I am getting a P1346 - misfire at startup on cylinder 3 code on my car that I am having trouble diagnosing. So far, I have moved the spark plugs around as well as the coils and the code hasn't moved or changed. I also tested the coils for ground, power, and pulse as well as the sparkplugs (which all are working fine). The harness checks out the same so I don't believe I need a new coil or even sparkplugs. I have ordered one injector thinking that would be the only other thing that could fail and will replace hopefully this weekend or so...
Has anyone experienced anything similar with only 1 cylinder having a misfire at startup code? I have been reading about oil separators and CPS and such but most of issues contain multiple misfire codes.
Any thoughts?
Any thoughts?
