Using bimmercode I can not get into the Air conditioning ECU module and bimmercode just displays something like "Air Conditioning ECU memory contains critical errors."
I know the Air Conditioning has a fault as 2 weeks after cleaning and recharging the Air Conditioning fluid its no longer blowing cold air. So pretty sure I have a leak somewhere.
(1) Is it possible to see the actual underlying error code using Bimmercode or a different app ?
(2) Could the above error in Bimmercode imply a leak ?
