E60 535D - BMW Fastest Diesel 353 HP (!!!) - BMW M5 Forum and M6 Forums
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
post #1 of 30 Old 15th February 2005, 07:29 PM Thread Starter
NSMG
Cheers,
Check out this E60 535D reprogrammed to develop 353HP...
http://www.speed-factor.net/news.php3
This is probably the world's fastest BMW diesel up to now.
Best Regards.
NSMG
NSMG is offline
post #2 of 30 Old 15th February 2005, 07:48 PM
Ashok Arora
Ashok Arora's Avatar
Re: E60 535D - BMW Fastest Diesel 353 HP (!!!)
Welcome to the board
723Nm torque is very impressive as well.
Ashok
2015 White/Saddle Brown Alpina XD3 BiTurbo.. omg!!!
https://www.m5board.com/vbulletin/e60...kend-hell.html
Ashok Arora is offline
post #3 of 30 Old 15th February 2005, 11:59 PM
romeara
I drove the base 535D last week and I have to say it is quite a car. I would have to work hard to lose it in my E39 m5 on the straight. It doesn't have the cornering balance or surefootedness of the M car though, so cornering is a different matter. It's quite a nose-heavy car. I was however quite disappointed with the ride. Compared to a 520i loaner it was quite rough. I blame the run-flats, they suck!
Rob
carbon black M5
romeara is offline
post #4 of 30 Old 16th February 2005, 09:14 PM
AJ
dont worry.. the meatiness of the diesel is only at lower gears... in 4th and 5th it runs out of gear and the e39 m5 will gain but in a light-to-light race i imagine this engine is a tough opponent...
AJ is offline
post #5 of 30 Old 16th February 2005, 10:22 PM
max_m5
max_m5's Avatar
Welcome @ the board! - That sounds great. that means the strongest pcar diesel, vw V-10 TDI isnt the strongest anymore (@313iHP)
<** max_m5 **>
WE HAVE IT: THE NEW E60 M5.
max_m5 is offline
post #6 of 30 Old 17th February 2005, 12:46 AM
Leon82
Leon82's Avatar
talking Re: E60 535D - BMW Fastest Diesel 353 HP (!!!)
I think you might be wrong on this one. Since the car has 2 turbos one works in low rpm and the second one in high. So this diesel unlike others has the power all the time. That is whats so special about this diesel. My dad owns a E60 545i M/paket and I know that E60 535d has a better acceleration from 80 - 120km/h than the E60 545i. AND THATS IMPRESSIVE
Race with the best burn like the rest
Leon82 is offline
post #7 of 30 Old 17th February 2005, 02:34 AM
digger
the fact that the m5 has more power means that puts more torque to the ground than the diesel when operating in high engine rpms, the extra rpms of SI over CI allow it to be geared to provide more tractive effort (force). Look at the power! this tells the m5 has more top end torque to the ground which is most noticeable in a 4th and 5th gear race. The diesel would have good bottom end and midrange grunt though.
digger is offline
post #8 of 30 Old 17th February 2005, 03:56 AM
AJ
in so many words- what digger said.
or to put it differently- the diesel has more tq, but fewer revs (lower redline). this forces the gearbox to be geared very long so the diesel will not run out of revs at higher speeds. well, it just happens so that even with its monstrous torque, at higher speeds the gearing is so steep that it actually puts less tq to the wheels thus providing weaker acceleration.
on the same token, at lower and midrange, where roadspeeds are lower and allow shorter gears, the diesel shines.
a rule of the thumb is that diesels are superior to 100ish mph (more torque, ok gearing) and petrol engines- above that (less torque but much more favorable gearing resulting in more tq to the wheels)...
alex
few cars
AJ is offline
post #9 of 30 Old 17th February 2005, 07:20 AM
alibo70
alibo70's Avatar
It would interesting to see a tuner setup the turbos to run parallel. I wonder what that would do to the power output? I know its popular on the Supra's and RX-7's.
alibo70 is offline
post #10 of 30 Old 17th February 2005, 05:42 PM
AJ
actually both cars in question have sequential turbos. parallel turbos are typical for V-engines so one turbo can feed one bank. however, on the rx7 there are two sequential smaller turbos running all the time (if i remember correctly) and on the supra the 2 sequential turbos have different housings and are controlled electronically for one to provide boost below 4500 rpms and the other to join in above that..
alex
few cars
AJ is offline
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E60 M5 and E61 M5 Touring Discussion 53 12th May 2005 01:51 AM
WSJ article : "BMW's Push to Broaden Line" howler E39 M5 and E52 Z8 Discussion 15 13th January 2005 05:50 PM
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 43 1st November 2004 07:16 PM
