106 Agera One:1 Silver, w Black & Orange accents - Page 4 - BMW M5 Forum and M6 Forums
Koenigsegg Forum | koenigseggboard.com A Forum for the Swedish supercar manufacturer Koenigsegg. www.koenigseggboard.com
 15Likes
post #31 of 68 Old 1st March 2014, 04:05 PM
Mr. New York
Originally Posted by mattjs33 View Post
That's a bunch of nonsense. They rented the runway for the day, you think NASA really cares which direction they drive on it?
Exactly this ^ If you pay them the money, you get the runway for however long you want to do whatever you want, it's that simple. Now there is no proof etc etc but if the car broke, or for some reason couldn't go 270mph in the other direction, pulling the "one run" card would be a great excuse for the majority of people on this planet. Since no one was there besides Hennessey, no one can prove otherwise, but in reality, we all know they could have ran more passes.
I am good friends with Audi of north america's vehicle transporter, and he told me it's pretty much free roam once you pay the money and the site is secured. The facility is a ghost town, so it's not like any harm could happen.
Mr. New York is offline
post #32 of 68 Old 1st March 2014, 09:00 PM Thread Starter
J_C
Arriving Geneva
[YOUTUBE]https://www.youtube.com/watch?v=WP2qU2rubX0[/YOUTUBE]
Instagram
J_C is offline
post #33 of 68 Old 2nd March 2014, 02:18 PM
Davvemannen
All specs listed on Koenigseggs website.
Koenigsegg One:1
Performance
Power output: 1 MW at 7500 rpm - rpm limiter @ 8250 rpm
Torque: over 1000 Nm from 3000 to 8000 rpm
Max torque: 1371 Nm at 6000 rpm
0 - 400 km/h approx. 20 sec
400 - 0 km/h approx. 10 sec
Braking distance: 28 m (100-0 km/h)
Max lateral g-force: 2.0 g
Emission levels: Euro VI
Aerodynamics
Cd 0.45-0.50 with adaptable rear wings
Frontal Area: 1.910 m2
Total Downforce at 260km/h: 610kg at 440km/h: 830kg
Flat underside of chassis. Venturi tunnels at front & rear of chassis/body
Active aero front and rear underside
Active triplex suspension
Maximized intercooler flow
Dimensions
Total length: 4500 mm
Total width: 2060 mm
Total height: 1150 mm
Ground clearance: Rear: 74-90 mm Front: 59-100 mm plus 50 mm lift system
Wheelbase: 2662 mm.
Front track: 1700 mm. Rear track: 1650 mm.
Front overhang: 944 mm Rear overhang: 900 mm
Fuel capacity: 74 litres
Curb weight 1360 kg (complete car ready to drive with 50% fuel,
100% fluids)
Weight distribution: 44% front, 56% rear
Transmission
Specially developed 7-speed dual clutch, 1 input shaft transmission with paddle-shift.
Electronic differential.
Chassis
Advanced high modulus carbon fibre chassis with F1 style honeycomb core and integrated fuel tanks for optimal weight distribution and safety.
Monocoque torsional rigidity: 65,000 Nm/degree.
Weight: 72kg.
Double wishbones, active ride height control and bevel carbon fibre springs with variable spring ratio.
Triplex damper in the rear.
Needle bearings and o-ringed wishbone bushings.
Fully machined aerospace grade aluminium uprights with SKF LeMans specification 150mm angle contact ball bearings.
GKN hollow/gun-drilled driveshafts.
Koenigsegg Z-style progressive and lightweight anti-roll bars front and rear.
Engine
Koenigsegg aluminum 5,0L V8, 4 valves per cylinder, double overhead camshafts with flex-fuel capability.
Compression: 9.0:1
Bore: 92 mm Stroke: 95.25 mm
Sequential, multipoint fuel injection.
Variable geometry twin turbo chargers.
1.8 bar boost pressure.
Dry sump lubrication.
Carbon fibre intake manifold with optimized intake tracts.
Tig-welded ceramic coated Inconel exhaust system manifold with merge collector.
Weight: 197 kg
Brakes
Front brakes: Ventilated ceramic discs 397 mm, 40 mm wide. 6 ceramic piston calipers.
Rear brakes: Ventilated ceramic discs 380 mm, 34 mm wide. 4-piston calipers.
Traction Control. F1-style for optimal performance with 5 different handling modes.
Steering
Rack and pinion power assisted steering. 2.7 turns lock-to-lock.
Turning circle: 11 metres. Electro-hydraulic power-assisted.
Wheels
Koenigsegg Aicore™ carbon wheels with centre locking.
Front: 19” x 9.5”
Rear: 20” x 12.5”
Tires
Specially developed Michelin Cup 2 tires.
Front: 265/35 – 19” (Y)
Rear: 345/30 – 20” (Y)
Speed rating: 440 km/h
Body
Two-door, two-seater with fixed roof. Body made from pre-impregnated carbon fibre/ kevlar and lightweight sandwich reinforcements.
Electrical System
Unique Koenigsegg developed electronic control systems including:
body, engine, transmission, traction and stability control and power management. Solid state digital semiconductors - minimalizing need for physical fuses or relays. Can bus operated and fully programmable
functionality.
