Hey peoples,
My M5 is currently in the shop following the damage caused by the towing company, and as part of the repairs, I requested that they do a compression test.
The results seemed completely wrong with their quote of 110-120 PSI on all ten cyls. I asked "are you sure? its a 12:1 motor?" she said the mechanic of 20 years said the most he has ever seen in an M5 is 120psi.. So I go away unsatisfied and call head office.
She was very sympathetic and understanding and contacted their head tech.
He relays the following information, which they emailed me from their tech shop manuals:
Compression ratio: 12:1
Compression pressure (of all cyls roughly the same value): 6.5-10 bar [94psi-145psi]
She said that he explained as long as all ten cyls lie in that range then the engine is in fine condition.
So hearing that I am happier, BUT I am still confused.
Even my old supra, which is a turbo motor is 8.5:1 comp ratio, I got 165 psi compression test on all 6 cyls.
Now this confuses me :S
A supra is 8.5:1, which I thought would yield a MUCH lower comp test result than a motor at 12:1, and here BMW head office has documentation stating the MAX a S85 will have is 145psi...
Maybe I am completely missing some point here, but I dont understand
I always thought that a 12:1 compression ratio should mean ~180psi, but the fact that the bmw tech manual clearly STATES 6.5-10 bar (98-145 psi) is the acceptable range.
Anyone able to explain this at all?
