e39 m5 hubcentric rings?? - BMW M5 Forum and M6 Forums
post #1 of 8 Old 13th January 2010, 03:15 AM Thread Starter
greekspeed
I put some aftermarket oz rally forged wheels on my 2000 bmw m5 and i am getting crazy vibrations at around 50-60 mph and sometimes higher. I notice then the wheel has to much play so i was wondering if you guys know were i can buy some hub rings that will fit our cars. Its like 74. somthing inner. i checked on ebay and there all 72 inner and i have no clue were to look now.
greekspeed is offline
post #2 of 8 Old 15th January 2010, 06:28 AM
jt2ma71
jt2ma71's Avatar
Youll have to measure the diameter of the new wheels hub, then call tire rack and see if they have anything. I had to make my own, i only needed 0.5mm though.
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
jt2ma71 is offline
post #3 of 8 Old 3rd February 2010, 10:13 PM
gsfent
gsfent's Avatar
Your wheel has to be BIGGER than the 74.1mm inside bore, since it is loose.
If the seller can tell you what car it is designed for, you should be able to determine the inside diameter and then you can get a spacer/adapter made up. If it is small, centering rings should work Try board sponsor Turner Motorsports as a first stop. Or try H&R. Or any good machine shop.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #4 of 8 Old 14th October 2015, 09:08 AM
kingston
i think i have the same issue. Had a machine shop bore the hub for me because they fit a smaller BMW bore. I think they went to big though. The wheel doesn't mount snug to the hub.
kingston is offline
post #5 of 8 Old 14th October 2015, 09:12 AM
kingpin025
kingpin025's Avatar
I'd start back at that same machine shop and see if they'll correct the issue by making you some rings.
Tommy L.
(oOO \ (IIII) (IIII) / OOo)
-o- (##########) -o-
2001 BMW M5 LMB LHD Euro
Bilstein PSS
Dinan Rear Anti-Sway Bar
UCC SSK/DSSR
Matte Black Style 65
Alpine ILX-007 Head Unit
Alpine MRV-F 340 Amp
Boston Acoustics Pro Components
Alpine MRP-M450 Amp
Infinity Kappa 102.7W Sub x2
_____________
Current Garage:
1993 BMW M5
1994 BMW 525i Touring 5spd
2004 Ford SVT Lightning
kingpin025 is offline
post #6 of 8 Old 25th April 2016, 04:40 AM
Thumper600
Thumper600's Avatar
Hub Centric rings
somehow I am under the impression that the e39's have the 74mm hubs and the e34's have the 72.5mm hubs. Call me crazy but that's the hub centric ring I use to put e39 wheels on the e34 car. My stock e34 wheel, (Style 21), do not fit the M5 or my ex '99 e39. This is what I use to make the e39 wheel fit the e34 hub and it somehow seems to work. (BTW, I do not work for the company, I found them on ebay and a set costs $7.00 including shipping.). Please look them up online or on ebay. Hope something as inexpensive as this fixes your dilemma:
Thumper600 is offline
post #7 of 8 Old 4th May 2016, 11:02 PM
Thumper600
Thumper600's Avatar
Wow, just noticed the thread is six years old, hope you got the situation resolved cheap
post #8 of 8 Old 15th May 2016, 12:43 AM
Jrgymie
Jrgymie is offline
E39 For Sale: 3mm H&R Hubcentric Wheel Spacers for E39 ultraman206 Parts / Other For Sale or Wanted 3 1st December 2009 07:54 PM
Want to buy Ac schnitzer hubcentric rings (green 74.1mm) georgost Parts / Other For Sale or Wanted 1 22nd August 2009 12:32 AM
Want to buy Wtb acs hubcentric rings (green - 74.1mm) georgost Parts / Other For Sale or Wanted 0 23rd June 2009 10:47 PM
hubcentric rings WGM5 E39 M5 and E52 Z8 Discussion 0 14th February 2007 02:09 PM
Hubcentric rings Passmore E34 M5 Discussion 4 27th January 2006 02:43 AM
