Old 21st September 2009, 00:16   #1
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
DIY: Fog Light Sanding/Refinishing with Pics
DISCLAIMER: Sanding glass is an inherently risky undertaking and I take no responsibility for any personal or property damage that may arise as a consequence of or during the course of this process. This thread is purely for informational purposes!
Since our fog lights are glass, the general consensus is that refinishing them when they get all pitted and gross is next to impossible. I decided to tackle it this weekend so I thought I'd write up a little DIY for anyone thinking about doing this. New fogs are $200 from Tischer but I refinished mine for $40 in materials and a lot of my time. Here is the sorry state my foglights were in when I started:
DIY: Fog Light Sanding/Refinishing with Pics-before-1.jpg
DIY: Fog Light Sanding/Refinishing with Pics-before-2.jpg
DIY: Fog Light Sanding/Refinishing with Pics-before-3.jpg
I originally went with the headlight refinishing process that worked very well for me of wetsanding with progressively finer sandpaper but the wetsanding just doesn't cut it (sorry for the pun) with a material as hard as glass. Here is the very disappointing result of 6 hours of wetsanding + cerium oxide polishing:
DIY: Fog Light Sanding/Refinishing with Pics-cerium-wetsand-1.jpg
It is clear that a more drastic approach is needed for glass, here's what I did:
What I used:
-Stick'n'Sand 5 inch Sanding Discs - 40 grit, 80 grit, 120 grit, 220 grit, 320 grit, 400 grit, 600 grit (I couldn't find any SnS discs finer than 220 grit so I used 3M WetorDry Sandpaper that I cut into 5" circles for the 320, 400, and 600 grits, works the same)
-Stick'n'Sand backing plate for Electric Drills
DIY: Fog Light Sanding/Refinishing with Pics-tools-2.jpg
-Cerium Oxide powder with 3" Felt Polishing Wheel (a "glass polishing kit" that works with any drill, I purchased here: GLASS POLISHING KIT - CarParts Quality Discount Parts and Accessories
DIY: Fog Light Sanding/Refinishing with Pics-tools-3.jpg
-Microfiber towels to periodically wipe and check sanding/polishing progress
-Spray bottle with water to keep cerium polish moist during polishing
Start by removing your foglights from your car. Just (gently) pry off the black plastic cover from the outside of the car side with a small screwdriver wrapped in tape to keep from scratching your paint. Then remove the 8mm bolt holding the foglight to the bumper and pull the foglight housing out. Twist the bulb holder 1/4 turn and remove the bulb. Next, thoroughly clean your foglights with a solvent/degreaser and then wipe down with rubbing alcohol and let the lens dry completely.
THE SANDING PROCESS
Next, start by dry sanding the glass with the 40 grit with the drill until you can no longer see any of the pitting. If your lenses are severely pitted, you may not be able to sand down deep enough to eliminate all of the pits without cracking your lens. Use common sense and if you see your glass getting too thin, stop sanding and move on to the next grit. Since we are DRY sanding, you MUST MUST MUST be careful not to heat up the glass too much. I was only able to sand for about 5-10 seconds at a time in one area of the lens before it got too hot and I had to stop to let it cool down for 2-3 minutes. I can't emphasize this enough, dry sanding generates a lot of heat so you MUST take your time!!!
Here is what my lenses looked like after about 1 hour of dry sanding with the 40 grit (I got all the pitting out except for 1 pit which was just too deep but it's too small to really see anyway):
DIY: Fog Light Sanding/Refinishing with Pics-40-grit-1.jpg
DIY: Fog Light Sanding/Refinishing with Pics-40-grit-2.jpg
The 40 grit will take the longest because you have to keep going until you've corrected the surface. Next I did 80 grit for about 10 mins:
DIY: Fog Light Sanding/Refinishing with Pics-80-grit.jpg
I kept going, using the edge of the sanding pad to sand down trouble spots until I had removed each preceding grit's sanding marks with the next finer grit. Since you'll be looking at semi-circular sanding marks, I rotated the lens 90 degrees each time I switched grits so I could make sure I saw nothing but the latest grit's sanding marks before I moved to the next grit. Periodically wipe down the lens with a damp microfiber to check your progress. Glass is very hard so it'll take 6-10 times more sanding time than plastic would. I had planned on going up to 2000 grit, but after 600 grit, the sandpaper just fell apart, it couldn't sand the glass any more. Doesn't matter anyway, the cerium oxide took care of the rest.
THE POLISHING PROCESS
After sanding, clean the glass with alcohol and let it dry. Next, you'll need to mix the cerium oxide with water to make a paste for polishing. Other people say mix it 50/50, but I achieved the best results by mixing the cerium 60/40 water:cerium into a paste the consistency of yogurt.
DIY: Fog Light Sanding/Refinishing with Pics-tools-4.jpg
Apply to the lens and start polishing with the 3" felt polishing wheel hooked up to your drill. The paste will fling a little at first so start slow and work your way up to max speed. Once the polish starts to dry/chalk up, add a spritz of water to the face of the felt wheel to keep things lubed. After about 2 mins of polishing, wipe off the lens with a damp cloth and check your progress. Cerium is the best thing for polishing glass but it still took about 8 passes of 2-4 mins each to get the clarity I wanted. The main thing was to keep the cerium paste on the lens moist and not chalky b/c the paste is what does the cutting.
