HELP! Vanos replacement advice needed, is my vanos capoot?!
24K views 100 replies 14 participants last post by  M5aud
#1 ·
Hi guys looking for advice from owners who have gone through the vanos replacement and diagnosis procedures.
My car sound like this:
YouTube - M5 Idle engine sound - good or bad???
I am guessing the vanos is capoot!
I am guessing these parts are needed to "refresh" the vanos units and their problematic woes.
RealOEM.com BMW E60 M5 VANOS CYLINDER HEAD MOUNTING PARTS
11367841074
11367841073
11367841072
11367841784
11367834553
11367838669
11367838670
Any advice would be much appreciated as I dont wont to waste money just replacing everything, I dont want to sell the car as I would waste a large amount on stamp duty etc when I can just fix it and enjoy it.
Thanks guys!
#8 ·
I have replaced the vanos on my E46 M3 but that was because of the solenoids packing it in. You really need to take it to a dealer, and get them to diagnose it. However don't buy your vanos off BMW Australia if it comes to that. The E46 M3 vanos retailed at $6300 but I bought mine from BMW UK for $2300 exchange.
I strongly suggest that you use www.bmminiparts.com as you will find that it is WAY cheaper to buy from BMW UK than BMW Aust for most items. However if you still want to buy off BMW Aust contact me and I will speak to my contact in Melbourne.
Good luck with it and post back what you find. PM me with your email address if you want to talk off line.
#9 · (Edited)
Test drove an 08 build today as suspected and read they make no diesel sound on operating temperature. Also went in an 9/05 build funnily enough it was identical. Same year build with more klms and it was exactly the same with vibration and diesel idle tone original owner and he stated that it has always sounded the same from day one.
#18 ·
I am dealing with a vault in WA, they are not giving me any information as to whether they did recalls. A month ago they stated they have never done one, then yesterday the assistant service manager stated he cant remember when they last did one. The difference in conversation tells me something has been done before but as per usual they play the denial game. Last time they did this with me I had my lawyer write a nice letter to BMW Australia and they paid to repair my E46 M3 rear subframe for free under goodwill. We provided the evidence via BMW NA case findings and I also had panel beaters in Australia on my side to provide evidence, with the E60 M5 I am having trouble finding proof of repairs for the vanos system in Australia.
If anyone can get some evidence or have someone willing to be a reference to having a repair under goodwill please contact me.
#20 ·
I know your problem is a lot bigger than just a oil line replacement but could this have caused it in the first place if it wasn't replaced.
Also meant to mention I read in the latest BMW Car magazine that BMW U.K are going to release and sell various extended warranties for all BMW's regardless of age and mileage (sounds to good to be true)
see Home
I called BMW Australia yesterday to ask if they will also be offering them and I was told to check back with them in a couple of months as they are looking into it.
#21 · (Edited)
Big thank you to M5 VTEN I have emailed the pdf from the 5series link to the manager.
A metal clacking noise is apparent only from starvation as it should have been well lubricated which is where the oil pressure line most definately would have caused my problems.
Just cant believe there is no one on this forum openly admitting they have had the recall for the pressure line done or that there is a vanos recall on the early models in Australia.
#23 · (Edited)
M5aud....
Check out this thread I found. It contains recalls on the M5 for 06-07
http://www.m5board.com/vbulletin/e6...ulletin/e60-m5-e61-m5-touring-discussion/113071-list-recalls-my2006-2007-a.html
Will the dealer do these SIB even though I'm out of factory warranty???
Cant see why not, a manufacture defect is actually covered and warranted by law in the automotive industry for up to 10 years. When I fought BMW Australia over the replacement of the rear subframe in my E46 M3 MY03.5 it was done under goodwill. They by law have to pay for it, as soon as you enforce a legal representative they will back off and assume responsibility.
The above link you have posted is relevant, a lack of oil starves mechanical metal parts and thus causes a wearing metal sound, I believe it is the causation for the ill vanos system.
Please find the details for that service bulletin below with pdf from BMWNA attached.
SI 11 10 05
Engine January 2006
Technical Service
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES BEFORE CUSTOMER DELIVERY OR THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
Service Action: S85 Replace VANOS High Pressure Line
MODEL
E60 M5 with S85 produced up to 11/22/05
SITUATION
The VANOS high pressure line may start to leak engine oil around the flexible hose.
A Service Action will be conducted on all affected vehicles which have not already had the improved VANOS line replaced. Customers will be mailed letters notifying them of the Service Action shortly (copy of the customer letter is attached).
