Replaced pixel ribbon but damaged gas gauge - BMW M5 Forum and M6 Forums
post #1 of 4 Old 5th September 2015, 01:23 PM Thread Starter
ELotz101
I bought the pixel repair kit to fix the damage pixels in my display.
Drilled the 4 holes. All going fine when I was putting screws for LCD back in I lost screw off head and pushed screw driver hard into the mother board and appears the gas gauge got pulled up and now it sits at 1/4 at rest.
Can this be repaired?
ELotz101 is offline
post #2 of 4 Old 29th October 2015, 05:46 AM
Eurosapien
Eurosapien's Avatar
with the cluster removed, simply turn the needle by hand to the desired position. If you feel resistance thats fine; as long as you dont wind it 360 degrees and tighten up the return spring too much.
a simple twist to the left wont do any harm. the needle should work as before
Eurosapien is offline
post #3 of 4 Old 8th November 2015, 06:43 AM
wrx47
I know this has been asked a while ago, but in case someone in the future has this issue:
Chances are pulling the gauge face, the VDO glue holding the face to the plastic piece got undone. Put a finger on the gauge face near the needle and lightly push down. As youre doing that, move the needle to make sure it it doesn't hang. If that's your issue, a very small amount of gorilla glue near the hole you drilled takes care of it.
Source: I just installed a nes silver ribbon 2 weeks ago and had that problem
wrx47 is offline
post #4 of 4 Old 13th May 2016, 10:43 AM
E39M5sterlinggrayguy
E39M5sterlinggrayguy's Avatar
I did this same damn thing, but I just scratched the guage face, I ended up buying a used cluster on ebay cause the scratch bugged me too much
E39M5sterlinggrayguy is offline
Gas gauge not registering/Gas smell ECB E39 M5 and E52 Z8 Discussion 6 24th August 2013 04:08 PM
Pixel fix replacement ribbon diy ger E39 M5 and E52 Z8 Discussion 20 3rd October 2011 08:12 AM
Gas Gauge not reading properly?? VsM5 E60 M5 and E61 M5 Touring Discussion 8 10th June 2011 06:12 AM
E39 For Sale: Feeler: 01 Gauge Cluster for your dead pixel one jrhaile Parts / Other For Sale or Wanted 0 27th September 2010 08:40 PM
Gas Gauge Problem IRISH M5 E39 M5 and E52 Z8 Discussion 42 11th January 2009 05:57 AM