RESULTS
Here's what I was left with after polishing:
DIY: Fog Light Sanding/Refinishing with Pics-after-1.jpg
DIY: Fog Light Sanding/Refinishing with Pics-after-2.jpg
DIY: Fog Light Sanding/Refinishing with Pics-after-3.jpg
DIY: Fog Light Sanding/Refinishing with Pics-after-5.jpg
A shot from the inside of the housing NCIS style:
DIY: Fog Light Sanding/Refinishing with Pics-after-4.jpg
BEFORE/AFTER
DIY: Fog Light Sanding/Refinishing with Pics-compare.jpg
Hope this helps anyone tired of staring at pitted foglight lenses!
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline
The Following 14 Users Say Thank You to Mfreakin5 For This Useful Post:
5PEEDY (26th October 2009), chowdah (26th October 2009), doc$holliday (26th October 2009), E55AMG2 (27th October 2009), emoshun (28th October 2009), firehire (26th October 2009), Jacob_Seattle (26th October 2009), mmzcee (26th October 2009), MrCrashRR (21st September 2009), Nabio (21st September 2009), Old4thWardM5 (26th October 2009), primeral (21st September 2009), sor118 (26th October 2009), Vector57 (26th October 2009)
Old 21st September 2009, 00:29   #2
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
Send a message via AIM to Nabio Send a message via Skype™ to Nabio
Great thread and the results look awesome! Thanks for sharing this process, because I've never considered sanding as an alternative to purchasing new foglights as mine are quite pitted. So when dry sanding with the 40, you said you must stop every 10-15 seconds and wait for a few minutes for the glass to cool. So was a majority of that hour sanding with the 40 grit just waiting for glass to cool? Or do you move on to a different location on the glass and sand that?
Jet Black 2000 M5
Nabio is offline
Old 21st September 2009, 00:53   #3
Mfreakin5
Mfreakin5's Avatar
Glad you found it helpful. The majority of the time is indeed time spent waiting. I only sanded the whole lens at 1 time for maybe 30-45 seconds of actual sanding time. The rest of the actual sanding time was spent spot sanding areas that were more deeply pitted. Since that spot sanding left criss-crossing sanding marks, I went over the whole lens 1 more time to get the sanding marks as uniform as I could before moving on to the 80 grit.
I forgot to add that I wore a sanding mask during the whole process and I recommend doing the same as glass particles aren't good to breathe in.
Last edited by Mfreakin5; 21st September 2009 at 00:54. Reason: "sanding" no "saing"
Old 21st September 2009, 01:14   #4
OC e39r
OC e39r's Avatar
Garage: M5 Alpine White
Impressed with the results..good job
Running strong
OC e39r is offline
Old 21st September 2009, 01:53   #5
Steveo
Steveo's Avatar
Garage: 01 Imola Red M5
Nice!
BMW M Power....- -
Steveo is offline
Old 26th October 2009, 13:49   #6
mrchilipalmer
mrchilipalmer's Avatar
Garage: 2002 e39 m5 imola red
Great thread, with great pics. Results are amazing. I too hadn't considered this as an option, however, I will now. I don't suppose you have any experience in sanding headlights?
mrchilipalmer is offline
Old 26th October 2009, 16:19   #7
chowdah
Garage: sweetness
Sales Feedback: (3)
Are the first 3 pictures before or after basic prep washing? I ask b/c I'm trying to appreciate what the wet-sand did(n't) do.
chowdah is offline
Old 26th October 2009, 17:26   #8
Mfreakin5
Mfreakin5's Avatar
sanding the OEM plastic headlights is much, much easier. That can be done while the headlights are still on the car b/c the positioning of the headlights is ideal. There is a great DIY posted by a board member, you can find it if you search....but here it is in pdf form.
headlight lens polishing.pdf
It tells you everything you need, and if done properly you will get night and day results. Just skip the step in the end where it tells you to use 3M Hand Glaze. A Glaze is not what you want to use, it's just a filler. You need to use a very fine polishing compound as a 2nd to last step (last step being wax). I still had some fogginess after finishing with the Plast-X compound. I tried a couple of 3M "fine" polishing compounds as well and they just didn't get rid of the haziness in the lens. It wasn't until I used the Menzerna Super Intensive Polish followed by Menzerna Final Finish PO85RD that they came out as clear as when they were brand new, probably better.
those pics are before any kind of washing or prep. Believe me, wetsanding alone will get you very limited results on glass foglights. If you have only superficial pitting, like no pits you can feel with your fingernail (which isn't very likely) then wetsanding + cerium oxide will get you some results but they still won't look like new.
Good luck with the job, it's time consuming but it's satisfying
Old 26th October 2009, 18:15   #9
mrchilipalmer
Many thanks for this - again, these looks great when finished. I'm definitely adding this to my 'must-do' list!
Old 26th October 2009, 19:33   #10
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
Damn!
Lancefitzgiben is offline
Fog Light Bulb Replacement for E39 M5 w/ Pics D-RodM5 E39 M5 and E52 Z8 Discussion 25 24th September 2009 06:06
Installing Entire Fog Light Assemply With Rings DIY? or Pro. Install? ZJamaican E39 M5 and E52 Z8 Discussion 4 12th May 2007 22:40
Wanted-Upgraded Fog Light Pics BMWLVR E39 M5 and E52 Z8 Discussion 8 5th April 2007 00:36
Broke fog light: which eBay replacement light works? Jaeger E39 M5 and E52 Z8 Discussion 0 8th July 2006 17:17
DIY wheel refinishing??? SpecRaceM5 E34 M5 Discussion 16 12th March 2005 20:12
Page generated in 0.13127 seconds with 12 queries