Equipment
Lightweight glass system, power windows, adjustable pedals and steering column, One:1 stitching, adjustable light weight race seats, carbon ceramic brakes, Sport ABS, ESC, active ride height, power steering, power brakes, 6 point racing seatbelts, intelligent LifePo4 battery, USB connection, climate control, digital warning and info system, G sensor, alarm, tyre monitoring system, proximity key, car cover, rear view camera.
Optional Extras
One piece racing bucket seats, active shock absorber settings, full clear carbon body, custom body striping, upgraded audio system, painted calipers, personalized logo on rear hood, anodized black aluminium interior, custom leather One:1 custom luggage set, custom diamond encrusted key, titanium exhaust outlet, active noise cancellation, 3G telematics system, variable turbo geometry.
3 Year Warranty
Davvemannen is offline
post #34 of 68 Old 2nd March 2014, 06:24 PM
Davvemannen
Sneak peak!
EXCLUSIVE: Koenigsegg One:1 Sneak Preview at Geneva 2014 - YouTube
Edit: At 3:12 it sounds like he says that the car was built up from an Agera R?? If so, who? #091? #086?
This plack does say 7105 or 7106 (looks like 7106 to me), but could be possible that if this is indeed an old Agera R that it got a new VIN?
post #35 of 68 Old 2nd March 2014, 07:23 PM
Will_
Looks like 105 to me... The top part of the number has the flat then 90 degree turn like in a 5.
I imagine it wouldve been built up from someone who's getting a One:1's Agera R. One of the Chinese owns maybe or #91, he's owned a lot of Egg's right?
Edit: That doesn't make sense if its built up from an owners Agera R because its their development car, so its probably #77 that went through an extremely quick rebuild or #86 (but I kinda doubt it).
Maybe Tim was just saying that it shares the same chassis/suspension as an Agera R? It was built up from that platform?
Will_ is offline
post #36 of 68 Old 2nd March 2014, 07:45 PM
Davvemannen
It's the dev car so this one is Koenigseggs. It's not #077, parts of #091 has been at the factory for a while and been dissassembled so it's very possible that Koenigsegg bought the car to use for the One:1 dev car. This means that they can re-use alot of parts wich would lower the development costs rather dramaticly. #091 hasn't been seen on the road since summer 2012, but parts like the bonnet has been spotted in the factory. If this is indeed #091 or any other Agera it has gotten a new VIN.
post #37 of 68 Old 2nd March 2014, 08:03 PM Thread Starter
J_C
This is a new car, no doubt! It's made of another (F1 standard) carbon fiber quality (saves 20% weight) with (probably) new layups and everything (read the press release)!
20% lighter carbon chassis and body due to implementation of M46J & M55J high modulus fibers
Edit: .. could be 105 .. .. but should be 106, as Koenigsegg rejected "my" earlier claim that 105 (spotted by joeystockholom) pictured with roof scoop and CvK holding a front wiglet for One:1 was the "one". Now when we know more, it's obvious that the roof is just a loose part as the rest of the car is not One:1
J_C is offline
post #38 of 68 Old 2nd March 2014, 09:03 PM
mattjs33
Moderator koenigseggboard.com
Audio on the clip was horrible for me, all I could hear was the music in the background, so I missed all of that. I think what he means is that the One:1 is generally based on an Agera chassis, in terms of its shape and dimensions. Like J_C says, supposedly the monocoque is unique to the One:1 with a different weave of carbon. If that's the case then I doubt its a rebuild of an earlier car.
I think we knew this car was the development car already going in, very nice of Koenigsegg to label it so clearly for us! I'm sure when clearer photos surface in less than 24 hours now, we will see the door sill much better!
mattjs33 is offline
post #39 of 68 Old 2nd March 2014, 11:15 PM
Will_
I think the chassis in the photo of CvK and the winglet is the One:1 chassis and it is #105, frankly. I asked Koenigsegg on their Facebook page if it was the One:1 and they said it wasn't. They told me "we can't tell you what it is, but it isn't the One:1", but I kinda think they weren't telling the truth because they didnt want the hype of the One:1 and such to build early.
I could be completely wrong though, maybe someone just ordered a fixed roof/hoodscooped Agera R. But remember even though the One:1 is fixed roof, in the production line photos the roof wasnt fixed, it was still open top.
Will_ is offline
post #40 of 68 Old 3rd March 2014, 01:04 PM
joeystockholm
I saw a video where they claim the roof is still detachable but it takes some work to do it..
And are we sure the chassi had the new type of carbon and not just the body panels?
joeystockholm is offline
#105, Agera R, Black w/ carbon accents. Davvemannen Koenigsegg Forum | koenigseggboard.com 71 23rd April 2017 11:39 PM
104 - Agera S RHD Black w bronze accents J_C Koenigsegg Forum | koenigseggboard.com 35 16th May 2014 11:54 AM
#011 - 2010 Ultimate Aero Orange / Orange & Black 1S9SA28440W944011 mattjs33 GTBoard.com: General Sportscars 1 21st September 2010 04:25 AM
