but still there. I do not use engine braking and the car is 100% stock except for my new F10 shift knob.
The driveshaft was replaced by the PO at BMW dealer #2 below back in November 2010. The guibo has been inspected multiple times very recently and looks good.
The clutch was replaced over the summer by Indy #2 below. The flywheel was not replaced as it appeared in good condition. The problem presented itself around five months later. Also, about a year ago, Indy #1 below changed the transmission fluid and differential fluid.
Over the course of the past few weeks, I've gotten a lot of opinions on the matter:
BMW dealer #1: The service manager, who I really respect and have known for awhile, went out with me and said it sounded/felt like a center bearing/u-joint/driveshaft issue or something to do with various mounts. He recommended replacing the tires (this was before I got four new ones) and then seeing how it felt. I will say that it might have gotten a little better after the new tires were put on (road force balanced + alignment) although there might be a placebo effect here.
BMW dealer #2: Normal wear and tear.
Indy #1: Not really sure. Only way to check would be to drop the transmission to see what's going on. Said the center bearing looked fine. Recommended starting with a change of the transmission fluid. Implied that it could be a transmission problem but again only way to rule it out would be to remove the transmission and check everything else.
Indy #2. Not really sure. Doesn't think it's the flywheel. Suggested going back to OEM fluids in transmission and diff (Indy #1 put Red Line in both) as a start.
Mike Miller (Roundel): I emailed Mike about the problem and he immediately suggested it was a classic case of center bearing/u-joint. We even spoke live about it. Said that if the center bearing wasn't preloaded correctly when the clutch was out this can lead to premature failure of the center bearing et. al. He didn't suggest it wasn't preloaded, just a possible cause.
I'm inclined to go with the Indy recommendations of changing the fluids out and seeing what that gets me since it's a much lower cost option than replacing the driveshaft components. However, if it's a center bearing et. al. issue, the fluid change isn't going to do anything for me.
I'd appreciate all thoughts on the matter......I'm not opposed to replacing the driveshaft/components again but don't want throw big bucks at the problem with an unknown outcome. Thanks!
