501 - 520 of 1,168 Posts
Probably a stupid question, as I am not understanding how too do this yet...I just ordered the alpha n tube from jaws. It comes on a mygenie unit, could I use that unit to do the smg tune as well if I programmed it?
I've been seeding the files for the last couple of days and will keep them up over the weekend in case any one else needs to grab them.
Got a link to the torrent? Mainly just looking for the Euro SMG File. Tried to PM you, but I'm 30 posts shy of being able to.
Thanks!
Made a video using the Euro Launch Control!
I always noticed with the U.S Spec Launch Control you got a lag once leaving the SMG lever go but now with the Euro Launch Control, no lag, less violent than before, and more awesome! Revs up to 4100, let the SMG lever go, and it takes it from there shifting for you!
:jump::clap::clap::clap::clap::jump::clap::clap::clap::clap::jump::clap::clap::clap::clap::jump::clap::clap:
Ok, I'm almost harder than Chinese algebra after seeing that!! MUST HAVE!! MUST HAVE!!
Thanks for posting that, khyber...you da mang, mang!
Seemed like it took a little long to shift out of first gear, though. Was that because the tires were spinning, or what? Just curious. Oh...and have you tried to adjust the RPM speed of the launch control yet? I think I read somewhere that this can be done using either the turn signal stalk or the cruise control stalk.
Curious to know if the RPM adjustment works or not.
yeah, my rear tires are way low on thread from my powersliding practice ahaha! I was real curious if it would shift on its own and it did, giving it a perfect redline shift, my wheels were spinning till 3rd gea, btw. My adrenaline shot up, i wanted to go again but I'll try it again with a fresh set of PS2's. No more handicap U.S Launch Control!
If you find a more thorough instructions on the adjustment I would love to try!
I wonder if it auto learns the wheel spin like a 458 italia? Would be awesome if it does!
Thanks!
The magnet URI is:
magnet:?xt=urn:btih:VLMBNBYHE6HRXOOJUY7LEQGVNZU34QFR
I assume if you use the link in the first post it will download from there, I am seeding from that link.
I am a torrent noob!
Discussion starter · #507 ·
Nice glad you are enjoying!
So even when in S mode, the SMG shifted automatically for you at redline for all gears? I just got the Euro SMG coded Friday, but haven't launched yet.
I did go through almost the entire LC sequence just to make sure it would launch at 4k if I let go of the lever, but in the end I didn't let go of the lever.
Euro SMG installed by....???
Oooo...ok, I see you have an '08 like I do. Who did you have install the Euro SMG software? Did you send your TCU out or take your beast somewhere? Do you know if it was done with an ICOM interface or just an ODB-II cable and a laptop??
VERY curious to know, since the '08 and newer cars are the ones that are being....."fickle".
Yeah, the first thing I did after I got it programmed for Euro SMG program was test out the Launch Mode and it went to 4000rpm, I was kinda in shock, I was real happy, It was like Santa came 2 months later.
Yes, in launch mode, once you let the lever go, it will pull through the gears shifting automatically at redline perfectly. 1st gear your wheels are just spinning and computers are basically shifting @ at the best time to get traction for 2nd gear. I don't care about the clutch wearing down, i can replace that my concern is the overall wear and tear on the SMG as a whole, pump, gearing, etc. Its highly addictive, my passengers wanted to do it again and I told them Summer 2012 lol
I only know that the SMG shifts on its own in Euro Launch Mode. I have not tried redlining the motor in S to see if it shifts on its own then, though I don't have a problem trying since I have got p.m's on that and curious myself.
I did Randy's SMG with an ICOM interface. I've done two 08 E60s (along with 2 other 06 E60s) and one 08 e63 with it so far. Allows me to make sure all the other modules are up to date with ISTA/P before proceeding.
Thanks for answering his question, Paul. I was about to send you an email to confirm that it was ICOM you used for the Euro SMG coding.
And thanks again for helping code my car! =]
What's up Randy...you afraid ?
Afraid of launching? I'm more worried about what the dealer will say if it sees that I have been Euro launching since I'm still under BMW's extended warranty.
Isn't the limit like 7 LCs in Europe before warranty is avoided? I actually was planning to try it this weekend, but never got an optimum opportunity in a safe area. The only times I have tried with the US spec LC are either late at night or at open, safe areas (i.e. the Marina airport during CCC).
I should make some gopro videos of launching though...or you can do that, Paul. You seem a bit more balls-y than I =P
Through ISTA-D, I have yet to find any obvious notifications as to the count of launch control, nor have I seen it in INPA. I have run ISTA-D on a member whom has launched a couple of times specifically looking to see what the diags had to say. I'll continue to dig around, but so far the only item would be be if programming (ISTA-P) were invoked on a coded car, it would recognize that the ZB number for the SMG was incorrect, and it would want to update it to the most recent US program (effectively overwriting the euro program). This is no guarantee and YMMV.
Ah, thanks, Paul.
Still a little worried about launching too many times. I thought that for US-spec'd M5's, BMW limited LC to 1500rpm and thus the dealer didn't really care really how many times you launched because it was pretty much a pointless launch and wouldn't hurt the tranny/clutch too much compared to the 4000rpm Euro LC.
But, I know I'll be doing it sometime in the near future...very near I'm sure hiha
I did it today and I adjusted the RPM for Euro Launch Control via the cruise control knob, it would go lower or higher by 100rpm each click down or upward. Pretty awesome, really helps get that perfect launch for the variable conditions you could be in!
