E60 m5 increased emissions light help please! - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By AceMaker
post #1 of 10 Old 31st May 2015, 10:27 PM Thread Starter
Loso333
Loso333's Avatar
So my increased emissions has been on for a few months now. When I took it to the dealer they quoted me around 16k for the job. They said the entire exhaust system was bad? Is that even possible? Has anyone ever heard of this or know any approach/ideas I should take to getting rid of this light. I've cleared the light but it'll come back on after 15 min of driving. Please help I miss driving the beast. It's been parked four months. It's a 2006 with 74k miles.
Loso333 is offline
post #2 of 10 Old 7th June 2015, 01:57 AM
jarrett
If you pull the codes and post them, people may be able to help give advice on how to fix it. I had the same error in the car, so I pulled the codes with INPA and did some research online. I ended up replacing the pre-cat o2 sensors and my thermostat (was stuck open) and everything is good now.
jarrett is offline
post #3 of 10 Old 9th September 2015, 02:28 AM
Ysgi
Ysgi is offline
post #4 of 10 Old 14th September 2015, 05:14 PM
AceMaker
hey, I just had my increased emissions come on as well. 2006 M5 also with 75,000 currently. , I have had this code come up at 72,000 miles and ran the codes and first got 2722, high pressure fuel - cleared it out and it came back right away. it was the fuel sensor. easy do it yourself replacement. located in front left wheel well. you have to remove the wheel and the plastic inner fender ( at least remove the screws from the rear portion. It's located rightf to the rear of the shock/spring. 2 allen nuts. just unplug it and then swap it out. Light went out and stayed out. car ran great. Cost $100.
but at 75,000 miles light came back on and said increased emissions and but this time the codes say Cat banks. (brother owns a shop and he knows what he is doing) I guess the catalaytic converters go out about at about 60-80K on these cars. Yes replacements are about $1900 per side from the discount places like bimmerworld. But I found weld in CA legal Cat replacements for $160 ea. checking today to see if can be done while still on the car. If not will need to remove manifolds which looks like a 5 hour job each way. 49 state cats manifolds can be bought for under $1000. We get ripped off in CA
AceMaker is offline
post #5 of 10 Old 14th September 2015, 05:22 PM
AceMaker
pull the codes what do you get?? dealers are rip off places....
Gregory "Wired" Colyer
Ace Maker Airshows
AceMaker is offline
post #6 of 10 Old 14th September 2015, 05:32 PM
[email protected]
m5board.com Site Sponsors
Mark@Evolve's Avatar
post #7 of 10 Old 14th September 2015, 05:41 PM
AceMaker
just to edit my original post... for the 2722 code the dash message does say increased emissions too
Ace Maker Airshows
AceMaker is offline
post #8 of 10 Old 29th October 2015, 07:00 AM
M52006
I got a cat code for passanger side only bad luck but I guess I'll change both.my scanner shows it runs hotter than the left side.
M52006 is offline
post #9 of 10 Old 29th October 2015, 04:45 PM
jcolley
jcolley's Avatar
EGT probes are disabled on mss65 on almost all S85s. This was done via software update only, so the sensors and bungs were left in place. EGT and cat temps are calculated in the DME based in combustion parameters. So, while it still makes sense that the less efficient side could be hotter, it's not via direct measurement per se.
jcolley is offline
post #10 of 10 Old 29th October 2015, 08:06 PM
M52006
I'm not the most experienced with my scanner does pretty much everything last night I look at it again and was able to see the specs for USA and Canada and could see my one side was too high then I was able to erase the history and the problem is gone for now. I'm just saying when I was running the motor you could see the temp on the bad side was higher. I also looked at the co2 sensors and they were in range and ok my scanner can test them.i did a test on the cats and one bank fails
M52006 is offline
Increased emissions light reset itself?! The Engineer E60 M5 and E61 M5 Touring Discussion 4 15th September 2015 12:30 AM
E60 m5 increased emissions light help please! Loso333 Parts / Other For Sale or Wanted 5 14th September 2015 05:43 PM
CE light- Increased Emissions. Related to ASR Exhaust? BioRunUp E60 M5 and E61 M5 Touring Discussion 9 8th October 2011 12:47 AM
Increased emissions light came on tonight Rodster E60 M5 and E61 M5 Touring Discussion 3 19th April 2007 05:38 PM
Check engine light came on - increased emissions tkhater E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 17th January 2007 07:31 PM
