Vibration in the Steering Wheel - BMW M5 Forum and M6 Forums
post #1 of 12 Old 1st April 2016, 04:11 AM Thread Starter
okindao
okindao's Avatar
Hi all,
Have noticed in last month or so that after I start the car there seems to be a slight vibration in the steering wheel. This lasts a few minutes and seems to go away when underway......
any ideas ? I am baffled
Thanks in advance for any help you can provide
Dennis
2002 M5 Imola Red
1997 993 c2 Triple Black Porsche Cab sold
2016 Porsche Cayman GTS
okindao is offline
post #2 of 12 Old 3rd April 2016, 05:05 AM Thread Starter
okindao
okindao's Avatar
no ideas folks ? I am baffled.....
Dennis
2002 M5 Imola Red
okindao is offline
post #3 of 12 Old 19th April 2016, 04:25 PM
Bigmitch117
Bigmitch117's Avatar
Hi. Tell us more about the vibration. Is it at certain speeds? How are your front rotors? I've heard of people having a "sticky" brake caliper when cold, causing it to grip the rotor a little until warmed up. If your rotors are in less than perfect shape, this could transmit the vibration into your steering wheel.
Sent from my SCH-I545 using Tapatalk
Bigmitch117 is offline
post #4 of 12 Old 28th April 2016, 06:30 AM
Thumper600
Thumper600's Avatar
are your wheels balanced? Do you experience this phenomen when braking, if so how much life is left in your pads and how thick are your rotors? Have you had the car off the ground to check if you have a "loose" wheel? (Remember the good old days when Dad kicked the tires?). Have you checked the "guibo", ( driveshaft rubber flex disc coupling), is your drive shaft balanced, are your shocks in good shape? And and and, these might be a good place to start though.
Thumper600 is offline
post #5 of 12 Old 29th April 2016, 05:31 PM
3mta3
3mta3's Avatar
check for bent wheels...specifically the inner lip. jack up a corner at a time and rotate wheel and watch for runout on the inner lip
2002 E39 M5 Sterlinggrau Metallic; Full Carmel; MKIV
3mta3 is offline
post #6 of 12 Old 30th April 2016, 02:51 AM
Zero_Cool
I'm experiencing a similar issue. Its only noticeable at about 40mph and as I speed up it goes away. I will see about getting it on a lift this weekend so I can check the wheels. Thanks
Zero_Cool is offline
post #7 of 12 Old 13th May 2016, 01:11 AM
Sailor24
Sailor24's Avatar
Not really a general question. If you post in this forum you will get tons of replies.
E39 M5 and E52 Z8 Discussion - BMW M5 Forum and M6 Forums
That said if it is at one specific speed likely in the balance of the tire or wheel.
Sailor24 is offline
post #8 of 12 Old 13th May 2016, 01:21 AM
BONDOSPECIAL
BONDOSPECIAL's Avatar
Do you mean you get the vibration while the car is running, but stopped? How are your remote oil filter housing rubber mounts? I had some weird rpm specific noise and vibes from these mounts being bad. I wouldn't have believed it was from the mounts until I fixed them and it went away.
Steven H. www.carfap.com
2000 M5, 109k miles, Carbon black. 18x8/9.5 TSW Rivage wheels.
BONDOSPECIAL is offline
post #9 of 12 Old 13th May 2016, 10:32 AM
E39M5sterlinggrayguy
E39M5sterlinggrayguy's Avatar
that could be something as easy as control arm bushings, get the car in the air and shake the wheels. get the wheels balanced dosent hurt
E39M5sterlinggrayguy is offline
post #10 of 12 Old 15th May 2016, 01:14 AM
Jrgymie
Jrgymie is offline
Steering wheel vibration!! rashed2694 E39 M5 and E52 Z8 Discussion 18 15th January 2014 06:32 AM
Steering Wheel Vibration kiddhan625 E39 M5 and E52 Z8 Discussion 60 4th May 2011 12:41 PM
steering wheel vibration tjab80 E39 M5 and E52 Z8 Discussion 3 1st January 2010 12:32 AM
Vibration at steering wheel -help- BD 997 E60 M5 and E61 M5 Touring Discussion 29 3rd March 2008 02:33 AM
Vibration in Steering Wheel tranck E39 M5 and E52 Z8 Discussion 12 26th December 2006 04:41 PM
