Clutch Stop DIY - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 15 Old 11th September 2012, 08:05 AM Thread Starter
aznbo187
aznbo187's Avatar
Clutch Stop DIY
Recently purchased a clutch stop from Nelson aka bmwclutchstop @ gmail.com and figured I'd snap a few pictures during the process. It's a fairly straight forward install (10 minutes) but it's helpful for someone that doesn't know how or where the clutch stop installs.
Nelson's clutch stop comes with 3 parts. The stop itself, a flat washer and a nut to lock it in place.
In comparison to the stock clutch stop, this one offers more adjustability allowing you to reduce clutch pedal travel. I also had the UUC big boy stop in my M3, but didn't want to spend much on a part that does the same thing.
The stock clutch stop is made out of plastic with a rubber condom.
The stock clutch stop is located on the floor directly behind the clutch pedal. Remove it using a philips screwdriver.
Once removed, it's just a threaded hole. You want to put the flat washer first, then the nut so that it sandwiches the washer in between.
I started with the nut fully threaded down (longest clutch throw) and then adjusted it until my car stopped starting. The clutch has a switch that prevents the car from starting so you can't adjust the clutch stop to the longest setting (shortest clutch throw) without modifying the bracket that holds the pedal switch. This can be easily done by bending the bracket. Or hardwiring it to disable the clutch switch. With the clutch stop in, you simply screw it by hand. Even with the clutch stop at the shortest length, it's noticeably shorter than stock.
Hope this was helpful! Enjoy your new shorter clutch.
Link to clutch stop.
aznbo187 is offline
The Following User Says Thank You to aznbo187 For This Useful Post:
Sculler22 (2nd October 2012)
post #2 of 15 Old 1st October 2012, 10:15 PM
Richneerd
Richneerd's Avatar
Richneerd is offline
post #3 of 15 Old 11th November 2012, 03:19 AM
Chuck Finley
Chuck Finley's Avatar
Just put mine in today, got it from him via eBay and love it. Best $13 mod ever. Feels so nice.
Chuck Finley is offline
post #4 of 15 Old 11th November 2012, 07:34 AM
greentrbo95gst
greentrbo95gst's Avatar
Did mine as well and love it!!
Sponsored by www.dtmhaus.net
F10 M5,E60 M5, E39 M5, E46 SC'd, F15 Diesel, E90 335d, E53 4.8is, E39 540i
2013 M5 Azurite Black.....[email protected]
greentrbo95gst is offline
post #5 of 15 Old 26th April 2013, 09:51 PM
Jgy6000
Sorry, but what is the point in this mod? I don't understand why you would want to stop pushing the clutch all the way down?
Jgy6000 is offline
post #6 of 15 Old 10th May 2013, 03:54 PM
E39M5MO
E39M5MO's Avatar
i was actually speaking to someone at a local BMW shop, and they said that this could actually be harming your clutch....
2001 BMW E39 M5
Carbonschwarz Metallic
Caramel "Extended Leather" Interior
Eisenmann Sport Exhaust (4x83mm)
Frank Smith Tune (Tuning Techs)
Koni/Dinan Suspension
Squared.
///M Registry
2007 BMW E64 M6 Convertible
SMG III Transmission
Interlagos Blue Metallic
Silverstone II Complete Merino Leather
Stock
///M Registry
E39M5MO is offline
post #7 of 15 Old 13th May 2013, 02:30 PM
Kthxbye
Does anyone know if the 2007 E60 (6 MAT) has a clutch stop? I purchased one from BT and they insist that it is there, however their customer service is horrible and I can't get any detailed information.
Kthxbye is offline
post #8 of 15 Old 20th May 2013, 09:09 PM
M3_JD
Been thinking about this for my E60 and also my E46 M3. The auction you linked says the "shorty" is for E39 only. Can anyone confirm if the "shorty" or the longer E30, E46, etc. version is the right fit for the E60?
M3_JD is offline
post #9 of 15 Old 22nd May 2013, 05:44 PM
JetBlackE46
Only the "Shorty" will work without modification. The one for the E30/36/46 would require you to modify the clutch interlock switch.
JetBlackE46 is offline
post #10 of 15 Old 13th June 2013, 04:14 AM
M+
M+'s Avatar
M+ is offline
Tags
bmwclutchstop , clutch stop , mclubla , nelson
E39 For Sale: M5 Clutch Stop - Must see! JetBlackE46 Parts / Other For Sale or Wanted 174 14th February 2019 06:56 AM
Clutch Start Sensor Modification (w/ clutch stop) russap5 E39 M5 and E52 Z8 Discussion 4 23rd January 2010 09:34 PM
Clutch Stop ag21197 E39 M5 and E52 Z8 Discussion 16 21st February 2008 08:10 AM
clutch stop JLH E39 M5 and E52 Z8 Discussion 0 28th January 2003 11:48 PM
Clutch stop M5Ted E39 M5 and E52 Z8 Discussion 0 13th March 2002 03:41 AM
