FM Radio doesn't work - BMW M5 Forum and M6 Forums
post #1 of 4 Old 4th September 2017, 11:51 PM Thread Starter
Bmwguy002
Bmwguy002's Avatar
I still have my stock radio in the car and when I go to FM radio nothing works anyone ever experienced this problem ?
Bmwguy002 is offline
post #2 of 4 Old 12th September 2017, 03:02 AM
Knowledge1L
Knowledge1L's Avatar
I had a similar problem with mine. My radio would turn off every 3 minutes on its own. I had to turn it off and back on to get another 3 minutes going. I ended up buying a MKIV computer which was an upgrade from my MKII and it went away. Could be the computer or radio module. I did upgrade my unit to a 16:9 but I didn't need to replace radio module to fix the issue.
2000 E39 M5 Titanium Silver Metallic
1991 E30 318is Alpine White
Knowledge1L is offline
post #3 of 4 Old 6th December 2017, 08:01 AM
S30
S30's Avatar
I would check the fuse first. Itís a green 30amp fuse in the trunk. Check the label, I know itís right below the middle ones
S30 is offline
post #4 of 4 Old 6th December 2017, 03:45 PM
AGM5
AGM5's Avatar
Is it only the FM reception or do you loose audio from all (Tape, CDC, AM, Navigation, Telephone)? If you are loosing all audio your radio is dying or dead already. If it is only the FM band, check that the radio is coded for the correct (e.g. US) frequency reception, via the radio service menu or INPS, NavCoder or PA Soft. If the radio is working and properly coded, check the antenna diversity, the antenna amp and the connection to the backlight FM antenna.
///M - The most powerful & expensive letter in the alphabet
1 of 123 ANTHRAZIT METALLIC (397) / WALK NAPPA/SCHWARZ (M1SW)
Tuned by BMW Motorsports 4/2001, Bone Stock at 185,000 Miles. 355.78 WHP / 345.33 WTQ
2 facts you might not know: Ducks cannot fly and they nest in trees.
Updates:
BM53 Radio / Gen-13 ULF / OEM Sirius / MK-IV Navigation / Aux input / Intravee II / KCA-410c / KCA-420i / 5th Gen i-Pod Nano / CHA-S634 / Umnitza VXX Angel Eyes / F10 ///M5 Shift Knob /
Schmiedmann Shadow Chrome Grills / Rear Fog Lights
DIY: Retro-Fit Auxiliary Audio Input Harness /// DIY: E39 - BM53 & (BMW) Sirius Radio Retrofit /// DIY: E39 - Replacement of the Left and Right Firewall Covers
For Sale:
BMW Style 5 17" 2 Piece Wheels And Tires
AGM5 is offline
Horn doesn't work 20ducks E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 9th December 2014 02:30 AM
search doesn't work azaytsev E39 M5 and E52 Z8 Discussion 7 8th February 2008 07:46 PM
