Bluetooth Streaming Audio (on the cheap)
61K views 83 replies 34 participants last post by  dmalhi1
#1 · (Edited)
Ever since I added AUX input I've been wanting a wireless solution. You see, our VW has us spoiled. We get in the car, it auto-pairs with our phone and we can easily stream high quality audio without plugging anything in. It "just works".
I wanted to get as close to that as possible in the beast, but wanted to do it on the (mega) cheap. There are plenty of do-it-all off-the-shelf solutions, but I need projects to keep me off the streets.
My requirements:
- Auto-on with the ignition
- Auto-pair with ignition (this is less common)
- Decent audio quality
- Hidden
- Cheap!
*Note* You can do the whole thing without soldering and splicing if you buy a BMW flashlight-to-car-socket adapter, but again, that isn't as fun or as cheap.
Here's how I did it.
Parts List:
0. Aux Input (I am cheating and not counting this towards total cost since I did this earlier)
1. Miccus Mini-Rx This guy is the only one that auto-pairs on powerup! $35
2. Compact USB car charger $5
3. T-Tap splice connectors. I used generic 14-18 AWG deals from Home Depot. I'd try to score less bulky ones if I did it again. $2
Steps:
1. Solder a lead to the positive (center) and negative (barrel) contacts on your USB car charger. Use some sandpaper to get a key on the connectors.
You can crack it open to make sure you get the "live" outer contact, manufacturers save $$ by only wiring one up.
2. Use shrink wrap or electrical tape to tidy everything up.
3. Zip tie the Miccus Rx to the charger. Tidy up the USB cable (or get an even shorter one).
4. Pull the cover under the glovebox (no screws, just a firm straight back motion).
5. Locate and unplug the connector going to the flashlight. Use a DMM to check polarity. My car's purple wire was positive.
6. Run the cables from the contraption down near the flashlight. Splice the leads, plug the connector back into the glove box.
7. Enjoy!
The Miccus includes the solid mini-stereo coupler, as well as a short cable if you prefer. They also supply a USB cable that is too long for my taste, but I am using it for now.
Audio quality is great and it pairs every time. I might expand the project to include an inline headphone amp later.
#3 ·
Thanks for this DIY; it's going to be bookmarked in the guidepost sticky.
Is this the BMW power adapter you referenced?
I'd probably try the Miccus on a 7hr charge alone, as I don't drive it daily. Was there another competing product you considered besides the Miccus?
This probably depends on the phone, but: how do you manage calls while the phone is streaming music? Does your phone send A2DP to Miccus and voice to headset? Or do you just talk on speakerphone? Thanks.
#6 · (Edited)
BMW Genuine Auxiliary Power Adapter, (3 Series after 1999), (5 Series after 1996), (7 Series after 1994), All X5, X3, Z4 : Amazon.com : Electronics Is this the BMW power adapter you referenced?
Yes!
There a bunch of these, but this is the only one I could find that would auto-pair when fed power.
When receiving a call on my iPhone, the audio fades and pauses, and my phone rings using its own speakers. I can then answer and use speakerphone. I suspect if I paired to a bluetooth speakerphone, it'd switch to that rather than the phone on an incoming call.
#11 ·
Nice solution- do you have a DIY link to your AUX Input? I have a Sony Head unit in my Pathfinder and the streaming audio quality from my iphone is excellent so i imagine this solution is a good one depending on the device used at the receiving end.
#22 ·
Hi, thanks for this idea
How do the other non miccus a2dp adapters work since they don't have auto pair?... Once the initial pair is done, do you have to re-pair with a password each time you want to use it? Or can I still just turn on bluetooth on my phone and have it pair semi automatically?
I'm asking to see if there are are cheaper alternatives as I don't need it to pair when I turn on the car. I don't leave my bluetooth radio on 24/7 on the phone. I turn it on only when I need it.
if anything, Ill just get the miccus as it isn't that expensive
#27 ·
Excellent write-up - just did this tonight and it works perfectly.
Reactions: emfunf
#29 ·
Hows the Miccus holding up? Mine crapped out today (after less than a month of use) and I'm wondering if it's because I had it USB charging through an ipod cable with an adapter.
#32 · (Edited)
my iphone 5 connects to both the M5 and the AGPtek via bluetooth so when playing music, navigation, etc. on my phone, it will send the signal through the AGPtek on the AUX setting. when placing or receiving a call, it works just like it normally does. so far the only issue i had was that the AGPtek lost signal once while i was driving so i just unplugged/plugged the AGPtek back into the usb slot. it works great and i think it is another best bang for the buck mod out there. i'm not sure if works on all years of the e60 but mine is an '08 with the usb for ipod integration.
#33 ·
Has anyone attempted to do this with a DSP adapter and leave the bluetooth receiver near the cd changer?
I've seen folks do the DSP adapter and leave the bus wire plugged into the cd changer so you get aux-in on an older car but it's displayed as the cd changer.
I'm worried it wouldn't have enough range placed in the trunk, but it could be easily moved to under the rear seat or center console with a long stereo jack wire.
#51 ·
I recently set this up, got the DSP adaptor, powered it, plugged it into the Miccus RX, left the CD changer plugged in to the IBUS. You leave it on CD mode and it works perfectly. There are no range problems sitting in the front seat.
Note that, as said earlier, it does not act as a headset, it only streams audio, it does not answer telephone calls.
For people that want their bluetooth turned on automatically, and to auto-sync with the Miccus, you could try a solution using NFC tags. Simply get an NFC tag, program the NFC tag to turn on bluetooth and connect to the Miccus RX. Then when you get in your car, drop your phone on the NFC tag, and voila.
#35 ·
I've wondered about this, but was hesitant as I'd want at the very least APT-X support, and some kind of decent output level.
Not many bluetooth devices list their analog DAC type, or the output level they can drive.
Typically I am using an IPOD touch headphone out directly to the CD analog input of the BMW/Alpine C43 radio.
My Galaxy S3 headphone output does not sound nearly as good.
The Crystal Acoustics Blu-DAC-UK looks like it has everything - APTX, Auto Reconnect, and Wolfson DAC.
Not sure if it is worth cutting the wire though as it isn't APT-X lossless.
#39 ·
I had a blitzsafe ipod adapter in my previous car (s2k), and was VERY happy with it. I still receive promotions from the company and they just sent this out...
Blitzsafe - HON/BLUETOOTH V.2X
Thats the link for a honda adapter, but I emailed them asking if they had one for my car (02 pre-AUX DSP) and they said yes, they already have one...
This was the email response:
"I realized not all of our Bluetooth interfaces are listed on our website yet. If you would like to order the BMW Bluetooth, please call me or you can enter it as the Honda or VW, which are listed on featured products if you click on the “our products” button. Just make sure in the notes that you need the BMW BT V.1."
She also confirmed that is uses the CD changer connections in the trunk.
Seems pretty slick for less than $100. Especially due to the fact that the cd changer is a larger paper weight back there...
They currently have a special coupon code for St. Patty's day for $30 off...“BLITZ30”
Prior to getting this email, I had already been running a super cheap BT setup. I broke it down in the link below:
http://www.m5board.com/vbulletin/e3...5-e52-z8-discussion/153461-poor-mans-iphone-diy-integration-10.html#post4367521
Seems like the blitzsafe adapter is for music only, but I've never been satisfied with BT phone functions. They always tend to sound like poo, even in brand new cars, so that doesn't bother me. I think I'm eventually going to jump on that blitzsafe!
