First timer here on the forum. Anyway, I also suffer from the annoying vibration, most significant around 2k and 3k rpm. I haven't got any codes related to misfires or anything else and my friends seems to ask is this running on all cylinders while reving the engine standing still. I've already done something to find the culprit.
I've replaced my flywheel and clutch assembly, had my exhaust system disconnected from the chassis during engine running (except from the manifolds) and the fan (viscous coupling) disconnected. It feels like something is out of balance. No popping from the exhaust, so I trust no misfires either.
I know my viscous coupling bearing has play, the water pump axle has play and one of my belt pulleys creates a noise at cold ambient temperatures. No other problems whatsoever. Vanos solenoids are replaced about a year ago along with the MAFs.
I'm thinking next about checking the harmonic damper, maybe running my engine shortly without the belt also. I really can't find any other reason for the vibration, since my flywheel (one of the heaviest parts) is replaced. Also no codes. Play in connecting rod bearings seems a bit far fetched, since so many other suffer from the same symptoms.
But before that, a full body paint job has to be completed
