M6 Rod Bearings
2 reading
82K views 144 replies 38 participants last post by  M V10 Power
#1 ·
New to board as I am considering buying an E60 M5 or E63 M6 if I move to Europe next month. Been doing as much research as possible and searched the M6 part of the forum as much as possible but found nothing. Wanted to see if the M6's have the same Rod Bearing issues as the M5's. I would assume so since they are the same engine, however, as mentioned could not find anything when searched. Thanks in advance for any feedback!:M5thumbs:
#89 · (Edited)
Hey Guys, So im bring back this thread...
I have a 08 m6 SMG that I am the 3rd owner of(i think) I bought the car at 56k and now have put on about 2k miles. I am thinking about getting the rod bearings done as a preventative maintenance and while I get my decat headers installed.
Questions, any recomendations for good /affordable mechanics for the jobs?(I'm in the NYC area) also, what kind of bearing and other parts would I need ideally to forget about them for a while? im confused as Im reading about different part names like BE bearings and WPE treated bearings and ARP rod bolts? Sorry, Im unfamiliar with the technical side of things.
#97 ·
No sorry.
Nope. No warning signs. But I was the 3rd owner and I had no clue how the others had driven the vehicle. And... of all the BMWs that I've owned, this one has hit all the classic pain points for the E60 M5. I decided that it wasn't worth the risk and I moved up the Bearing job to this year. If I hadn't, I'm sure that I would have had a destroyed engine sometime in the next year - and it could have been easily within the next week given how some of the bearings were down to copper and starting to curl.
If the damage has been done and the bearings are already down to copper - it's not likely that you'll see anything in an oil test. BUT... because they are now thinner and subject to the same forces, it's likely that they're starting to curve a little more headed to a spun bearing.
Yea, i am just gunna have to go and do it for ease of mind. Its always in the back of my mind. Thanks!
#100 ·
Quick point - when in 2008 was your car made if it was late it will be a 3rd gen s85 with the better bearing already fitted would it not?
Harder, not better.
Soft bearing + oil starvation = bearing wear
Hard bearing + oil starvation = crankshaft wear
The change wasn't BMW trying to fix the problem, it was BMW removing lead to comply with regulations...
#103 ·
Ok cool but if you look at the poll on this forum 05/06 have about 10x as many failures as 07 surely that means the change may have fixed something
...or the 05/06 hit high miles sooner, and their failures acted as a warning to 07+s.
Not to mention that there are probably more 05/06s than other years put together. Hmm... per howmanyleft.co.uk stats for new registrations of M5s in the UK, 1300 were 05/06 and about 400 were 07+.
I've got an 06. Warnings from this forum prompted me to switch bearings at ~70k. Luckily mine's relatively low mileage (and, perhaps, hasn't had too hard a life).
There's just not enough information to establish cause and effect.
#107 ·
Be Bearinga and BE ARP bolts apparently provide the proper gap for 10W60 oil. As such, the risk from cavitation and oil starvation is greatly reduced.
JColley has removed them from a car after 7K miles (IIRC - r 5K miles?) that show NORMAL wear. That's all anyone could ask for.
I actually used WPC bearings with BE bolts.... it's all bout how you maintain your car guys... question to ask yourself "how often do you change your oil" Do folks beat their car to death right at the cold start.
I run something totally different than MOST. I run Schaffer's oil 5/50 WITH ZINC which helps solve bearing issues...
Wanna see what original bearings look like after 113k miles? I've seen folks on the forums with half my mileage and bearings have nothing but COPPER all through every bearing...
Maintenance is key folks, change your oil every 3500 miles especially if you drive these cars hard. I used to use liq moly 10/60 and felt sluggish
I also run KP oil filter
#106 ·
I was led to believe the the newer bearing have a better clearance than the old 88/89s by a lot of googling this seems the case - also lots of changes I.e. Oil jet improvements should help shouldn't they?
2009 to 2010= version 3:
-All of the version 2 parts
-702/703 bearings (Troy has changed six 2009 motors, and all of them had the 702/703 bearings)
-Longer Set Bolts for Cylinder Head 2x (5/08)
-Intake and Exhaust valves different. p/n changes specific to Engine numbers starting with 2xxxxxxx (8/08)
-All Valve Collets and upper spring plates changed for above^ (8/08)
-Larger bolts for block to hold upper oil pan together to main block stronger (1/08)
-Piston cylinder oil jets are better design
#112 ·
Precisely my friend. It allows car temps at cold start to warm up faster and with thE Schaffer oil it has ZINC which the 10/60 lacks completely. Also with using that filter that was developed by KP for our cars it allows oil flow to be more efficient and effective on cold starts. I guarantee you will see a difference in power with this oil.
