Front Suspension - Proper Torque Values
12K views 2 replies 2 participants last post by  woods
#1 ·
Hi All -
I've searched the interweb high and low with no success and I don't own the Bentley manual for the e34 so if somebody could kindly let me know what the proper torque values are for:
- 19mm Strut to Steering Knuckle bolt
- 19mm Caliper Carrier bolt
- 12mm Strut Bearing nuts
- 22mm Bolt for the thrust arm
- Ball joint to steering knuckle torque for thrust arm
- Lug bolts - are they 74 Ft lbs?
...it would be much appreciated...
Thanks in advance -
#2 · (Edited)
Hi Woods,
If you're going to do this sort of work, you should really get yourself a Bentley Manual. There are a number sites on the web, probably seriously infringing copyright, where most of the Bentley Manual is available for download.
Not sure what consititutes a "steering knuckle" in a McPherson Strut ?
If you're talking about the 3 bolts that secure the steering arm to the bottom of the strut housing - 110Nm Bentley pg 310-6 use Loctite 270. They do work loose if you don't !
Front Brake Caliper to Strut Assembly - 110Nm Bentley pg 340-6
(Caliper to Carrier is 35Nm.)
Strut Bearing Nuts (Strut Assembly to body [3 nuts]) - 22Nm Bentley pg 310-3 DO NOT REUSE OLD LOCK NUTS !
Thrust Arm to Connecting Crossmember - 127Nm Bentley pg 310-10
Thrust Arm Ball Joint to Steering Arm - 93Nm Bentley pg 310-10
Lug bolt (Wheel Bolts ?) - Road Wheel to Hub - 100Nm Bentley pg 310-10
That should keep you entertained for a while.
If in doubt, there is table in the front of the Bentley Manual that provides default torque settings for nuts and bolts in these cars, when values are not specifically stated.
Reg.
#3 ·
Much appreciated...
For the number if times I've posted "buy a Bentley on BMW-related internet forums" - I will admit some slight embarrassment. yawnnnn I usually just grab torque values for similar sized bolts my E36 bentley but wanted to be 100% sure about these particular bolts for obvious reasons....
Cheers.
