Pretty sure I've already answered my own question here but want to bounce this off you guys before I drop $500-700 on new brake parts:
Symptom - brake shudder that I feel during light to moderate braking, most apparent in the 40-60 MPH range. Less pronounce during light or pretty hard braking, seems to worsen as brakes warm up. Not so bad first stop of the day.
Think I feel it through the whole car including the steering wheel, although maybe not so much in the pedal itself. That said, when I brake with only holding the wheel very lightly, I still feel it a lot but I don't see the wheel turning right/left very much at all.
Just did entire front suspension, including all new control arms, dampers, top mounts, steering links, etc. The whole shebang, maybe 100 miles ago. Makes me think it's extremely unlikely that the brand new tension strut bushings are bad (and yes I tightened them down with the weight of the car on the wheels up on ramps). Too hard to compare the shudder to before all this work though, as everything was original with 100k and all so loose/vague I honestly can't say if *just* the brake shudder is better, worse, or the same.
Rebuilt the calipers along with SS brake lines and the bronze slider bushings while I had everything apart.
Have not yet changed pads/rotors as the ones that came on the car looked good; smooth, lots of meat left, etc., but I suppose that's the next logical step. Will continue to double check to make sure I got everything tight, but I can generally trust the thoroughness of my own work.
Any other ideas, or just round getting EVERYTHING new with some new quality pads and rotors? Any chance the bronze slider bushings can cause this issue? Thanks!
