Been searching online, and RealOEM.com, need clarification.
Does our brake pedal have a bushing attached to it? Some sort of flex or clutch bushing attached to the pedal?
If so, does it tend to wear out over time (I have 63K miles)? I ask because I'm trying to troubleshoot a brake pedal vibration/pulsating i'm experiencing that has yet to be resolved since April '12.
my threads:
http://www.m5board.com/vbulletin/e60-m5-e61-m5-touring-discussion/215880-feedback-when-braking.html
http://www.m5board.com/vbulletin/e6...ing-discussion/213678-question-cyclical-vibration-brake-pedal-when-braking.html
And before I get asked:
I have all new rotors, new brake pads (bed ins), replaced front control arm bushings, replaced a bent rim, tires have been balanced and aligned, and brake fluid has been changed with the past 6 months. I've even swapped tires and rims with a fellow owner on here, so it isn't indicative to rims and tires. So I've ruled all those out. It isn't the DSC malfunctioning, so now i'm wondering if it's either the ABS system not functiniong properly, or, based on research online, a bushing in the brake pedal might be wearing out.
Thanks!
my threads:
Thanks!
