Scanner that can read ABS code - BMW M5 Forum and M6 Forums
USA Northwest Forum For WA, OR, ID and AK members.
post #1 of 1 Old 6th April 2016, 06:36 AM Thread Starter
ictoaln
ictoaln's Avatar
Anyone know of a good scanner which reads ABS code? Or anyone in Seattle has one that I can borrow to just read the codes?
The ABS/DSC/Brake lights started coming on and staying on after I sent for repair (similar to problem described in https://www.m5board.com/vbulletin/e39...-advice-3.html
I took it to an INDY and they want to replace it with new without much
diagnosis. I went the repair route 6 months ago. It went away for a while and the lights have returned less than 500 miles. The repair shop (in CA) has lifetime warranty for the repair, but want me to provide them the codes to confirm before sending it in again. I have a peake scanner, and it does not read ABS code.
TIA,
Ictoaln
ictoaln is offline
Help: ABS Brake Traction? - BMW Scanner Results inside belmontjoe E39 M5 and E52 Z8 Discussion 16 6th May 2014 09:02 PM
Anyone code a used ABS module with BMW scanner 1.4 ? Clayton Usher E39 M5 and E52 Z8 Discussion 20 29th December 2012 10:27 PM
BMW Scanner v1.4 - Traction Light on and ABS Error 540-S3 E39 M5 and E52 Z8 Discussion 0 2nd October 2012 11:22 PM
Read/decipher ecu code - or - what tuner code am I running ? mkaehly E39 M5 and E52 Z8 Discussion 2 29th January 2011 11:05 AM
Anyone has disgnostic code scanner karlcchen E34 M5 Discussion 7 14th January 2002 11:03 PM
HTML code is Off
