Navcoder assist - BMW M5 Forum and M6 Forums
post #1 of 4 Old 7th March 2015, 12:25 PM Thread Starter
norcale39
norcale39's Avatar
Navcoder assist
any norcal, specifically sf bay area members have access to a Navcoder? In a previous post I mentioned that i was unable to get my 3D perspective b/c the set or settings option was missing from my main menu. i was advised that i would probably need to load a known good, OE O/S CD and get the computer running properly. my tech skills are pretty weak and i have a mac not a pc. why, you ask, why? anyhow if one of you is out there and would be kind enough to assist me to recover the heretofore mentioned options i would be much obliged in one manner or another. thanks
the image is after i updated the firmware.
norcale39 is offline
post #2 of 4 Old 3rd April 2015, 11:26 PM Thread Starter
norcale39
norcale39's Avatar
update:
it seems that it was a firmware issue. i'd purchased firmware and an updated west coast map from two different vendors. the firmware wouldn't give me the set or settings option, which i wasn't aware of at the time. so after i did the supposed update i inserted the newer map cd but my markiv wasn't recognizing it. i contacted the seller and after a bit of back and forth he sent me a corrected version along with a firmware disk. i redid the firmware upgrade with the new disk and voila had the settings option. map disk also works fine. i even found the 3D option. all is good. the original updated firmware disk was the culprit. it's been tossed.
post #3 of 4 Old 10th May 2015, 06:47 AM
MMMLISHS
MMMLISHS is offline
post #4 of 4 Old 10th May 2015, 09:59 AM Thread Starter
norcale39
norcale39's Avatar
i wish i could tell you, 100%, but the disk was generic w/no writing on it. i think it was the version 32, which if i'm not mistaken, is the latest version available. purchased on ebay.
NavCoder WIFI GGodwin E39 M5 and E52 Z8 Discussion 4 17th September 2012 11:37 PM
Navcoder worth it ? englishdan81 E39 M5 and E52 Z8 Discussion 17 14th August 2012 12:38 AM
Anyone actively using NavCoder? Please chime in... SammyD E39 M5 and E52 Z8 Discussion 4 28th February 2012 04:04 PM
NavCoder - where to get IBUS connector? Kmac E39 M5 and E52 Z8 Discussion 17 1st April 2009 09:24 PM
Navcoder gurus in Alberta? 91Notch E39 M5 and E52 Z8 Discussion 15 20th February 2008 07:56 AM
