Dct swapped 2006 BMW M5. Extensive list of maintenance and modifications is below as are videos of the dct swap in action. Everything works as it should. One of probably only 2 fully working dct swapped e60 m5's in the country. I also built the other one.
I am only selling because I need cash to close on my house next month
Pictures here since there is a limit to what I can post - https://photos.app.goo.gl/c9Z8SwYJfx1wGN5u8
This is a pretty long list of work I've done.
Maxxecu pro
E90 m3 3.15 differential
E90 m3 dct transmission
E90 m3 dct flywheel
Audi R8 coils
Ferrari 599 fuel injectors
2x Mopar hellcat fuel pump control modules (factory EKP removed)
2x AEM 340 fuel pumps
30 row transmission oil cooler
Bosch knock sensor x2
Spark plug part # NGK 97312 ILKR9Q7G
GM flex fuel sensor
Speedsty wake up relay module
Idle actuators modified with VW diesel throttle body control module
Vanos oil pressure sensor
Custom e-box fan
Driveshaft extended 2” for dct swap
Android cic screen
Velocity stack intakes
GM intake air temp sensor
Dinnan lowering springs
Rpi race exhaust
Supersprint headers
Under drive crank pulley
Amsoil 10w60
Amsoil dct fluid
Lucas 80w140 gear oil
Rod bearings done at 85k (BE bearings with BE rod bolts), checked at 120k when vanos pump was replaced
120k
New OEM vanos pump
New aftermarket vanos solenoids
New OEM vanos hose
New battery
108k
Steering rack input shaft seal
Front control arms
Rear tires - Continental DWS
Throttle actuator gears replaced
60c thermostat
Lambda sensors x2
New starter
Added drain plug to front of oil pan
AC compressor drive plate replaced
93k
Front tires - Continental DWS
Things Removed
Air pump system
Pcv system removed
Evap bypass
Brake pad sensors bypassed
Things that don't work or need to be addressed
Oil level on gauge cluster - it works in CCC but not on the gauge cluster.
Ride height sensor for adaptive headlights
Audio from Android unit. Regular radio works fine
Rear diff bushings
Alignment
Thermostat for dct cooler would be a good idea
Center console and arm rest leather have typical wear
Maxxecu pro
E90 m3 dct flywheel
Audi R8 coils
GM flex fuel sensor
Custom e-box fan
Android cic screen
Rpi race exhaust
Supersprint headers
Amsoil 10w60
Amsoil dct fluid
120k
New OEM vanos pump
New OEM vanos hose
New battery
108k
Front control arms
60c thermostat
Lambda sensors x2
New starter
93k
Things Removed
Air pump system
Pcv system removed
Evap bypass
Rear diff bushings
Alignment
