[EDIT: downloadable PDF instructions with images, see attached files at the bottom of my post]
Ok so I posted screen shots of the main i-drive hidden menu in another thread and we all got excited about finally having a true live GPS speed view. As those who tried found out it was only a snapshot of the speed when the page was loaded and you had to click next or previous to get it to updategrrrrrrr
I refused to be defeated so did some searching round and have now found not one but two different ways of having a live GPS speed on show
Here we go...
1 - Hidden Navigation Menu
It appears that there is a hidden Navigation Menu showing very similar information to the main i-drive hidden menu but this one shows live GPS speed in km/h. To access the menu follow these steps:
2 - Hidden OBD Menu
There is also a hidden menu that you can access using the trip reset button on the instrument panel but it's slightly more involved and complicated to access but I've found some very interesting things in there including:
- via hidden navigation menu
- via hidden on board display [dash] menu
Here we go...
- From the main i-drive menu select the navigation screen by press the i-drive controller right (east).
- Once in the navigation section make sure the top sub-menu shows navigation and not information, etc then go to the bottom section and highlight "Map Indicating Direction of Travel" but don't click on it.
- Press the i-drive controller to the top-right (north-east) corner and hold it there for 10 seconds and then release.
- Rotate the i-drive controller right (clockwise) 3 clicks.
- Rotate the i-drive controller left (anti-clockwise) 3 clicks.
- Rotate the i-drive controller right (clockwise) 1 click.
- Rotate the i-drive controller left (anti-clockwise) 1 click.
- Press the i-drive controller down (towards the ground).
- You should now see part of the hidden navigation menu
Just push the controller to the right (east) to highlight the top sub menu where you can chose from the following sections- Position (ignore the speed in here, heading, etc)
- GPS (the gps speed, visible sats, )
- Guidance (info relating to route selection)
- System (blank for me)
- Map (blank for me)
- Simulation (you can pull down (south) to select between a few demo options but I can't get anything to work for love not money)
2 - Hidden OBD Menu
- live GPS speed in km/h
- current rpm digital read out
- current rev limit rpm's.
