My problem here is that I only drove the vehicle 1300 miles since the last oil change 29 months ago. I've been reading that the oil should be changed yearly at any rate. Thoughts?
Thanks for your question. In our opinion, yearly oil changes are unnecessary for modern engines if they're not driving much. They're sealed up well from environmental factors, so things like corrosion
and condensation/contamination aren't really concerns like they were back in the day. Based on this report, we don't see any signs that the engine had any trouble going a couple years between oil changes, so you can feel good about basing your oil changes on mileage as opposed to calendar time. We still think 3,000 miles or so would be fine for next time, even if it takes a while to get there.
Sincerely,
Blackstone Laboratories
Btw, what's the cutoff for modern engines? Looking at the vehicles I have on my account, do the 2001 740iL and the 2002 M5 also fit into this category?
We tend to consider anything from the 90s on to be modern, so both your other engines would fit too, so doing mileage-based intervals should be fine for them as well.
Sincerely,
