The New Race Car - Page 5 - BMW M5 Forum and M6 Forums
Track, Racing and Drivers Education This is related to your driving on track and racing with your M5
 125Likes
post #41 of 83 Old 7th August 2015, 08:38 PM Thread Starter
herrubermensch
Originally Posted by jamiepeers View Post
Heel toeing is one thing I am a complete noob at and have not got the hang of yet. It was the reason we ended up ruining an engine mount which in turn burst the header tank on the radiator at the 'ring this year.
Any tips?
I have tried the true "heel on the accelerator with toe on the brake" method, and it just doesn't work for me. When I moved to the "roll the side of your foot onto the accelerator" method, I got much better. Combine that with a lateral accelerator pedal extension and modification of the accelerator pedal to be at the same height as a fully depressed brake pedal and you'll be much better all of a sudden.
--Peter
herrubermensch is offline
post #42 of 83 Old 7th August 2015, 09:11 PM
REKIII
REKIII's Avatar
Glad I'm getting caught up on this thread. All sorts of awesomeness.
I'm up for designing more mounts. Pretty soon we'll be putting the S62 in everything, like the LS!! hahaha.
Sams missing the diff to make an S2? I'm the last person that would ever want to contribute to the making of an S2, however I might be pulling my Dinan diff for a stock one once my car is together.
Making an adapter plate for the ZF to S62 shouldn't be very difficult.
2001 Jet Black M5
2012 Black Ford Raptor
2014 Black Jeep Grand Cherokee Summit
2008 Raven R1 - Being disassembled and sold
REKIII is offline
post #43 of 83 Old 8th August 2015, 06:19 AM
BrendanSC
BrendanSC's Avatar
--Peter
Agree with all of this. Even if you perfect the technique on the street, track braking is different. It took me a while to learn braking safely with the ball of my foot so I can roll on the accelerator if needed, then when I went to the track I was depressing the brake pedal all the way and the accelerator was too high to roll onto. I had to revert to the heel on the accelerator method for the day. It worked but it led to some untidy driving.
BrendanSC is offline
post #44 of 83 Old 8th August 2015, 06:32 AM
m5 deamon
m5 deamon's Avatar
--Peter
Peter first off all congrats on the m3, you know who to call about doing an s62 swap, anyhow the above combo is how i have my pedals set up in my m5 makes heel toeing a breeze
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
post #45 of 83 Old 8th August 2015, 01:33 PM
CSBM5
CSBM5's Avatar
Not yet, Chuck, but it is definitely in the cards for next year. Though I DO have a 50th birthday coming up!
Interesting about Hogpen. I find that nipping the inside rumble strip as you sweep into the straight keeps you fast, on the track and leaves you at exit on the far left side of the front straight where you want to be. But I did notice my instructor in a street car on street tires having to be careful right there. I would always catch up to him right at that point and then be on his *** on the entire front straight.
--Peter
I last used iRacing about 5 years ago and thought it was fantastic. Their laser track mapping was spot on, and the simulation is outstanding. I was more able to really use it well though in an open cockpit car, the Star Mazda, since that give a better "visual feel" of yaw which it is essentially the only thing you have to communicate the car's attitude.
Anyway, one of the things I found most useful with iRacing was working on worst case situation recoveries/recovery attempts. You find out real quickly how little room there is for error/problems at some locations on various tracks like turn 5b-6 region at VIR -- don't ever get the tail too loose since the never seen Armco to the right of track there is just feet away. I did also manage, eventually, a way to survive a total brake failure at the end of the back straight.
One other thing to do in iRacing is to drive the track backwards. For most all tracks, you can't ever do that since all the safety barriers and such are not designed for such use, but it was very instructive to drive VIR backwards for me. I learned a lot about the topography of the track that I was unaware of having driven it so much in real life in the normal direction. It gave me better insight into the exit of Oaktree turn, roller coaster/hogpen, exit of turn 10/south bend, and turns 6-5-4-3.
Chuck
Current stable:
CSBM5 is offline
post #46 of 83 Old 9th August 2015, 04:10 AM
Blue Thunder
Congrats on the M3!
M5 is too big and heavy for this use anyways
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore, UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis, 19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Dynawin headunit, CF interior trim
1989 E30 M3 White - track toy
S85B50 with M-DCT - 560+ hp, 1300kg rocket for the Ring being built
https://www.m5board.com/vbulletin/e6...ct-e30-m3.html
Blue Thunder is offline
post #47 of 83 Old 9th August 2015, 03:23 PM Thread Starter
herrubermensch
Originally Posted by Blue Thunder View Post
Congrats on the M3!
Thanks! It is a great car!
You and I disagree about the M5. Mine is currently at about 3100 lbs. dry and getting lighter by the moment (carbon doors and fenders to come and a few other lightening techniques). There are at least two fellows building E39 M5s to campaign in GTS next year. Having driven my M3 at 2725 lbs wet, there is a weight difference no doubt, but it is nowhere near what people think and there is a huge power differential, particular at lower RPMs coming out of hairpin turns. That is where the S62 really shines. Also try some Motons or MCS struts on an M5 sometime. You'll be surprised at how docile it becomes!
All that said, I agree that the M3 has greater potential. Just needs an S62 and full Motec electronics.
--Peter
post #48 of 83 Old 10th August 2015, 02:07 PM
CSBM5
CSBM5's Avatar
--Peter
You know Peter....an S65 is a good bit lighter (50+lbs I think) and somewhat smaller than the S62, so you could always go that route too.
Current stable:
CSBM5 is offline
post #49 of 83 Old 10th August 2015, 02:47 PM
rao
He could, if he was actually interested in performance
If you find this post unsatisfactory, please add me to your Ignore List so you will not be disappointed again in the future.
---> https://www.m5board.com/vbulletin/pro...?do=ignorelist
Rob
Prior - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Older - 92 325i with Chevy 6.6 LS2/T-56 Power
Oldest BMW - 95 M3 with Chevy 6.6 LS2/T-56 Power
rao is offline
post #50 of 83 Old 10th August 2015, 04:46 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Late to see this thread, but WOW WOW WOW!
Congratulations Peter! Looking forward to more threads on THIS toy!
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =158,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
The Following User Says Thank You to Fiftytwoeighty For This Useful Post:
herrubermensch (10th August 2015)
My Kinda Car: Dinan's E34 Turbo Race Car herrubermensch E39 M5 and E52 Z8 Discussion 6 5th August 2014 10:03 PM
M5 Race Car pspassos E34 M5 Discussion 4 1st April 2009 09:01 PM
Race car-M6 gsfent E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 15th January 2008 01:17 AM
M5: Race Car or Show Car? Izzyzx E28 M5 Discussion 21 27th September 2006 09:37 PM
MY M6 NEXT TO MY RACE CAR bs774476 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 10th April 2006 10:49 AM
