So I bought a Gallardo... - Page 5 - BMW M5 Forum and M6 Forums
GTBoard.com: General Sportscars See the GTboard.com DVD. This form also contains a BMW X6 and X5 Forum.
 22Likes
post #41 of 51 Old 26th March 2015, 05:34 PM Thread Starter
pnirenstein
The original clutches in the early Gallardos often had some issues. My car has 5000 miles on it now and its 30% worn. Some people blew them at 2k miles. Once you replace the OEM piece of cheese they last about 15-20k miles. It ain't a Camry, but like the M5 its worth it!
pnirenstein is offline
post #42 of 51 Old 26th March 2015, 07:20 PM
JZelnick
JZelnick's Avatar
That just seems ridiculous, I know the shifts are probably faster and more violent (read fun!) than a manual but that is such a short service life. The E39's clutch has been claimed to not be as strong as it needed to be but there are quite a few members with over 100k on the orginal clutch.
2002 ///M5 Jet Black/Black
Sport Interior
Titan Trim
M-Audio
Split-Fold Rear Seats
Daily Driven
Bilstein PSS9 Coilovers
X5 Thrust Arm Bushings
Eibach 18mm Rear Swaybar
Beastpower Brackets
Michelin Pilot Super Sport
VAC 12mm Spacer:Front
UUC SSK
ZHP Shift Knob
Muffler Delete w/ Timmay Tips
Shadow Chrome Kidney Grilles
Custom Programmed Hardwired Valentine One
MKIV Nav w/ v32 Update
DICE MediaBridge
3M 20% Colorstable Tint
Clear Euro Headlight Lenses
Umnitza ICE VXX Angel Eyes
Stablemate:
1973 Honda CB350F - Undergoing full restoration
JZelnick is offline
post #43 of 51 Old 26th March 2015, 07:52 PM
Eero H
Eero H's Avatar
Eero H is offline
post #44 of 51 Old 27th March 2015, 03:06 AM
D-RodM5
D-RodM5's Avatar
Congrats on the purchase! Planning to make my stable just like yours! Are you up on Lambo Talk?
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
TimmayTips
Bilstein PSS
Evolve Alpha-N
D-RodM5 is offline
post #45 of 51 Old 27th March 2015, 11:58 PM
Apples
Well done my friend well worth the dream and worth the 8,500rpm red line.
I bought a 04 6 speed and sold it 3+ years ago as I just didn't use it much.
I had an Kreissieg Exhaust on it (amazing) and a flexing right foot it was a blast to run through the gears.
In this vid there was no exhaust so vid is only telling 10% of the real feel/sound that rips through your spine and brain.
Enjoy the car its great.
It will hold a place in my mind forever.
I was lucky enough to be the first person to complete a FIA approved race in the Gallardo in the 2005 Targa Tasmania.
The best thing I've ever done by far, amazing experience ranging around Tasmania at full noise in a AUD$400,000 car with he roads locked off.
Also doa www.youtube.com search for Targa Tasmainia Gallardo and you will have some idea.
https://www.youtube.com/watch?v=zYsxA9UetYY
Apples
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/3:45 diff/BBS LM 19's 275's rear, 245 fronts 440-460hp
YouTube M5 Kelleners Exhaust (race) www.youtube.com/watch?v=v5cJA231c-8
YouTube M5 Exhaust removed...the real beast sound www.youtube.com/watch?v=ozS31-SuO4o2003
2003 M5 (was Yoda) now transformed in a "Aussie UTE"
www.m5ute.com.au
2006 Ford GT Heritage blue
Apples is online now
post #46 of 51 Old 9th April 2015, 04:35 PM Thread Starter
pnirenstein
Apples
Thanks Apples! Sad to hear you let her go, but that Ford GT will do just fine
Yes I'm on Lamborghini talk. I've put 1000 miles on her in 3 weeks, totally obsessed. Regarding speed it is WAY faster than the M5. The pull is at a different level. I'm sure a S/C on the E39 could humble her though.
post #47 of 51 Old 9th April 2015, 06:21 PM
m5 deamon
m5 deamon's Avatar
actually the reason the early gallardo's had clutch issues is because they were not getting all the air out of the e gear system at the factory. Lambo revised the e gear bleed sequence and clutch longevity was improved. Also it depends how you drive it do not use auto mode and lc will put wear on the clutch i would pop it in neutral at red lights, stop and go traffic these are what puts wear on the clutch also have a tech adjust the pis value to superlaggera or even more aggressive as this will extend the life of the clutch cause it engages quicker but you need some one who knows how to use lara and ldas . If its set to aggressive you will be cursing me out so you will have to drive it and find where you like it and have him adjust plus or minus on the pis values. Also there is a screen on the oil tank feed i would remove it and clean it there is also a screen on the transmission that should be checked and cleaned. Also keep an eye on you oil level they eat oil and i would not fill it to the top level marker when hot i would keep it in between the max and min mark. Also if you want a good parts hook up call matrin soto at newport beach lambo tell him george from m-chanics sent you hes a great dude with the best prices in the country feel free to contact me with any questions as i specialize in bmws and lambos
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
post #48 of 51 Old 8th May 2016, 11:54 PM
JrMint03
Originally Posted by m5_ View Post
Was this the one from LNB?
Nope, I bought that one
2007 E60 M5- Black Saphire
Eisenmann Race Exhaust
CIC Retrofit
Euro SMG Tune
RPI Scoops and Block off Plates
Lowtech Front Springs
H&R 12mm Spacers all around
Black Kidney Grills
LED Interior, License Plate and Side Marker Lights
2014 F10 M5- Alpine White
Gloss Black Front Grills
Gloss Black Side Grills
IND Painted Reflectors
BMC Drop in Filters
10mm Spacers all around
Other Rides-
2019 Jeep Grand Cherokee
2017 Mercedes GLE350
2015 Lamborghini Aventador Roadster LP700-4
2015 Lamborghini Huracan LP610-4 Twin Turbo
JrMint03 is offline
post #49 of 51 Old 16th June 2016, 08:42 PM
04yfz
Congrats! Definitely an inspiration for me to work harder. Got a link to your youtube channel? Would like to check it out!
04yfz is offline
post #50 of 51 Old 17th June 2016, 12:44 PM
REKIII
REKIII's Avatar
Any updates Parker? I'm pretty sure your G was hit, I hope you got that all fixed and you have healed. Did you ever sell the M5? Both great cars.
2001 Jet Black M5
2012 Black Ford Raptor
2014 Black Jeep Grand Cherokee Summit
2008 Raven R1 - Being disassembled and sold
REKIII is offline
Video - Underground TT Gallardo vs Heffner TT Gallardo SGC GTBoard.com: General Sportscars 3 16th August 2012 11:15 PM
HD: Lamborghini Gallardo LP560-4 vs Gallardo SE 50-300 km/h x 2 Gustav GTBoard.com: General Sportscars 0 26th March 2009 08:13 PM
HD Video GTBoard.cm: This is how much faster the Lamborghini LP560-4 Gallardo is vs the Gallardo SE 520 HP Gustav GTBoard.com: General Sportscars 9 29th January 2009 03:29 PM
HD video: GTboard.com Lamborghini Gallardo LP560-4 vs Lamborghini Gallardo 500 HP E Gear with Tubi exhaust Gustav GTBoard.com: General Sportscars 0 26th January 2009 04:14 AM
The difference between a Lamborghini Gallardo SE 520 HP and Gallardo 560-4 is significant: Porsche 911 Turbo 997 manual as reference Gustav GTBoard.com: General Sportscars 0 3rd November 2008 05:48 PM
