Partee Racing Carbon Fiber Plenum for E39 M5--Top and Bottom!
12K views 56 replies 20 participants last post by  herrubermensch
#1 · (Edited)
Partee Racing's carbon fiber and fabrication division, in partnership with EAE Motorsports, is pleased to offer the first commercially available complete (top and bottom) carbon fiber plenum for the E39 M5. Borne of the S62's illustrious racing heritage, our carbon fiber plenum mounts directly to the throttle bodies using stainless bolts in lieu of the stock studs with only thin gaskets in between, thereby eliminating the necessity of plenum plates altogether. Aside from eliminating heat-retaining metal under the plenum, this has the advantage of allowing us to make the plenum top taller, increasing the internal volume of the plenum, without changing the overall height of the plenum or creating hood clearance problems. Similarly, our plenum eliminates the four internal mounting stanchions as gratuitous (given the strength of the carbon fiber), thereby creating additional internal volume. Increasing the height of the plenum top also benefits users of our carbon fiber velocity stacks because it avoids having to "clip," angle and shorten the Cylinder 2 velocity stack. (Early adopters of our carbon fiber velocity stacks wil receive a complimentary new Cylinder 2 velocity stack with a purchase of our plenum).
Intakes and oil separator holes are made from 6061 billet aluminum, as are the mating rings for the plenum top and bottom. To ensure plug and play installation, the bottom mating ring accepts the stock plenum gasket, and aluminum hose bungs are used for the idle air control valve air intake and the plenum oil drain (can be upgraded to AN connectors of your choice if you want to replace the stock rubber hoses with braided or other aftermarket hoses).
As with all of Partee Racing's carbon fiber products, our plenum is made from aerospace quality pre-preg carbon fiber that is baked in our self-designed and built autoclave, formed from molds cut with our CNC router, and finished by hand in our paint booth, all in Partee Racing's Danville, Virginia shop (near Virginia International Raceway).
The best part: Unlike the previously available custom carbon bottom plenums designed for race engines, this plenum is affordable, with an introductory price of $3k for BOTH top AND bottom. And for those who want to go deep, we will throw in a set of our carbon fiber velocity stacks for another $2k. So for $5k, one can have entire plenum and a set of our stacks. That is an introductory price only and is not permanent.
Renderings below. Happy to answer all questions either via email (peters@parteeracing.com) or by phone (917-683-9439).
To purchase, go here: BMW E39 (S62) M5 Carbon Plenum
--Peter
#2 ·
Thanks a lot for putting the hard work in and producing such a beautiful product. This community is truly grateful for your efforts. It's my honor that I'm getting the opportunity to work with you on amazing projects like this.
#4 ·
Looks fantastic!
owns 2000 BMW M5 DUH!
Reactions: herrubermensch
#10 ·
Bravo Peter.
Finally the CG of the S62 will get better with this option
and the most important ~20-30F less heat !
Anri
#11 ·
Bravo Peter.
Anri
Would love to hear more about the decrease in overall heat, as I was thinking about this last night laying in bed (you know, when you see an amazing carbon fiber plenum for your engine, you just cannot sleep!) and was wondering if it would increase or decrease the heat soak? My theory in my own head was that it may increase as the plastic plenum seems to be more of an insulator than the thinner carbon fiber, but I know nothing about either material's insulating characteristics, I was really only considering the thickness of the parts.
What are the facts involved with a decrease in intake temps, other than the fact that the heat soaking plenum plates are no longer necessary? was that the only factor?
#12 ·
I'd say there are too many variables to properly answer the heat soak question. Plastic is a good thermal insulator but after heat soaked it will be, well, hot. No different than CF or any other material really. Depending on CF used it can be made either a thermal conductor or insulator. Everything else constant thinner walls will increase heat transfer.
Bottom line... best would be to run back to back tests and measure what manifold air temp looks like. Perhaps Peter already knows the answer?
#13 ·
the answer?
Hi,
I have done a test on inline-6 Cast Aluminum
vs Fiberglass, the heat dissipation is day and
night on aluminum vs plastic/carbon. My test
showed at peak around 30F difference. Much the
same as cast iron block vs aluminum block.
Have not measured the thickness of the S62 lower
cast alu plenum but for sure the temps will be
better with this Carbon no doubt about it.
