e39 M5 Clutch replacement - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By Zero_Cool
  • 1 Post By jsdsm5
post #1 of 9 Old 23rd November 2015, 06:43 PM Thread Starter
clubracer777
clubracer777's Avatar
Question e39 M5 Clutch replacement
Does anyone have feedback on a Sachs Clutch Supersert vs OEM?
My 2000 has 185k and is not a daily driver.
Goal is to keep in pristine condition...
Per the folks at Gripforce this is a take out and replace part no issues...
Any feedback appreciated!
clubracer777 is offline
post #2 of 9 Old 29th February 2016, 06:42 AM
Thumper600
Thumper600's Avatar
Don't know what brand name BMW of South Atlanta sells but it looks like they will sell you what ever BMW recommends for about $885 including all clutch components and dual mass flywheel. Don't know how much the the Sachs set up is but Sachs is supposed to be a better German OEM supplier company.
2000 BMW 5 Series (E12,E28,E34,E39,E60,E61) M5 Sedan Clutch
There's Turner Motorsport review but I am under the impression they're trying to sell you something.
From NightKrawler July 19, 2013 (Pg 4 I think on this Forum and he states he's the M5 Guru)
being the clutch isn't really a quick easy thing to change why take a chance. the clutch i got from south bend is 100% sachs parts, pressure plate, disc, and t.o. bearing. (So I guess Sachs is the supplier of clutches to BMW in Germany)
From MDA185 @ Bimmerfest
I have performed several clutch replacements on my bimmers over the years. This is not a job for most beginners unless you are motivated, have some good manual skills, and are willing to take your time and be meticulous until you have it all figured out. The procedure is 90% the same as for the 328i E36 and there should be many threads and write ups on the internet for that car. The Pelican Parts web site should also have a good write up for an E36 clutch job. I am guessing that because of your age and where you live, your only option is to take this to a shop for the work. Doing this job on a cold driveway in winter is not much fun. If you have access to a garage and a lift, this becomes much easier.
You don't say how many miles are on your car. I do not recommend re-using the flywheel on any car over 100K miles especially if it has been slipping a lot. When the clutch slips, it messes up the friction surface on the flywheel. You may get away with reusing the flywheel but if it fails after 5-10 thousand miles, you will have to pay for all of that labor again to replace it. That happened to me the one time I reused a dual mass flywheel with high mileage on it. I just purchased an 03 530i with a manual from an owner who did the same thing. He replaced the clutch at 110K miles but kept the flywheel. Guess what is failing a year later at 124K miles?
I am a big fan of the UUC single mass flywheel kit that includes an M5 Sachs clutch and pressure plate. It is much better than our stock set up while still being very easy to drive with on the street. By that, I mean it has very progressive clutch action and easy to engage unlike most high performance clutches. It costs a little more than OEM dual mass flywheel and Sachs clutch or the LUK alternative.
if you've got a welder handy I thought this was an interesting tool in case you're a do it yourselfer
Sachs Clutch Review - PureLocal
So, Hope this helps and from what I've looked at Sachs is the supplier of clutches to BMW. Hope this helps, happy reading and research
Thumper600 is offline
post #3 of 9 Old 6th March 2016, 10:59 PM
palantirion
palantirion's Avatar
I recently had to replace my clutch and after asking around several shops I trust, that work on every variation of street and track BMW, the unanimous conclusion was to go with stock OEM clutch.
I'd run Dinan's lightned flywheel/clutch for quite a while, and it was very nice until the flywheel was ruined by a UUC clutch with a weak spring. I got some credit at UUC for that, went with their V12 clutch kit (shipped 64gr out of balance!) and while it grabbed fine it was always noisy, and then after 20-30k miles a flywheel pin failed, ejected itself, and cracked the case of my transmission. So after taking it in the rear for $7k to replace my transmission I would certainly stay the hell away from anything made by UUC.
I went back to stock, and it's just great. In fact my M5 is so much quieter now, even at freeway speeds! I had no idea the UUC made noise apart from idle, but it did. Apparently a lot. My exhaust tone even sounds different, lol.
www.ebsart.com
2011 X3 35i,
Alpine White
with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe,
Titanium Silver
with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
palantirion is offline
post #4 of 9 Old 13th May 2016, 10:34 AM
E39M5sterlinggrayguy
E39M5sterlinggrayguy's Avatar
E39M5sterlinggrayguy is offline
post #5 of 9 Old 14th May 2016, 12:50 AM
Zero_Cool
My PO replaced the stock clutch near 100k with a LUK clutch and dual mass flywheel I believe. I haven't launched it, but spirited shifting has shown this clutch has very good grip. Haven't driven a stock clutch for comparison though..
Zero_Cool is offline
post #6 of 9 Old 1st January 2017, 06:22 PM
jsdsm5
jsdsm5's Avatar
UUC is a horror story on clutches. Made that mistake on my 540i Msport. UUC clothes never again.
Current Stable
2003 E39 M5
2003 E53 X5 4.6is
1985 E24 635csi Euro
2008 P80 Volvo XC90 R-Design Yamaha V8
M5 MODS
Dinan Suspension
Dinan 3.45 Diff
Dinan Exhaust
Style #65 Rears - four corners
jsdsm5 is offline
post #7 of 9 Old 27th January 2017, 04:27 PM
dinkman
sachs clutches in general are cheaper oem quality. not high performance but not bad quality either
i've used them numerous times in the past and have never had complaints
dinkman is offline
post #8 of 9 Old 6th January 2019, 05:06 AM
bmb063
I just had my clutch and flywheel replaced. I went with OEM because the other options didn't really make sense unless you go more power.
bmb063 is offline
post #9 of 9 Old 15th February 2019, 08:08 AM
10le
10le's Avatar
Hoy together,
Do anybody have experience with VAC motorsport?
I would like to have this:
https://store.vacmotorsports.com/mob...-v8-p1085.aspx
lightweight flywheel is must have and central bearing Tiltion would be so porn
So, if you have a feedback, please share with me.
Regards
Sent from my SM-G965F using Tapatalk
E39 M5
04/ 2000
Currently sleeping.
Wating for a new clutch.
E92 M3
11/2007
Runs and runs
E46 325Ci
09/ 2002
Daily whore
10le is offline
DIY - S62 V-belts replacement and fan clutch replacement. J Irwan E39 M5 and E52 Z8 Discussion 56 8th May 2017 12:17 AM
Clutch/Transmission Issues after Clutch Replacement - Help Needed BCUZICAN540 E39 M5 and E52 Z8 Discussion 11 26th November 2013 10:07 PM
E39 Clutch replacement pete_griff E39 M5 and E52 Z8 Discussion 6 12th October 2009 11:16 PM
Clutch Replacement canysmc E39 M5 and E52 Z8 Discussion 42 22nd January 2009 09:05 PM
Clutch Replacement amgsmoker E39 M5 and E52 Z8 Discussion 3 23rd March 2007 12:26 PM