I use this oil in my X5M and all my 330s as well. Mainly because of the Zinc.
#113 ·
Brilliant- only thing is I use my m6 as my dd and mainly for long highway runs so it really only gets thrashed every so often so I only do the oil every 10k (I have both sump bungs as well so it can drain properly!) will that oil work ok at those intervals?
On a side note I'm not trying to disprove they fail the evidence is there simple - and my first engine (gen1) failed at 45k due do bearings. My point I was trying to make is if the risk is significantly reduced with the newer engines
#116 ·
#119 · (Edited)
[QUOTE
As for KP yes, it was solely made for Troy Jeup. Only can buy through him. They made a smaller production just for Troy. I've been one of the few of performance ///M cars running it and it's phenomenal
QUOTE]
I called them directly and they said they did not make this filter for him. It's been available for sale directly. See the link above that I posted above
#121 ·
[QUOTE
QUOTE]
Gotcha. Well there you guys go, got some options to get filter...
Check out this video as well. This is the brand of oil I run and it's proven!
https://youtu.be/hDF1zcaxrNU
#125 ·
Interesting to read that later cars have all those updates... I have an E63 MY 2009 with production date December 2008. Around 23k miles now and I can only count to 3 oil changes that I know of for sure.
Do you guys think I´m good until 50-60k?
Are you asking if you good for oil change until 50-60k from 23k? Hmmmm I would say personally that is bit long of a wait... How hard do you drive your car would depend on how frequent you change the oil.
Personally I won't wait that long
#123 ·
Originally Posted by M V10 Power View Post
You are
correct these engines def run a little hotter for sure. The issue is 10/60 is its soooooo thick that bulk of Rod bearings issues is not because you drive car hard BUT at cold start and start up. That 10/60 is like sludge at a cold start and takes almost two min to filter through OEM filter and rods that it has "starvation" then MOST want to go hammer on it immediately BOOM! Chips of metal over time chip away and away. I have a 08 M5 113k original miles and my car NEVER had metal shaving ever. I just did my Rod bearings 3 weeks ago and if you see my bearings compared to cars with half my miles it's night and day.
N I'm fully modded FBO Dave it hard AF. But I use Shaffer 5/50 with zinc which is perfect for Rod beearinfs. Yes it has more zinc for sure but that's the point.
It's an OLD myth that to much zinc kill cats. Please see video
https://youtu.be/PgXRNEukzn0
Also please see my bearings at 113k. I used to use liq moly for a little time 10/60 not any more and will never got back.
V8TT Motors get just as hot and they all use 5/30
The more I look at this issue the less sure I am of the causes of the wear.
I'm in the UK and I bought my 2006 car at 90,000 miles 18 months ago. I am the 5th owner and it had only been serviced by BMW dealers with TWS. The oil had been changed on average every 16,000 miles, so when the OBC said it needed it.
So with 5 owners there's not chance they were all sympathetic and warmed it up before working it hard. The type of use it had won't have been the same - short /long journeys. It lived in Scotland so would have regularly seen 10F in the winter.
@ 90,000 miles I changed the bearings and they looked just like yours, no worse at all. It had 289/288 shells so they hadn't been done before. I replaced the bearings with 702/703 OEM shells and bolts and will continue to use 10W60.
Now I do warm the car up, I keep it between 2 & 3,000rpm until the oil temp hits 180F and don't use full revs until the oil hits 200F.
What I do know though is. If this engine had been fitted to a Ferrari or a Lamborghini, which is about the only other place you would see a 5 litre naturally aspirated engine giving 100+ BHP/litre. There would not be one whisper of moaning about rebuilds being needed at 60,000+ miles. It would be normal!
BMW's biggest mistake was fitting a supercar engine to a shopping/family car that looks just like a 520d. People bought them expecting them to have the running costs and reliability of that 520d
#130 ·
So which bearings should one order....are these the options:
WPC Coated OEM
BE Bearings
OEM
Bolts:
ARP
OEM
Planning this now, but would like the new bearings to be an improvement i.e. longer lifecycle.....also prefer the older composition where a Blackstone will highlight wear.
#131 ·
WPC Coated OEM
BE Bearings
OEM
Bolts:
ARP
OEM
#142 ·
Yes, I must admit I was'nt comfortable with the car since I was afraid of the bearing shells status.
Copper just shows up actually, The kind of strips we can see on the surface still show some lead in the copper exhibits.
However I am a bit concerned on what could be the reason why the bank 2 bearing shells seem two times more worn than bank one's.
#145 ·
As tell people “gotta pay to play” these cars are CHEAP as heck now to buy BUT unfortunately not everyone has the $$$ or take the maintenance seriously and BOOM there goes a motor. It’s expensive to maintain these cars and it’s also crucial that it’s done on time