Anri
#15 ·
Anri beat me to it! The main benefit heat wise is the minimization of metal under the intake air. The more metal, the more heat retention compared to carbon. Delete the heat exchanger, delete metal plenum plates, delete the metal plenum--all of that provides a significant drop in intake air temps. I have not done a one to one comparison, but probably will do so at some point. But its basic race car technology that we use on all of the DP motors. We DO put a thin layer of aluminized heat shield on the bottom of the carbon plenums of the race engines for additional heat deflection, and there's nothing wrong with that, but it is lagniappe compared to the difference of moving from a metal lower plenum and metal plenum plates to a pure caron setup.
All of the foregoing is what convinced me to go this route, but the plenum also is significantly lighter and looks very cool. Our lead fabricator/designer, Chris Knerr, is about to welcome his second child into the world on Monday, but once he returns, we'll put together and post some in-car pics and if we can, we will log some temps, though the difference will be greatest in summer.
--Peter
#18 ·
Absolutely Peter I do the same with the Gold or Silver
thin foil or heat shield the job of it is to stop/back up the radiant
heat used in Motorsport for ages.
One can put this foil on both intakes and can benefit
from it but I was strictly pointing how much better the Carbon
bottom plate is vs cast aluminum.
I am sure candidate for your Intake for my S62 in my E31. Need
to remove every pound so that I can get close to the M62 weight!
Anri
#20 ·
1. Standing alone, I don't think the increased volume of the plenum is something the ECU can't adjust fuel flow to accommodate. But combine that with headers and a good intake, and yes, you will need a tune. I always recommend a tune when making a material change to a motor, even if it is just a bolt on, such as a plenum. If you are planning multiple changes, I'd do them all at once, then get a tune.
NB: We are working very hard to bring tuning in house with a very well known and respected tuner in this community. Stay tuned! (See what I did there?)
2. Yes. Every DP motor sports essentially the same plenum, albeit without a lot of the connections necessary for a street motor (such as the elbow for the IACV). I three or four used carbon race plenums in my shop at any one time. They hold up quite well.
--Peter
#22 ·
Indeed! Maybe next year, we'll have a car with one of our engines at one of the races held in connection with the Rolex 24. We did recently acquire an F82 body in white, stich-welded with a Fall Line Motorsports cage, fuel cell, and carbon roof and doors. Yet another project I need to finish! Guess I need to build another few S55s, huh? (We've only done two!).
--Peter
#24 ·
It is not designed to hold boost. It is designed for NA applications. That said, the carbon will hold a fair amount of boost, probably more than the stock plastic plenum. My only concern is the billet attachments. I'm sure it would hold low boost (6-8 psi), but no representations about anything higher. Would have to experiment and see. Again, this was NOT designed for "boosted" applications.
--Peter
#25 ·
^^ If you watch one of the recent videos from M539 restorations when he installed a carbon box on his E60 M5, in one of the shots he has the hood open and is revving the engine and you can see the carbon plenum slightly deflecting in the reflection on top with each rev.. he also comments about how the carbon flexes so much, it was impossible to get any of the badges to stick to it with only 3M tape and had to use the Reinzosil stuff he uses sometimes on gaskets to actually make the badges stick without popping off due to the carbon flexing - possibly because he painted over the carbon finish?
Here it is! it's really just ever so slight..
see the 21:00 mark where he explains about the badges and was only using the top piece of carbon for the plenum
Then watch at the 26:25 mark and you can see the new full carbon fiber plenum flexing.
#28 ·
Had an amazing time this past Monday during my unplanned, last-minute trip over to Partee Racing. Got an insider's look at the Carbon Fiber production process and had the chance to chat with Christopher D Knerr and the one and only, Peter Partee @herrubermensch about some FAQs regarding the manufacturing process and design for the E39 M5 Carbon Fiber Plenum. Peter is always generous with his time and gave me time even though it was a last-minute trip since I was in the area anyway.
With full-scale production now in full swing, seize the opportunity to grab the plenums at their presale price. Plus, don't forget about the additional discount applied when you purchase both the plenum and stacks as a kit. In my view, the E39 M5 plenums represent the ultimate modification to hit the market for our cars. The wait may have been long, but it's undeniably worth it. This marks a significant milestone for the E39 M5 community.
Here is a short video I recorded displaying the production process for the plenum with commentary from Peter Stone Partee Sr
#31 ·
My order is in and I'm in line waiting for the whole shebang to be built. :) Will be going on the track car build.
#33 ·
Peter,
This is awesome. I think you've done it right, and with the DP knowledge fueling what you're doing for the consumer market, this is going to be a hit. All the best!
