Fixed leaking rear door vapor barriers (pics) - The Unofficial BMW M5 Messageboard (m5board.com)
Like Tree6Likes
Old 30th August 2009, 04:11   #1
timmay77
timmay77's Avatar
Garage: 2001 M5 (M CINCO), 2001 525i Touring (FAM WAG)
Sales Feedback: (15)
Thanks to Lunker325 (Brian) for info on how to do this, I fixed my rear doors from the leaking water horror that some M5's suffer from. Very easy DIY. Mx5 is coming over next week to do some work on his car and mentioned he wanted to do this repair so I thought I would go ahead and get my car done so it will be easy to do his. We will be working against the clock on his car, so I wanted to do a trial run.
Remove door panel (One screw on door handle, the rest is just pop locks securing the door. Take out the window switch and the flood light and unplug them.
Clean up area around old seal
Use some silicone to create a new seal (I used 732)
Tape up seal until it cures
Let car air out (I hate the smell of silicone)
Re-install door panel
Pics....
Visible water damage
Old rubber seal
I love blue tape
I know you are digging the power wheels in the background.....
2001 Jet Black/Executive Black///M5 ("M CINCO") current mods and accessories:
RMS Stage 2 SC Kit, installed by Buckhead Imports, tuned by Tony Lawshee ~ 546rwhp 450lbs trq on 8lbs of boost
~ Full compliment of PLX Devices ~ (2) OBD2 DM-100's, (2) SM-AFR, SM-V/B, (2) SM-AIT, SM-FP, SM-FT
~ Complete aftermarket stereo system w/Alpine INA-W910/PXA-H701, Rear Camera,
Hybrid Audio Technologies L831 speakers
~ UUC V12 clutch kit with segmented kevlar clutch disc
~ Muffler delete with ///M5 - MCINCO etched "Timmay Tips" LOL
~ Dinan wheels (4) 18x9.5" 10mm rear/5mm front spacers
~ Stoptech slotted rotors and Centric Posi Quiet Pads
BC Racing coil overs ~ Powerflex thrust arm and inner track control arm bushings ~ Dinan RSB ~ Beastpower sway bar brackets
Slimmbones finned rear diffuser, XL fog light covers, and front lip spoiler.
Coming soon -
Slimmbones trunk spoiler, hopefully sooner than later!
Tim ~ email: t.hallman77 @ yahoo (dot) com
timmay77 is offline   Reply With Quote
The Following 4 Users Say Thank You to timmay77 For This Useful Post:
Diny (15th October 2009), M5 London (15th October 2009), northumbriaborders (11th March 2011), Quicksilv3r (18th October 2011)
Old 30th August 2009, 04:17   #2
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 TiAg E39 M5
Sales Feedback: (13)
Soon VERY soon.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline   Reply With Quote
Old 30th August 2009, 15:37   #3
sidneyj
Garage: 530i Sport (M5 wannabe)
Not sure what silicone 732 is and why you have all that blue tape holding the barrier on? What you need to do is remove the old barrier and remove all the original black 3M sealer which is extremely tacky and somewhat difficult to remove. However, once you discover how to remove it it gets easier. Once you have like a golf ball sized chunk rolled up you actually use that as a magnet to get the rest of the stuff off by "blotching" the old seal. Again, it's difficult and you need to repeatedly go over and over the old seal until it lifts off. Once you have the old seal off and everything cleaned up just place a new seal along the old path, on the door, not the barrier, as you will see where the old seal was as it contours along the door. You don't need a new barrier unless it has a tear or hole in it. Press every square inch of the barrier back on the new sealent and you don't need tape to hold it and it doesn't need to cure. This "732" stuff that needs to be cured, not sure you should use that. This 3M stuff, I forget the product # can be had at the dealer, or, I did see the EXACT same stuff at Advance Auto type auto parts stores. If anyone wants the product # I can look in the garage.
sidneyj is offline   Reply With Quote
Old 30th August 2009, 15:59   #4
Hdhntr23
Hdhntr23's Avatar
Originally Posted by sidneyj View Post
Not sure what silicone 732 is and why you have all that blue tape holding the barrier on? What you need to do is remove the old barrier and remove all the original black 3M sealer which is extremely tacky and somewhat difficult to remove. However, once you discover how to remove it it gets easier. Once you have like a golf ball sized chunk rolled up you actually use that as a magnet to get the rest of the stuff off by "blotching" the old seal. Again, it's difficult and you need to repeatedly go over and over the old seal until it lifts off. Once you have the old seal off and everything cleaned up just pace a new seal along the old path, on the door, not the barrier, as you will see where the old seal was as it contours along the door. You don't need a new barrier unless it has a tear or hole in it. Press every square inch of the barrier back on the new sealent and you don't need tape to hold it and it doesn't need to cure. This "732" stuff that needs to be cured, not sure you should use that. This 3M stuff, I forget the product # can be had at the dealer, or, I did see the EXACT same stuff at Advance Auto type auto parts stores. If anyone wants the product # I can look in the garage.
2 things, first if Im reading your post correctly youre saying that you should use the 3M stuff instead of the silicon and its the same exact stuff they used to build the car. If thats correct, then isnt the same thing going to happen again?
Second, silicon is waterproof and Im pretty sure itll last ages longer than the double sided tape that youre referring to.
To each his own but when I do this and its going to be soon because I just found my back foot wells sopping wet, I want a permanent fix so I dont mind having to let it cure nor do I mind using the painters tape to hold it in place until its done so.
I may have read your post wrong. I appreciate you posting an alternative approach but to me I want something thats gonna last longer than it did from the factory. Silicon I know for sure will do that.