To minimize customer's inconvenience caused by this Service Action, you are being asked to pick-up (and deliver after repair), if necessary, the affected vehicle from customer's home, and provide appropriate alternative transportation.
Customers will be impressed when you return their cars cleaned inside and out and with a full tank of gas. Reimbursement information for the vehicle fueling and valet costs can be found in the Warranty portion of this bulletin.
AFFECTED VEHICLES
This Service Action involves M5 vehicles with S85 engines which were produced from the beginning of production up to 11/22/05.
In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of the DCS (Dealer Communication System). Based on the response of the system, either proceed with the corrective action or take no further action.
The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.
Model
M5
B581062 ďż˝ B583155
CORRECTION
On the affected vehicles, replace the VANOS high pressure line between the pressure accumulator and connecting lead.
PROCEDURE
Remove the front underbody protection (refer to TIS RA 5147490).
Remove the fan cowl with electric fan (refer to TIS RA 1711035).
Remove the drive belt for A/C compressor (refer to TIS RA 1128050).
Remove the alternator drive belt (refer to TIS RA 1128010).
Disconnect the secondary air hose fitting and remove the water pump pulley
Carefully loosen the VANOS line at accumulator, to release any residual pressure, and then remove and replace the VANOS high pressure line: PN 11 36 7 838 670) ďż˝ identified as #1 on the illustration.
The required tightening torques can be found in TIS under: 11 36 Variable camshaft control. All sealing rings must be replaced.
Important: Only copper sealing rings must be fitted.
Reassemble all removed parts.
Verify that the engine oil level is correct and top off as necessary.
Note: When fitting the new line, make sure that there is sufficient distance to the cable tie on the secondary air hose on the bottom of the engine. If the cable tie is fitted with the lock facing upwards (towards the VANOS high pressure line) it must be replaced. When doing so, make sure the cable tie lock is positioned at the bottom (see illustration to the left).
PARTS INFORMATION
Part Number
Description
Quantity
11 36 7 838 670
VANOS pressure line
1
07 11 9 963 129
A12x15 Copper sealing ring
6
61 13 1 367 599
Cable tie (if needed)
1
07 51 0 009 420
Castrol TWS 10W-60 motor oil
1
LABEL INSTRUCTIONS
This Service Action has been assigned code number 459. After the vehicle has been checked, and corrected if necessary, obtain a label (SD 92-278) and:
emboss your BMW dealer warranty number in the middle of the label (1);
punch out code number 459 printed on the label and,
affix the label to the B pillar as shown.
If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one because a number from an underlying label could appear in the punched-out hole of the new label.
WARRANTY INFORMATION
Reimbursement for this Service Action will be via Campaign Entry.
Defect Code
00 11 25 02 00
Work Package #1:
Replace VANOS high pressure line,
Vehicle in dealer's inventory
(Vehicles not retailed).
Labor Operation:
00 56 725
Labor Allowance:
23 FRU
E60 M5
Part Allowance
11 36 7 838 670 ďż˝ pressure line
Qty = 1
07 11 9 963 129 ďż˝ A12x15 ďż˝ Copper sealing ring
Qty = 6
61 13 1 367 599 ďż˝ cable tie
Qty = 1
Sublet Allowance
Up to 1 liter Castrol 10W-60 motor oil
$10.01
Sublet Code
4
Work Package #2:
Vehicle in customer's possession
(Vehicles retailed).
Labor Operation:
00 56 099
Labor Allowance:
25 FRU
E60 M5
Parts Allowance:
Qty = 1
Qty = 6
Qty = 1
Sublet Allowance
$10.01
Sublet Code
4
RE-FUELING COST
BMW of North America, LLC, will provide reimbursement to have the gas tank topped off once as required, for each vehicle affected by this Service Action. Attach the appropriate fuel purchase receipt to the repair order to document cost.
Defect Code
85 99 00 66 NA
Refuel E60 M5
Affected by this Service Action
Sublet:
Actual cost to top off the fuel tank
Sublet code:
4
VALET COST
BMW of North America, LLC, will provide reimbursement for vehicle valet services (pick up & delivery) for each vehicle affected by this Recall Campaign. Attach the appropriate receipt to the repair order.
Defect Code
99 99 77 77 NA
Valet Service for E60 M5
Sublet:
$25.00
Sublet code:
4
RENTAL VEHICLES
Service Loaner vehicles, for this Service Action, should be utilized for alternative transportation needs to promote customer satisfaction.
Please note that the Warranty Policy and Procedure Manual in Section 9 on Page 8 and SI B01 07 03, spells out, for those participating BMW centers, the opportunity to self-authorize a rental vehicle if needed by your customer for this type of repair.
