Last night I was driving home on the highway and the car didn't seem to get as warm as it should. This was the first time this season where I drove it in chillier weather and it was roughly a 35-minute drive, more than enough to warm the engine I would think. The temp needle didn't move up to its usual 12 o'clock position but hovered between the first dot and 12. I couldn't get hot air out of the vents until I remembered the hot/cold dial on the center vent; a mistake I made in my M3 regularly as well.
Sitting in the driveway it did warm up very quickly to the usual spot and of course once I got the vent set to hot I got all the warm air I wanted. I drove it again this morning, all stop-and-go for about twenty minutes. Again, abundant hot air but the temp needle never pointed straight up as it should.
I'm assuming based on this behavior, and some searching here, that I need a thermostat. It was even chillier this morning so I suspect that the colder weather is revealing the problem and that it was masked before by hot weather and AC use driving the engine temps up to normal.
Tischer has OEM for about $80 but I can get Behr/Mahle for about $50 from another source. Are these effectively equivalent - or is Mahle/Behr in fact OEM?
Also, I'd be grateful if anyone has part numbers for the rubber O-rings everyone mentions in the DIYs as I am having trouble finding them.
Thanks!
Thanks!
