E39 M5 Post Facelift Headlight Rebuild - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By ND4SPDLSC
post #1 of 6 Old 11th September 2017, 09:42 PM Thread Starter
lbovenzi
lbovenzi's Avatar
Hi all,
Decided it's time to tackle the headlight issues on my e39, so I'm reaching out to fellow members before I begin this task. Recently my headlights have s*** the bed, with one side half working and the other side half working as well (both sides polar opposites). So, I figured I would either replace them, or rebuild the original units. This will be my first time tearing apart some headlights, so any advice is highly appreciated.
Essentially I am looking to swap the lens (originally US Post Facelift) with a clear corner alternative as one side of my current setup is yellowing quite bad. I am intending on upgrading the halos as well as all the obvious bulbs.
If anyone can recommend parts/advice regarding this sort of work, that would be greatly appreciated. Been having a hard time finding aftermarket replacement headlights that will fit a post facelift M5 with minimal wiring/modification, so it seems as though this is the better route. I would get some Euro Hellas but my bank account would be far from happy.
Thanks!
European Automotive Importer
Current Cars:
Vladimir - 2002 BMW M5, Carbon Black, OEM Style 65's Squared, E60 SSK, ZHP Weighted Knob, Muffler Delete/All American Muffler X-Pipe, BeastPower brackets, Powerflex Black Series Bushings
The Green Bean - 1991 BMW 318i Touring, Laguna Green Metallic, RHD UK import
The Orange Turd - 1988 Land Rover Defender 90 TDI, RHD UK import, full off-road spec
lbovenzi is offline
post #2 of 6 Old 18th January 2018, 01:21 AM
ND4SPDLSC
ND4SPDLSC's Avatar
I thought you can't buy an OE lens for the post facelift headlight. You also may not be able to remove the lens due to an epoxy change. You need to check, but the change may have occurred in '02. You can wet polish and buff out yellowing lenses though. Usually the lights are long lasting and don't need rebuilding. I have only had to replace a Xe bulb on 1 car and the adjusters on all. The electricals have been fine.
Nick, BMW CCA Member #425357
2001 BMW M5, Anthractite Metallic
2001 BMW Dinan 540i/6, Jet Black
2000 BMW 540i/A, Biarritz Blue
1999 Dodge Viper ACR, Viper Silver
1999 Jaguar XJR, Anthracite (Black) Metallic
1994 Mazda Miata, Classic Red
1989 Lincoln Mark VII LSC, Platinum Metallic
1987 BMW 325is, Schwarz
1986 Lincoln Mark VII LSC, Medium Graphite Metallic
ND4SPDLSC is offline
post #3 of 6 Old 4th May 2018, 07:39 PM
TurboHugh
TurboHugh's Avatar
Originally Posted by lbovenzi View Post
Hi all,
Thanks!
I haven't found a cheap way to upgrade post facelift Xenon headlights. Actually I'm likely jumping the other direction and going all in on BiXenon upgraded lights .. $$$$$
2003 M5 Sterling Gray Metallic
BMWmregistry.com Member # 13792
NccBmwCCA Member # 5339
TurboHugh is offline
post #4 of 6 Old 22nd June 2018, 08:40 PM
e39noob
e39noob's Avatar
I just did this a few weeks back. I bought replacement lenses through ecstuning for about $160 and they have the silver euro markers already attached.
As for separating the lenses, there are a few good YouTube videos on how to do it even if you have the epoxy. Basically you Dremel off most of the lens, leave about 1"along the seams and then use a utility knife to cut the epoxy on each side of the remaining piece. Then you can pull it off. Not a bad job but it takes time and patience.
You can get butyl based headlight sealer on Amazon and it works nicely for putting the new lenses on. Fits right in the seam and you just press the lenses in after applying some heat to the butyl.
e39noob is offline
post #5 of 6 Old 8th August 2018, 06:17 PM
Trizzuth
Trizzuth's Avatar
you have any pics of your end result? I was considering this as well, but likely will have a friend just polish the lenses for now as that should last me awhile.
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #6 of 6 Old 9th August 2018, 02:13 AM
e39noob
e39noob's Avatar
e39noob is offline
E39 Euro facelift headlight parts Wankell E39 M5 and E52 Z8 Discussion 2 27th January 2015 05:29 PM
E39 For Sale: E39 OEM Facelift Headlight Brackets Pair 6SpeedDave Parts / Other For Sale or Wanted 7 29th October 2013 11:53 PM
Post-facelift headlight covers aznbo187 E39 M5 and E52 Z8 Discussion 6 19th December 2012 02:16 AM
HELP e39 2001+ Headlight Facelift Retrofit on a 2000 M5 poofyo101 E39 M5 and E52 Z8 Discussion 6 9th August 2012 11:29 PM
help! how to open e39 facelift headlight?. Ver$uZ Motorsport E39 M5 and E52 Z8 Discussion 32 31st July 2011 09:43 PM
