F10 M5 Rod Bearings and where to buy? - BMW M5 Forum and M6 Forums
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
 1Likes
  • 1 Post By technician117
post #1 of 6 Old 6th April 2019, 04:06 AM Thread Starter
MartynRogue
Before I get the equivalent of a internet slap... yes, I’ve googled the **** out of it. 😂
So, can anyone put me on the right track to where I can buy a complete set of either ACL or King standard size big end bearings in the UK without causing myself a stroke going round in circles please?
Also, can anyone tell me the actual coolant operating temp for the hot V?
Cheers
MartynRogue is offline
post #2 of 6 Old 6th April 2019, 05:53 AM
Craze
Craze is offline
post #3 of 6 Old 6th April 2019, 01:21 PM Thread Starter
MartynRogue
BMW do not supply an upgraded version of their own rod bearings.
I would only use ACL or King bearing as a replacement but I’m having issues sourcing them.
post #4 of 6 Old 6th April 2019, 08:18 PM
Craze
Craze is offline
post #5 of 6 Old 6th April 2019, 10:20 PM Thread Starter
MartynRogue
Meaning BMW do NOT offer a revised or higher quality of rod bearing over the original specification, a well known fact for being such a weak point in the S63 build.
Hence why I’d like to know where I can buy a more superior rod bearing like ACL or KING in the UK.
post #6 of 6 Old 10th April 2019, 12:38 PM
technician117
technician117's Avatar
The rod bearings are fine in this engine. It's using incorrect oil or not letting the engine get to proper temp before driving aggressively that causing bearing failure. What can be a problem are the rods themselves when adding an aggressive tune.
How many miles on your engine?
To more directly answer your question, I'm not aware of many aftermarket sources for internal components for the S63 that can be considered a reliable alternative to OE. There are threads on F10post discussing engine builds/builders using aftermarket parts (from well known suppliers, not no-name brands) that aren't even designed correctly (causing rebuilt engine failures).
Good luck!
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 64k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
286,000 miles and counting
'00 Imola/Imola 107k stock
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
