s62 secondary air reroute? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By mgdmb
post #1 of 5 Old 14th March 2016, 03:59 AM Thread Starter
charofire
I read about an owner of 2000 m5 locally who re-plumbed the secondary air system into the exhaust (some say they will re-route into the exhaust manifolds (as it's done on the M73) and plugging the ports on the head. How many have found this a successful solution?
charofire is offline
post #2 of 5 Old 14th April 2016, 08:14 PM
Alan Ahern
Alan Ahern's Avatar
It seems like a load of hassle. Its probably easier to unblock the heads and actually fix the issue.
Alan Ahern is offline
post #3 of 5 Old 12th May 2016, 10:48 PM
mgdmb
mgdmb's Avatar
It's a lot faster to just code out the AA code. Pulling the heads is 40+ hours, re-routing the heads will never pass CA visual smog...
mgdmb is offline
post #4 of 5 Old 13th May 2016, 12:39 AM
Sailor24
Sailor24's Avatar
I am not the first to have done this but likely have the most development time into it. I never did do a full thread on this but have replied in other posts with pics and details. Worth your search in the E39 M5 specific forum. As far as how it works, better than stock and many of the faults are removed. Other than welding fittings to the double walled header pipe all the rest of the tasks are easy, drill holes and use compression fittings. This is a real fix as the system works as designed and is likely why BMW has gone this route also.
It is so much easier than clearing the head passages they can't be compared. Heads cost is $10,000, reworking the system (once I had the design and some fabricated parts) took one evening in the shop. IIRC the total for the parts was less than $300. The design took a very long time because I had to do many experiments.
I have made some suggestions on how to do it now, learning from what I have done and I suspect that path would be 3 hrs work, no fabrication work, and $150 for parts plus wielding 2 fittings to the exhaust.
It is easy to just code it out, but the system working offers some advantages that are worth while. It is only easier to code it out if you can do the coding yourself or use one simple tool available. Otherwise coding it out using a tuner costs some big bucks as they seem to only offer it bundled with other mods.
Sailor24 is online now
post #5 of 5 Old 13th May 2016, 11:12 AM
E39M5sterlinggrayguy
E39M5sterlinggrayguy's Avatar
yea usually the right way is the correct way. I have used a couple kits to clear the blockages I think AGA was the one that I liked best for the N62 motor
E39M5sterlinggrayguy is offline
Cats and secondary air xrviz E39 M5 and E52 Z8 Discussion 20 14th June 2015 10:04 AM
Air leak from secondary air system? ///DeafM5 E39 M5 and E52 Z8 Discussion 10 5th March 2015 03:54 PM
E39 For Sale: Secondary Air Pump mattmor Parts / Other For Sale or Wanted 2 4th November 2012 10:59 PM
Secondary air pump JustinM5 E39 M5 and E52 Z8 Discussion 39 13th June 2012 07:27 PM
Secondary air pump glen_lloyd E39 M5 and E52 Z8 Discussion 10 14th April 2012 06:04 PM
