I cant' find a clear answer to this question. Front & rear?
You guys can complain all you want about the stock M5's brake lacking on piston count, but performance wise they are quite impressive...
Unless you do some serious track duties, they hold up more than fine.
Also, the reason the M5 calipers have so few pistons is that they are sliding calipers. This is what I feel is most disappointing, as I feel that if M division had Brembo come up with a monoblock, opposed piston caliper to clamp the stock discs (which are massive), the braking would have been phenomenal.
But to simply point out, more pistons does not mean better braking. I have a full Brembo setup in my G35 (4 piston front, 2 piston rear - and they are the monoblock opposed piston style) and despite my G35 weighing a full 500lbs lighter with after market slotted rotors and high performance (borderline race) pads, our M5 has (in my opinion) better brakes.
Also, I believe that Rotora brakes for the M5 with their massive 12 pistons do not perform as well as a Brembo GT setup with "only" 6 pistons.