Old 30th August 2009, 16:15   #5
sidneyj
I think you read at least some of it wrong. I didn't mention anything about using double sided tape. I indicated no tape is needed to hold the barrier on while it's curing because using the 3M stuff requires no curing.Yes each into his own here but I think where the problem comes in here with this failure on the barrier is from previous work someone has performed while having the door panel off and not correctly re-installing the barrier. The 3M factory stuff is plyable and meant to be removed and re-used if needed. Example: if you need to remove the door panel for some reason and work behind the barrier you can carefully, slowly pull the barrier away from the door and place it back without issue. My guess is using the 732 stuff that needs curing would require a total re-do if removed? The factory stuff does not fail if it was installed correctly and it will never break down for no reason. I had an issue with my 2003 right rear door leaking and discovered the dealer never installed it back thoroughly. If done correctly and one takes there time to install it completely then this 3M product will not fail. Also, if you have "sopping" wet footwells I would remove or at least lift the carpet up back there where it was wet and let it dry out and maybe even spray something to kill any potential mold that may have grown under the carpet. Maybe I'm just being anal but thinking logically of at least what I would do.
Old 30th August 2009, 17:00   #6
Flybot
Flybot's Avatar
Garage: 2000 M5, 98 528i, 75 911S
That correct 3M product number would be handy.
Flybot is offline   Reply With Quote
Old 30th August 2009, 17:59   #7
Tyrone D.
Garage: -
3M Automotive (MMM8610) 3M„ Window-Weld„ Round Ribbon Sealer, 1/4" x 15' - MMM8610
Tyrone D. is offline   Reply With Quote
Old 30th August 2009, 18:00   #8
BAD TA WS6
BAD TA WS6's Avatar
Garage: '02 WS6 blk/blk 6 speed, '02 Imola on Red Sport M5
BMW has their own Buytl tape which is the correct way to repair this. Remove the door panel, remove the vapor barrier (do not tear/rip it). It's important to remove all the old butyltape next. Then lay a frash bead of ribbon sealer/tape around the area. You can use a heat gun over vapor barrier quickly, to get the tape nice and sticky. Re-install the door panel and you're done.
Silicone is going to be a major PITA to clean up next go around. Definately would not use this method.
Normally the factory tape fails, because whoever was last in there replacing a window regulator, etc. Didn't take the time to replace the tape. They just tried to reuse it, and as you can see, it never works that way. Not unless you heat it with a heat gun, and try and get it tacky to re-use it.
'02 Imola M5 - modded
'02 Trans Am WS6
Built motor, Coil overs, complete suspension, iForged wheels, etc. - Fast.
'06 GSXR 1000 - Faster...
BAD TA WS6 is offline   Reply With Quote
Old 30th August 2009, 18:20   #9
Lunker325
Lunker325's Avatar
Garage: 02 Sterling Grey/Silverstone
Sales Feedback: (7)
There are several ways to fix this. On my old 540 I used just silcone sealant, plenty of it, and it held up for years until I sold the car. On this car, I used the window weld stuff, AND silcone sealant around the outside edges just to make sure no water would get onto my illuminated door sills, or into the car.
12th Gen Bluetooth * Intravee II, Alpine KCA-420i, Alpine TUA-T550 HD Radio * Alpine SPX-17 REF 6.5" F & SPS-500 5.25" R Speakers * OEM Sirius * JL Audio XD600/6 6 Channel Amp(DSP Removed) * Audio Control DQXS * Custom ED Sub Box with 2 x SQ10's * Infinity 611a Sub Amp * Dinan Exhaust * Powerchip MAF-less tune * E60 SSK * ZHP Illuminated Shift Knob * Jet Black Rear Valance * Headlight Armor light smoke tinted tails * 18x10 SSR GT3 wheels F&R * Euro Hella Headlights * Predator Ice AE's with 5W Luxeon K2 Star and 1000 mA PowerPuck Driver * Seasonal OEM Heated Steering Wheel Retrofit * F & R Illuminated Door Sills * Ultimate Pedals * Full Interior LED's * 6000K HID Fogs * MKIV Nav * Passport 9500ci * Griots Italian Air Horn * Slimm's leather tilting armrest * Dinan Stage 1 Suspension *...
Lunker325 is offline   Reply With Quote
Old 30th August 2009, 21:25   #10
timmay77
timmay77's Avatar
I personally did not reuse the original stuff because in my eyes it will just fail again. I have every record from my car since it's in-service date, and no one has ever had that door apart. The previous owner was not a DIY guy, EVERYTHING was done att the dealership. 732 is just Industrial Loc Tite silicone that we use at work to fix just about anything that needs to be repaired in a water tight situation. IF I do ever need to get inside that door panel I will cross that bridge when I come to it. I would much rather have to deal with a PIA door repair if a regulator fails than have to worry about the original sealer failing again causing my door to leak again. I can pretty much garuantee this stuff will not leak.
Sometimes OEM isn't the best route to go.
But again, to each his own.....
Leaking rear main seal = new clutch? R748 E39 M5 and E52 Z8 Discussion 3 20th March 2008 16:36
FS: e39 left rear door vapor barrier SeattleM5 Parts / Other For Sale or Wanted 0 21st January 2008 18:24
Something leaking from around the rear diff... Jon Baker E34 M5 Discussion 10 26th August 2005 19:34
door rattle fixed slowcar E39 M5 and E52 Z8 Discussion 2 4th June 2005 19:58
door rattle fixed slowcar E39 M5 and E52 Z8 Discussion 0 4th June 2005 17:11
